Results 1 to 21 of 21
    May 2010
    Big Fat Husker Du??
    45NRTH is teasing something on Facebook....
    I'm hoping for a Big Fat Husker Du....
    Reputation: dvo1's Avatar
    Rather see studs.
    Reputation: ecub's Avatar
    Quote Originally Posted by dvo1 View Post
    rather see studs.
    +1
    - Ed
    2012 Trek Madone 6.7 SSL
    2013 Specialized Tricross Comp Disc
    2011 Trek Top Fuel 9.9 SSL
    2012 Salsa Mukluk 2
    Reputation: atom29's Avatar
    Feb 2010
    I bet the BFHD is an actual 3.8" instead of the 3.5" standard HD. It's hard to admit when somone fu**ed up a massed produced item, but everyone that sees one knows it aint right...
    May 2010
    I'm HOPING for a BFHD, but unfortunately I don't think that is what they are teasing. I think Surly will be the only brand putting out the "big fat" sized tires for at least a little while longer.
    Studded HDs are probably more likely...
    Human Test Subject
    Reputation: Volsung's Avatar
    I could see vee rubber making super fats. Their 2012 line added a 26x4.0 and a bunch of 700c x 40 cx tires.
    aka bOb
    Reputation: bdundee's Avatar
    Quote Originally Posted by atom29 View Post
    Yeah I think you're right! But on the other hand everybody has wanted a little bit smaller tire for summer use and by accident they nailed it on the head.
    All fat, all the time.
    Reputation: Shark's Avatar
    Feb 2006
    Quote Originally Posted by bdundee View Post
    Yeah I think you right! But on the other hand everybody has wanted a little bit smaller tire for summer use and by accident they nailed it on the head.
    Exactly. The fat bike makers are realizing that more folks are riding these on dirt, not everyone needs max float.
    Jan 2005
    New question here.
    Quote Originally Posted by FTMN View Post
    I've not yet tried the HD (but intend to)... I'm just curious - does anyone have a listing of tire width of all the major players - on the same width rim?
    From what I can tell, the order is something like this, small to big:
    Husker Du
    Endo
    Larry
    Nate
    BFL
    Quote Originally Posted by gregk View Post
    Husker Du
    Endo
    Larry
    Nate
    BFL
    Is it true that all but the BFL are built on the same casing? If so it seems odd HDs end up being significantly smaller.
    Quote Originally Posted by BobShort View Post
    I have the HD, Larry, and Black Floyds (and one Endo). Of those, only the Endo looks similar to the HD in casing shape on and off the rim. The Larry and Floyd sit differently, even off the rim (IMO)
    Sandy Pants
    I would really like a set of HDs, if they weren't not only narrower but also smaller in diameter than a Larry. Slightly narrower I could live with, but not smaller diameter. I don't need a BFl size (although wouldn't mind), but would buy HDs that were at least equal in diameter (in width also would be nice) to Larrys in a heartbeat.
    Nates are too heavy, and too much rolling resistance for my use.
    Guess I'll just have to continue having a blast with my standard Larry/Endomorph combo - washouts be damned. Sigh.
    Reputation: emp?'s Avatar
    they asked about studs already on facebook, looks like they will just sell a screw in set from what they showed
    https://www.facebook.com/45NRTH
    scroll down abit
    Josh
    Nemophilist
    Reputation: TrailMaker's Avatar
    From what I can tell, the order is something like this, small to big: Husker Du, Endo, Larry, Nate, BFL ?
    Hey;
    Husker Du Tire Profile - For The Archives
    I started this thread on the Frame Forum, and Whit added his wisdom. I'd be happy for anyone to add their findings for the good of all.
    Most people ply the Well Trodden Path. A few seek a different way, and leave a Trail behind.
    - John Hajny, a.k.a. TrailMaker
    Reputation: shiggy's Avatar
    Dec 1998
    Quote Originally Posted by Volsung View Post
    FYI On the same rim the Vee Rubber Mission is a bit narrower than the Nate, but the bead to bead width of the casing is greater than the Big Fat Larry.
    I think the thicker base rubber keeps the Mission from expanding as much when inflated.
    mtbtires.com
    Reputation: Dmonkey's Avatar
    Yes!
    Rather see studs.
    Agreed - much needed this year!!
    "To Name me, is to label me." -
    Michi or Dick Van Patton
    Reputation: pbasinger's Avatar
    Dec 2004
    The Husker Dus I've seen are the same size as the nate's, endo, and larry's. Pretty sure they are made on the exact same casing.
    I'd like to see a 4.7 HD , but the tread needs to be increased proportional to the casing.
    I'm sure we'll see more tires with the BFL casing pretty soon. Maybe a rear specific Surly
    Quote Originally Posted by pbasinger View Post
    I'd also like to see a new Big Fat Something tire, with the something part being "something with more traction (rear) and tracking (front) than the BFL". With the conditions I have to ride in around here, I could use both of those things, but don't want to give up the flotation of the BFLs.
    100+ wheel-build club
    Reputation: johnny settle's Avatar
    Mar 2011
    Husker Du
    Endo
    Larry
    Nate
    BFL
    Husker Du and Endomorph are almost exact same width. I'm getting HD 100mm on a 90mm Uma, and Endo. 99mm on the same rim. For all practical applications the Larry, Endo, and HD are the same width- + or - a couple mm. Seems like the main difference is tire HEIGHT. HD is taller-around 79mm high and Endo more like 75mm. I like the HD's low rolling resistance compared to Endo's. I have recently switched to HD's F + R. They also have better cornering traction than Larry's IMO. Still, if a BFHD came out I would be one of the first to grab one for the front-nice tire. I'd really like someone to produce a BF small-block knobby.
    "Go that way REAL FAST, if something gets in your way... turn".
    no dabs
    Husker Du
    Endo
    Larry
    Nate
    BFL
    I've not seen a Husker Du in person, but the origin8 devist8r is quite a bit smaller diameter than any of the others.
