Page 1 of 3 123 LastLast
Results 1 to 100 of 260
    Reputation: bbudell's Avatar
    Jun 2005
    Best Tracksled Grooming Experience?
    I was curious if anyone out there would be willing to share how well the Best Tracksled is working for grooming? Any comparison to a Rokon/roller combo or other implement would be great.
    We recently got the ok to groom a 15 mile singletrack loop and are trying to determine what will be the best option for grooming. We are using snowmobiles pulling a roller and a Rokon pulling a roller on some of our other trail systems but the Tracksled looks pretty interesting. Seems like it is a more simple device (aka less to break/fail/maintain), the price is right and looks like it can handle tight singletrack.
    Ken
    Dec 2013
    Cuyuna - We got the first one.
    The newer version designed around what worked and what didn't with ours is much easier to maneuver.
    This is a demonstration at Marquette in 40d weather and (very) wet snow. I was there along with another Crew member: https://youtu.be/MRlutC-7ak4
    If you want more details, PM me.
    aka bOb
    Reputation: bdundee's Avatar
    Sure looks like a lot more work than sitting on the Skandic, I could see it if the trails are to tight for a snowmopile.
    Dec 2013
    Quote Originally Posted by bdundee View Post
    Yes, either in trail width or in radi of turns (or both). Also, the groomed width is true singletrack, 20" wide, if you go with the narrowest groom.
    N8R
    N8R is offline
    I'm in the process of building a tracksled for grooming my own trails and should have it finish within a couple weeks. I'll let you know how it does
    My design is significanlty better than the Best Tracksled in several ways, including a much lower center of gravity. I'm using a 13hp 5 spd Honda ATC 200 with an automatic centrifugal clutch as the power plant. These old Honda motors go forever and are about as reliable as you can get.
    13 hp is fine for grooming established trails that have been packed and groomed frok the start of the season, but is not a lot of power for making new trails in deeper powder. Should still be doable if multiple passes are made to precompress the snow before trying to pull a groomer.
    As far as it being alot more work than a sled......not necessarily. If you dont want to stand up, just put a seat on it. I'll have a wide bike saddle on the groomer so I can sit when I want. It will take a little more effort to steer due to you pivoting the entire mass of the track sled, but still not something to make a deal about.
    One big advantage of the tracksled is all your body weight is directly on top of the groomer so you dont have to carry extra dead weight for compaction which is a very significant advantage in a low hp machine. The Best Tracksled groomer shown in the videos is a rather poor design as it has no notches to create a corderoy pattern in the snow for bike tire traction. Not absolutely necessary, but if you're going to make a groomer, why not make it to make the best trail with the most amount of traction. Also, it has a fairly large footprint which compacts less. Using a small 4" corrugated roller has a much smaller footprint and will give way more compaction for the same weight.
    My design will also have a bike mount ontop of the tracksled so I can take my fat bike with me when I groom, in case of a machine failure, I can ride out. Plus it'll look awesome with my steed mounted on it. Another bonus, the extra 35 lbs on top of the tracksled will be welcomed additional traction.
    One flaw, if it can be called that, with the Best Tracksled design is the front track profile. Its low and a perfect semi-circle which is a poor design for powder perfomance in breaking trail/compacting initial contact snow. Look at snowmobiles and the front underside of the track angles up to help precompact the snow for the rest of the track. I'll be incorporating this feature in my build.
    All in all, the Best Tracksled is a noble attempt at making a simple trail groomer and they did a decent job, but still much can be improved upon. IMO, its a much more capable trail groomer than a Rokon. Rokons are also only about 13 hp, and have way less traction and deep snow potential, even being 2wd.
    I'll be making several more tracksleds after my prototype and keep working to improve the design and may even offer a few for sale if theres interest, although I dont really want to turn it into a job. I'll start a new thread in a couple weeks or so with my finished machine and pics/video. I really think a tracksled is the best way forward for fatbike grooming narrow single track, and it can easily fit on a hitch rack on the back of a car or truck. Much easier to load and transport.
    Dec 2013
    I would suggest that that adding weight vertically is going to have unforeseen issues. Our first one had a 13hp motor. It was extra-ordinarily tippy in off-camber or bermed corners conditions. Like "nearly kill volunteers" tippy. The newer ones have 7hp engines and pull fine and far less tippy.
    We are testing a new one created by a local company. The first thing we requested is as little weight above the track as possible. We've found that tracksled seems to do best when it's floating on the snow vs. plowing through it.
    As to the flatness of the groom, the new grooms we use have a whole bunch of 1/2" deep skegs vs. 2 or 3 deeper ones. Otherwise its flat. At Cuyuna we haven't found a bike traction/ice issue with this design, generally the fat bike tires come along and "chew up" the top 1/8" of the groomed surface anyway. I would like to see a "mini-roller" style groom, with a bunch of 4-8" textured rollers in front of foot plate, I think that type of design would be great to refresh the already groomed trail.
    If you are thinking you've hit cats meow with your tracksled design, and live decently close to MN, PM me and I will send you some information.
    I'm with you, the Best Tracksled is work in progress, but I think over the long haul some type of tracksled based device will the grooming answer.
    N8R
    N8R is offline
    CycleKrieg, hope I didn't come across as being cynical towards your design in my post. I'm a critical thinker and am always trying to point out flaws and potential design improvements, even in my own work to continuously improve, and not to discredit past achievements. I think you guys have done a good job and watching your demo vids convinced me tracksled is the way to go. I've been pondering for a while the best machine for fat bike trail grooming, and its down to the tracksled and snow bike, with tracksled having some distinct advantages.
    I've spent a lot of time thinking about the ideal groomed trail, and its not the same IMO as the perfect ski groomed trail. Skiis are long and are better suited to nice flat trails without deep curves and dips. Bikes on the other hand, are well suited to big dips, rollers, etc and this is part of what makes it fun. An overly long machine has a hard time following the contours of deep dips and is less manuverable which is the major flaw I see with current snow bikes fitted with a Timbersled kit. I have a pretty cool short wheelbase snow bike design I may build in the future, but the tracksled is so much simpler, with better weight placement with much lighter overall weight potential, I may never even get to the snow bike design.
    I've got some more ideas for the tracksled, and I'm even planning on building a 50-100 hp version for powder and backcountry use. I wasn't going to give away my design idea yet, as I wanted to be the first to build it. However, I'm more interested in the progression of fat bike snow grooming. To get the center of gravity as low as possible, I'm putting the engine and entire drivetrain inside the track, not ontop. The bottom of the engine will only be about 2" off the ground. The top of the track will go over the engine, and the only thing above the track will be the gas tank. But I may even put the has tank below inside the track on a future build and use a fuel pump to get the fuel to the carb.
    With this motor-in-track design, even a high hp large motor can be used and still have a really low COG. I'm not interested in having a large business making and selling tracksleds, maybe just a few here and there so I'm more than willing to share ideas and collborate on design with you guys, and like I said, I'm more interested in progressing the sport than anything else. I'm in Utah so too far to meetup, but shoot me a p.m. with your contact info and we can talk design.
    Also, on the groomer side of things, the reason the top of the groomed snow gets chewed up by tires is because it isnt packed down densley enough, had time to set up enough, or its too warm out and snow is softening. If the snow gets packed down hard enough with enough weight and as little foot print as possible, the top edges of the grooves in the groom should not be damaged much by low psi tires. If snow is compressed enough, it turns into ice. So if we can achieve the sweet spot of super hard pack, groomed snow but not quite to the point of turning to ice, I think we'll have some durable, fast, good traction trails that retain the ridges in the groom as long as it stays below freezing. How feasable this is, I dont know yet. It could well be that its not easy to achieve this and the top of the groom will always get chewed up by tires, but I'm motivated to try and perfect the art of fat bike grooming.
    Dec 2013
    I'm not affiliated with Best Tracksled at all, other then being a customer. I am a big supporter of the tracksled for fat bike grooming, though, and think more clubs should go that way. We (being fat bike groomers) need to work with builders to create the best solution possible.
    We have different needs. In the Midwest, we need something that can go up punchy climbs, fit between trees, turn tight and is safer than a Rokon, etc. That is why we like the МОТОБУКСИРОВЩИК (literally, "Motor Sled Dog") style tracksled, similar to the units you can buy in Russia from Praxus, Boltmotr or Lebedev. We also would like something a 120# woman can use, so versus the tipsy beast that was the 13hp one, we have downsized.
    The style you are talking about is similar to Crosley T28 or the more refined Crosley T28E-1. The Ski-zee from Canadian uses a small power unit like that. The Russians had something similar, though that was 2-cycle and with the tank up by the user. ( http://i027.radikal.ru/0912/ba/dfab2ad449ae.jpg )
    Yeah, if you were closer, I would invite you to our groom learning/cross-pollination session.
    We are getting pretty good compaction and its not instantly getting chewed up. But a few days with fat bike tires on it does chew up the top little bit. That's why a refreshing groom would be nice. Don't over compact, just uniformly chew up and squish back down.
    At our race last year, we ran 300 racers over tracksled groomed sections and those sections held up better than the doubletrack which was groomed with a Yellowstone groomer.
    I do wish I had some actual "building things" skills because I would build something like the Technomaster Ruff TM-02, but with drop in grooms under the seat.
    Look forward to seeing your version!
    N8R
    N8R is offline
    Great info, and thanks for the links I'll check them out. I think an in-track design is going to be hard to beat for stability and can accomodate any engine size. I'm projecting total machine weight to be 250lbs or less for my first build and with light weight components, future builds could be sub 200lbs. Have you weighed your Best tracksled? I started a build thread you can follow here:
    Intrak Tracksled groomer build- Mtbr.com
    Thanks for the warning about Cuyuna's old tracksled, I've tossed a few messages back and forth with Aaron about buying it. It looked clumsy to me, but if the price was right (it isnt) I would have been willing to try. We have 10 miles to groom here in Fargo-Moorhead. Still looking for a solution! I'll have to hit you up when I head to Cuyuna again. The groomed riding there this January was amazing! Then again every trip to Cuyuna is amazing.
    Jason
    Disclaimer: www.paramountsports.net
    Dec 2013
    Quote Originally Posted by JAGI410 View Post
    PM me with your email address/contact info, we (Cuyuna) are working on some learning/cross-pollination/ideas/come-to-Jesus stuff that will help everyone in upper midwest with grooming.
    I will say the newer models Best Tracksled is pretty easy to use. You are still going to get an upper body workout, but you won't be toasted after a mile. Also, it's not so overpowered and heavy that it drives volunteers vs. the other way around. (In Soviet Russia, tracksled drive you.)
    As I said before, this will be a user based solution and we will have work on it ourselves. That may mean in short run caring less about keeping secrets and more about sharing and communicating.
    Reputation: campykid's Avatar
    Still waiting for this to come to market: Home | MTT136 Yvon Martel.
    Advantages I see: 1. low maintenance motor, 2. maneuverability, 3. light weight, fits in SUV, 4. stealth (electric motor) to facilitate grooming trails in areas where motorized vehicles are prohibited.
    Oct 2011
    wow, jealous of your abilities.... I'm in Western NY and have been having the hope and dream of grooming some of our local trails. done the snowshoe, marquette skies, pulling a tire, pan of a wheelbarrow, etc.... then bought a gravely tractor, then a rokon, then a small arctic cat panther sled, now trying a ski doo alpine, twin track..... problem is that last week, we got 20 inches of snow in 36 hours... so anything but a deep powder snowmachine is going to bog down especially when trying to follow the trail...
    I too, have been looking at all the ingenuity on youtube, (seems like a lot of ideas come out of Russia)... I'd be willing to help fund a local project for a "tracksled" type contraption, I really like the idea of the INtrak mockup you have N8R. be willing to buy blueprints, parts list, and a how to book if any of you are thinking of going that way.
    N8R
    N8R is offline
    Quote Originally Posted by twright205 View Post
    I never build anything with blueprints, I just make a quick concept drawing, sometimes, or just have the idea in my head and build as I go. Fabricating isn't all that hard, especially with the internet and youtube tutorials on about everything. Best thing is to just jump in and start doing it! My 2 pieces of advice to anyone wanting to learn is to not worry too much about making mistakes, they are valuable learned lessons, and always safety first! I'll be documenting the build in the link I posted above, so feel free to ask any questions there on how I'm doing anything.
    Dec 2013
    Tracksleds can handle deep snow.
    https://youtu.be/3sfhOyA8qQA
    Some models in Russia have an removable upward curving "bill" in front of the track to increase length and floatation. Yeah, it would be a two or three pass groom, first with tracksled and small Otter sled and then coming back with the actual groomer, but with some throttle work and not putting your biggest volunteer in there first, it should be doable.
    twright205, if you know someone that can build one of these, give it a shot. Otherwise some manufacturers are coming online. Best Tracksled is there, the new prototype we are testing for another company is almost there. N8R might be getting there also.
    What's going to happen in the long term, I think, is that there will be a messy beginning with lots of Darwinian sorting going on with tracksled designs and features before a "typical" model is birthed. It might be 2 models, a small one, for east of the Rockies that can handle tight spaces, corners and trees and a large one, for west of the Rockies that can handle long grooming sessions in the mountains.
    N8R
    N8R is offline
    CycleKrieg, thanks for all the links of the Russian tracksleds. I didnt even know they existed so it will be a huge help examining their designs. It'll be fun to see where we end up with them.
    beer thief
    Reputation: radair's Avatar
    Dec 2002
    Might be some worthwhile ideas here: ONE, 2 OR 3 TRACKED RIGID VEHICLES, LIGHT
    Subscribed
    ogarajef@luther.edu
    Reputation: 1strongone1's Avatar
    I think the tracksleds are definitely the future of singletack grooming. For the time being our group took an AD Boivin Snow hawk JR and made a custom roller to pull. Our trails are very tight with steep elevation, this set-up worked well, however it didn't have enough power and the Snow Hawk engine is a piece of junk. During the off season we put a new 6.5 hp engine in the Snow Hawk and it pulls the 60 pound roller no problem, 1 pass and our singletrack trails are perfect. The only thing that could make the set up better would be a little wider track on the snow Hawk.
    Attached Thumbnails Attached Thumbnails Best Tracksled Grooming Experience?-img_1357.jpg
    "RIDE IT LIKE YOU HATE IT"
    Reputation: Steezus's Avatar
    Quote Originally Posted by N8R View Post
    I don't think that you will ever retain the ridges after a bike rides over your work. I used to operate snowcats at ski resorts and that high speed tiller in the back beats the arms off of the snow crystals night after night to quickly turn the trail into hardpack and the ridges would still deform quite easily. I don't think it is important to maintain those ridges for fat biking though.
    One resort I worked at modified cats to spray water on the trails and that would create a really strong base at least, but not practical for the application you guys are talking about here as the weight would be tremendous.
    Pretty neat to follow this discussion though. The machines people are posting here look as fun as actually biking the trails.
    Jun 2005
    I thought this was interesting: SNOWDOG CLUB Looks like the Russian Baltmotors tracksled is working on districbution in the US.
    Reputation: c0nsumer's Avatar
    If you haven't yet, hit up the NTN. Earlier this year at the Fatbike Summit they tried one out on the North Trails and I was told they were purchasing one. The resulting groomed surface was nice to ride, and they were able to get it through narrower corridors and up/down greater slopes than they could with the snowmobile.
    Dec 2014
    Quote Originally Posted by bbudell View Post
    That looks pretty cool and reasonably priced.
    Their dealer locator shows dealers in the U.S.
    Mar 2012
    Quote Originally Posted by prj71 View Post
    I'm somewhat suprised the snowdog has not gotten more traction as a groomer. I believe it's safe to say that one of these snowdogs will make it's way into western WI in the near future for grooming singletrack.
    The price is right for one of these, and as mentioned above it's nice to have a dealer backing. The design also looks spot on, which only makes sense as the Russians typically have to deal with lots of snow.
    As a bonus it appears this unit may work well for hauling equipment in the summer months.
    Oct 2011
    Just pulled the trigger on the 10hp compact snowdog model. expect it to get to me in Western NY by 12/28... of course two weeks ago we got over 20 inches of snow in 36 hours. now with a chronic thaw, melt, rain cycle, who knows what I will have to play with when it gets here.. but Winter just started so I am sure there will be opportunities... I'll be sure to post up some pics and videos if it works like I am hoping... if you are in the market.. I dealt with Vlad v.filatenko@snowdog.club .... if you happen to be in Southern Ontario check out Scott at jsperformance@computan.com I know he had a compact 10hp... and a few of the regulars coming in....
    Merry Christmas and here's to a grooming new year
    Dec 2014
    Quote Originally Posted by blum585 View Post
    One of our local trail groomers in northern WI is thinking about buying one of these.
    Sent from my SM-G900V using Tapatalk
    Whats the price of the Snowdog?
    Jason
    beer thief
    Dec 2002
    Prices are given on the web site; about $3k+/-: SNOWDOG CLUB
    Thanks, I missed that. I'm tempted! This from the FAQ is concerning though:
    Why Snowdog`s engine shut down when going up the hill?
    Snowdog is equipped with an automatic oil level sensor that shuts the engine with a low oil level or when Snowdog is at a large angle of inclination. We recommend to place the Snowdog in the horizontal position, check the oil level and start the engine.
    Jason
    Mar 2012
    Well, Having purchased a snowdog for our local club 2 days ago then grooming for the past 2 nights I can say that the engine does not shut down on anything it can actually climb. It does shut down if it's about to tip over, it's got to be at a 45 deg angle or greater. With this said, like every tool, it does have it's limitations. It tracks much better on side hills when the left side of the unit is on the up hill side of the hill. And it's not something that you can just unload and go. unless you are grooming really flat areas. If you are grooming singletrack it will take some time to learn to use it, trust it, and find it's limits. I groomed some of the tightest single track found in La Crosse WI, and after learning how to use it go through nearly everything. It does have width limitations, but then again so do your handle bars. I got through trees that seem tight in the summer with 720mm wide bars.
    We picked our unit up and Kinni Sport and Power in Riverfalls, WI. The snowdog is new as of this year to the states. We paid $3165 (tax included) for the unit, the sled, seat and cup holder. Haven't used the seat, and have only groomed with the sled. We will be working on testing attachments that may led to better grooming. All of this fatbike grooming is still a work in progress.
    Dec 2013
    The tracking on hills is due to the gyroscopic forces of the clutch mechanism. (We have had the same thing with our tracksleds, they are not Snowdogs.) If it really bothers you, groom the trail in a direction determined by which side (left or right) has the most uphill to it. Otherwise, you get used to it.
    Build a groom vs. using the otter-style sled. You will get better results, the groom can be easier to maneuver. We've only used pan grooms so far, but have ideas to build a small roller groom (6" lawnmower wheels) and leveling/de-icing groom (reverse V).
    Another thing we found: grooms work best if they have a skeg (the vertical runners) every 2" or so across the bottom. The skegs then can be shorter (3/4") in height and you will get better tracking and easier to maneuver because you get more vertical surfaces to interface with the snow. Having only 2 skegs, one on each side means the downhill skegs is just flapping in the breeze without much snow push against. A series of them across the bottom give you uniform bite across the whole surface.
    Questions:
    Did you get the 7hp or 10hp model?
    Compact model?
    Is the include headlight worth anything?
    Our trails are very flat, this thing looks ideal. I'll reach out to the dealer in St. Cloud! Thanks for the info!
    Edit: The 10hp Compact model, sled, and seat would be $~3280 after tax. In stock too!
    Jason
    Oct 2011
    mine is set to arrive in Western NY on Tuesday or Wednesday,,, I got the 10hp.. compact model, looking into fabricating other stand on grooming attachments as well. please post up pics of ideas if anyone has one.. thanks for the update on your experience, really hoping this does the trick.
    Dec 2013
    You mean like this one?
    Mar 2012
    Quote Originally Posted by CycleKrieg View Post
    Questions:
    Compact model?
    We bought the 10 HP Compact Model, the light is a dual LED is and is more than bright enough to groom with at night. I bring a spare light along mainly to use as a flashlight. Do you have any photos of the groom that you've use? The sled that comes with the unit has 4 or 5 runners on the bottom, and it does float a bit too well.
    Kinni Sport and Power in Riverfalls are selling these unit's for $2999 plus tax. This is for the 10 HP contact, with sled and seat (and beer holder)...
    Dec 2013
    We don't have a picture of our groomer that shows the unit in any detail.
    Its very similar to the one shown here, at Black's Grove.
    https://twitter.com/BlackGroveRCR/st...55470000250880
    Instead of the plastic boat runners, we have skegs made with 3/4" angle iron.
    Mar 2012
    That drag is even being pulled by a Snowdog. Looks like a winner.
    May 2013
    Is there a boxer style engine (like BMW motorcycle opposed cylinders) made that would work? Lower center of gravity.
    it's a single cylinder engine, probably 2 strokes, so you can turn it any way you want. you'll have to refit everything then. not sure there is somethings to win.
    Mar 2012
    Do you have any better contact information for this club? Their website is not very helpful for contacts...
    Dec 2013
    Yeah, they are no good at the web stuff.
    I have found their FB page to be the only way to get a hold of them consistently.
    https://www.facebook.com/RiverCrossingMountainBikeRace/
    Its a shame I'm a little booked up with other things. I'm designing a grooming system I plan on open-sourcing that would work for tracksleds, snowmobiles and Rokons.
    Mar 2012
    Awesome, can't wait to see what you build!
    N8R
    N8R is offline
    I'm curious what the COG is like on the sled dogs. I'm about 90% finished building my Intrak tracksled and am very pleased with how low the COG is, at least on flat level ground not running. Its pretty effortless to tip it over to a 45 deg or more angle in riding position behind with the steering pole and doesnt feel like it wants to tip over at all. Its super stable. That is with an empty tank of gas though, so we'll see how much difference 8 lbs of gas makes. May play with putting a large gas tank down low infront of the motor with a fuel pump that pumps fuel into a tiny tank above the tracks and recirculates back down into the low larger tank . Then the small tank above will gravity feed to the carb. That way if the fuel pump ever dies, you still have a very small tank on top that you can just manually fill to get home.
    I'm already designing my next model that will have the motor cylinder in a horizontal position which will get the engine mass and carb even lower and allow the machine to be quite a bit lower. I'm not sure its even necessary as the current prototype has such a low COG, but always have to improve regardless.
    beer thief
    Dec 2002
    More pics please
    Dec 2014
    I'm picking one of these up and delivering it to a trail in northern WI today. If I get to see it in use maybe I'll be able to provide some feedback.
    Dec 2013
    Again, I want to put a gentle reminder out there.
    There is some planning for a tracksled demo. The planning is in very early stages and may not happen. However, if you are in MN, WI, IA, ND or SD and are interested in the idea of a tracksled, PM me with your email address and I will add you to invite list.
    Dec 2014
    Delivered a Snowdog to northern WI yesterday. Got a chance to try it out on some tight twisty single track. It works real well. Little bit of an arm workout but not that bad.
    The new owner was able to groom some trail that wasn't possible with the snowmobile.
    Dec 2013
    I'm curious about that too. Though the Snowdog uses a 20" (500mm actually) track vs. the 15" ones the USA built ones are using. Based on our experience, a wider track should make it less tippy on off-camber turns.
    Oct 2011
    Best Tracksled Grooming Experience?-15823353_10211520998808669_5473607376141465652_n.jpg
    just had my snowdog out this am... we got socked with 12 inches of new snow overnight. almost too much, had to break trail walking it in some deeper sections, others, the sled worked well.. I tossed on a pair of marquette fat skies and that helped getting through the deep stuff. after one pass , subsequent passes much easier.. I agree there is a learning curve, certainly making a stand up ride on grooming plate for it.
    center of gravity question... again learning curve. so deep today it was easy to start rolling over, but you can catch it, once a track is set, very little issue, I did have it start to go over and shut down.. but started back up with no issue. the quality of the build and thoughtful design is nice...https://youtu.be/0_kpKLde9t0
    Jan 2017
    Hello folks.
    As we just found out that Fat bike racing activity is big time in USA couple weeks ago we began working on a special accessory for fat bike trail grooming based on our X-country ski trail groomer. We will not be able to provide them this year but some demo`s in February, but next year you will be able to purchase it before the season starts.
    Vlad Filatenko
    Snowdog team.
    Quote Originally Posted by Sndg View Post
    Hello folks.
    Vlad Filatenko
    Snowdog team.
    My organization is interested in buying a Snowdog, but we'd really like it to come with a stand-on sled for grooming single track fat bike trails. If you can come up with a factory solution for this -- so we don't have to build our own -- it'd be excellent. If you offered a single track grooming package specifically, that'd be all the better.
    Reputation: dudeist's Avatar
    Apr 2013
    Hi sndg, could you show us the xc ski groomer?
    mechanic
    Mar 2015
    I have been talking with a dealer for the snow dog in Canada He says he is having troubles with the carb and clutch freezing up on the 10 hp one. we are looking to get th 13 hp one. So he is holding off on selling it till that problem is resolved. Any one else have issues?
    Banned
    Jan 2015
    Why would anyone buy or use one of these things? It looks like an ass backwards snowmobile. A regular snowmobile can do everything it can, much faster and more easily and then still be used for a ton of other things. You can tow whatever groomer attachment you like off the back of a snowmobile so I'm trying to understand why this machine even exists? It's cheap compared to new snowmobile, I'll give it that but plenty of good used work/utility snowmobiles can be bought for the same price and are actually easy to get parts for, can carry two people, and be used to haul somebody out if they are hurt back in the woods, keep the wind off you when riding it, etc, etc. This thing looks like a 1950's snowmobile design that never went anywhere because it is so impractical.
    Because snowmobiles cannot fit on single track trails, add a groomer and you are limited to double track.
    The idea is having a machine that can be manipulated in tight areas, even turned around, by one person, which is necessary when grooming narrow and windy trails.
    Not to mention, snow mobiles are loud, fidgety, and hungry.
    Our state park went as far as to say no to snowmobiles, but yes to a Rokon.
    Quote Originally Posted by ak-rider View Post
    Live to Ride-Ride to Live
    This is my current project. It should be ready for field testing next week after final welding, aluminum decking, hood, and paint. Planning to bolt on the handlebar so that it can be moved if placed wrong.
    mechanic
    Mar 2015
    This looks rad I want one Message me if it works!!
    Quote Originally Posted by Deadman View Post
    Banned
    Jan 2015
    Quote Originally Posted by Nurse Ben View Post
    How wide are the trails you are trying to groom? Many snowmobiles can have their front ends narrowed up either with available adjustments or aftermarket front ends.
    Regarding noise, these gasoline engine powered track contraptions are going to make noise as well and very likely use carburetors. Modern sleds are fuel injected, can be had in either 2 or 4 strokes and are not at all figety. I bet a Ski-doo 600 ACE gets better mileage than the tracked lawnmower type machines I'm seeing in this thread.
    N8R
    N8R is offline
    We're grooming 24" singletrack. A snowmobile is very limited to how narrow it can be made due to the wide engine and hood. It would take a lot of modification to even try and get a snowmobile less than 36" in width, and forget anything even close to 24".
    A tracksled is about half the weight of a snomobile and much easier to manuver, has double the floatation over deep snow, and can go many places a snowmobile wont fit, like between trees, under and over logs, etc. Snomobiles are also terrible for the beginning and end of season when the snowpack is minimal and rocks and roots are near the surface. Tracksleds are all season and can be ridden over rocks, roots, in sand, mud. Sometimes conditions are such that theres enough snow to pack a trail for fat biking, but too little to safely ride a snowmobile.
    They are also much simpler and easier to work on. Some of the Sleddog models are a bit heavy at 350 lbs, but my Intrak is around 250 lbs, and I can transport it on the back of a car in a hitch cargo carrier.
    I've ridden snowmobiles alot and for what they were built for theyre great. Not sure what fuel mileage the newest crop of sleds get, but the older used ones that are cheap and affordable get crap fuel economy, like 10 mpg or worse average. Just putting around a tracksled is going to be more fuel efficient, and with the proper exhaust, much quieter.
    Jan 2017
    XC ski groomer
    This is what we use for Xski trail grooming. Scheme in PDF is under the link.
    Groomer is 9 inches wider than the track, coming up ti 29,33 inches wide.
    Snowdog track is 20` wide. I would be very thankful for the feedback, how wide of the trail groomer that will feet your needs the best ?
    Best Tracksled Grooming Experience?-img_2896.jpgBest Tracksled Grooming Experience?-img_2897.jpgBest Tracksled Grooming Experience?-img_2898.jpg
    https://drive.google.com/open?id=0Bw...1VWWHlBLUYxMXM
    Quote Originally Posted by dudeist View Post
    Apr 2013
    That looks great, Snowdog. Thanks. Do you sell them and how mucho$$? We would probably want only 20-24 inches wide. Our bike trails are narrow and have lots of trees and rocks on the sides. (and in the middle) . Probably should taper the front a bit so it doesn't get caught on stumps and rocks. Others may want more width, but I'm curious how that works. I guess one needs a little overlap for the corners. Some trails will need reroutes or added B-lines for a machine anyway.
    Jan 2017
    First shipments of XC ski groomer will be available in USA this February. But I have got few suggestion how to improve it from Cuyuna Lakes Mountain Bike for Fat bike trail grooming and we are making something very convenient for use and factory manufactured. I am hoping to fit into $450-600 MSRP price.
    N8R
    N8R is offline
    Looks good! I was originally thinking of going that route, and just putting a motor ontop of a complete snowmobile track and skid, but wanted to try and in-track motor design. Where did you get the CV clutch, is it one for a go kart off ebay? I've been eyeing those to possibly try on my next build.
    N8R
    N8R is offline
ID:	1113449Click image for larger version.
ID:	1113450Click image for larger version.
    Desired width can vary depending on preference. Some fat bikers like narrow 24" trails and others like wider 30-36" wide. I would suggest making the groomer 24" wide and then making some side attachments that can bolt or clip on the sides to make the groom wider when desired. That way, when grooming if you wanted certain sections of trail wider or narrower, it would just be a matter of adding or removing a couple side attachments.
    Mar 2012
    I've put about 15 hours in on the snowdog now for grooming very narrow old school hand built single track. There is no way another machine such as a standard snowmobile could even come close to fitting into the locations that the snowdog fits.
    With this being said, the width of the track is all the wider a drag / grooming attachment should be, any wider and it would not fit between the trees or rocks on our trails. So far I've been using the sled that comes with the snowdog, but will soon be building a drag similar to the drag used a Black's Grove MN. Having a snow comb on the back would be nice, along with having something that will help level / cut up ice.
    regardless myself and others in my area really appreicate that a machine like the snowdog was designed and built as without out it we would not have groomed single track!
    Yes, the clutch is a Comet knockoff. Some in our group think a hydrostatic drive from a lawn mower is the direction. It would be nice to have reverse and variable speed at full power.
    Dec 2013
    Watch those Comet knockoffs. They will go SPLAT! on you. Drop the extra coin for a real Comet, you won't regret it.
    You don't need a transmission. Grooming is done at fast walking speed, depending on the size of engine, it will be about 3/8 to 1/2 throttle, max.
    If you make it light enough (as close as you can to 200lbs), you will find you don't need reverse. Just pull the unit backwards.
  67. #67
    N8R
    N8R is offline
    In this regard, I really like the 5 spd tranny with the auto clutch with the 3 wheeler motor. The gearing is so low I can start in 4th gear from a dead start no problem. I find that just leaving it in 2nd or 3rd gear is plenty fast so no need to even shift gears at all. But its nice to have the option depending on what I'm using the machine for. 1st gear is way low and really useful for snow plowing or pulling heavy loads. I built it primarily for grooming, but it is a multi use machine.
    I'll post a more detailed report in my Intrak build thread, with my observations. The biggest thing I noticed is it does take a lot of effort to steer the thing, but there's a lot of room for optimization such as changing underside track profile, increase leverage etc. The COG is low, but my machine would still be a handful for a small person to manuver. I dont think theres anyway around having to build much smaller tracksleds for smaller people.
    Once I get the steering dialed in, I'll be happy with the tracksled.
  68. #68
    beer thief
    Dec 2002
Name:	Tracksled - Groom - Pan.jpg
    This looks ideal. I assume the fold out wings are angled to chamfer the sideslopes? Have you built any of these and if not would you be able to send a .dxf file of this?
  69. #69
    Dec 2013
    Quote Originally Posted by radair View Post
    This actually the "old" version. It's based on the first groom we had with the improvements we wished for. I'm working on a new one that will be modular. It will be designed to work with tracksleds, snowmobiles, Rokons, and everything inbetween.
  70. #70
    N8R
    N8R is offline
    This sounds great, looking forward to see your groomer design.
  71. #71
    Snow Dog looks like a good solution, following this thread for more info. We are ready to buy a groomer for fat bike riding as soon as we get some snow.
    Michael Vitti
    CLIMB President
    www.CLIMBonline.org
    www.IMBA.com
    NY State Trails Council Member
  72. #72
    Quote Originally Posted by sick4surf View Post
    Suggestion: Buy your groomer before the snow hits. Once the snow falls you'll want to get on it, not start shopping and find a week/month/whatever lead time.
    We (cramba.org) bought our groomer and snowmobile in autumn, then when snow came to SE Michigan last year we got things done. It's been great! (Wildcat groomer and small sno-scoot-like snowmobile.)
  73. #73
    Oct 2011
    Quote Originally Posted by belterskelter View Post
    I have the 10 hp. compact.. no problems so far,
  74. #74
    Oct 2011
    Quote Originally Posted by c0nsumer View Post
    yes, to the above.... having it ready to go and keeping on top of each snowfall sounds like the key to having a good season...as I stated previously mine arrived day after 12 inches of new fell on top of about 8-10 base, then 55 degrees and an inch of rain, now back to 18 degrees. taking more work to get the trails packed down,, but I believe at least for our trails, this will be the best solution...(still working on a standup groomer to ride on)
  75. #75
    beer thief
    Dec 2002
    Mine is due to arrive Monday. Please post pics of what you end up with for a grooming sled. I have a bunch of scrap steel and am going to start cobbing something together.
    Can you give me dimensions of the hitch? It looks like a mini-pintle hitch?
  76. #76
    Jan 2017
    Curious what people are using for insurance when grooming using tracksleds that do not require a license plate. Snowmachines with license plates are way to provide insurance (at least in Canada).
  77. #77
    Oct 2011
    guess if your land manager allows lawnmowers, weed whackers, or chainsaws perhaps.. tracksled is ok, kind of like on same level or a motorized wheelbarrow
    that's one of the perks for me, no reg. no insurance no need to have a trailer.. plus with 20 inch track packs a nice size swath..
  78. #78
    or lawn Tractor.
  79. #79
    mechanic
    Mar 2015
    Quote Originally Posted by hehnerca View Post
    I have checked with ICBC and the track sled does not need to be registered, that is for bc, alberta, sask, and manitoba. that is all i know so far.
    Our organization still is going to be getting liability insurance to cover, trails society and land owners and directors and volunteers. we just put our money down on a 13 hp snow dog today!!!! so cool things will be happening in Rossland
  80. #80
    Dec 2013
    A quick note from those considering any type of tracksled.
    Length and weight are the two determining factors on the maneuverability of tracksleds. I know its tempting to go all 'Merica and go bigger, but the heavier you go, the more muscle powered required to move the machine. The longer you go, the further you have to move the bars to get a tight turning radius. When you combine long and heavy, you need your He-man volunteers to use it.
    The big advantage of tracksled, beside cost and narrowness, is that (at least with smaller/lighter variety) they are easy enough to maneuver that volunteers (teenagers, smaller women, etc.) that may not have strength to manhandle a snowmobile or Rokon down singletrack can now groom. By going long and heavy, you negate that advantage.
    If someone approached me and asked me describe the perfect tracksled based on our 2yrs of experience, it would 36" to 48" long, 6hp to 9hp and have weight at or below 200lbs.
  81. #81
    Reputation: Johanneson's Avatar
    May 2012
    I think a 20"-24" sled trail laid down by a 1.25" lugged track is perfect, no additional grooming required. That said, there's a lot of "bike" trail a skandic will never be able to negotiate like your Snow Dog could.
    What's the machine behind you in the last pic? It looks like something different. Thanks
  82. #82
    Mar 2011
    You're probably going to need a track with taller lugs, I've seen where anything less than 1 3/4" lugs spins up easily.
    Mongoose product development
  83. #83
    Mar 2011
    thanks for the info.
  84. #84
    N8R
    N8R is offline
    I would have to agree with this assesment, that if one's primary use of the tracksled will be grooming using volunteers, a smaller lighter machine is better. The smaller machines will struggle in non-grooming use such as pulling a cargo sled through deep snow. Also, for heavy snowfall, and neglected trails a larger machine with a longer track and taller lugs is going to be much more effective, at the expense of greater effort/strenght expense.
    IMO, the ideal situation is to have one of each, but if grooming is the primary use and only one machine can be had, I'd say get the smaller 6-9 hp machine and stay on top of grooming from the start of the season. I have an old honda 5.5 gpx160 generator motor lying around I think I'm going to build another one with, with about a 3' track footprint, and see how light I can make it. It'll be one speed, no transmission, just a centifugal clutch. I will use a longer lugged track something around 1.5"-1.75".
  85. #85
    Dec 2013
    Something like a Technomaster maybe?
  86. #86
    N8R
    N8R is offline
    Yeah, I'd like to build something like that, thats along the lines of what I'm thinking. Your suggestions have convinced me thats a good option to explore.
  87. #87
    Mar 2011
    Where did you guys find that Tecnomaster thing?
  88. #88
    Dec 2013
    I found pictures of this one on Unusual Locomotion.
    Technomaster is the distributor for Ruff. The new Ruff models look all 1950s with curves and cherry/cream paintjobs.
    The Russians have all manner of snow machines, from the Мотобуксировщик (lit. "motor snow dogs"), which we call tracksleds to mini and micro snowmobiles. Some of seen the Fisher 2MP or my favorite the SnowFly (picture below).
    If you want ideas and can read through Google Translate or have someone that can read/speak Russian, take a look at motodog.ru . They have forums, include DIY build forums with pictures. If you want to see what machines are purchasable in Stalin's neighborhood, check out master-tehno.ru .
  89. #89
    beer thief
    Dec 2002
    Quote Originally Posted by skota23 View Post
    I posted this on page 1 of this thread and may have found it from a link CycleKrieg posted earlier. Cool stuff in it: ONE, 2 OR 3 TRACKED RIGID VEHICLES, LIGHT
  90. #90
    Mar 2011
    awesome, thanks
  91. #91
    I bought a Snowdog 10hp compact, along with the sled and seat. Demo'd one, made sure it fit in the back of my Subaru, and bought it. Will work on grooming this weekend!
    Jason
  92. #92
    beer thief
    Dec 2002
    I bought the same set-up and have done just a few test runs around my property. Unfortunately we have a hard & sketchy crust that is not really groomable at the present time. The thing is going to be fun! I'm going to try hauling some sizable rock slabs to a wet spot on a snowmobile trail for armoring in the spring. Need to build a stone boat to haul them on first.
    How about that steel shipping frame? That thing is awesome and will become a project in itself. Not sure what I'm going to turn it into yet...
    Attached Thumbnails Attached Thumbnails Best Tracksled Grooming Experience?-snowdog-package-2-large-.jpg
  93. #93
    I picked mine up from a dealer, so I missed out on the steel frame! Groomed about 3.5 miles tonight. That little headlight on there is plenty bright, but I supplemented it with my helmet light as well.
    Jason
  94. #94
    This is the track that came with the skid as a $15 package. Once the thing is proven to run I will change it to a more aggressive track. It will only take about 30 minutes total to change. It should run by Monday!
  95. #95
    N8R
    N8R is offline
    If you are just using the machine for grooming, the track you have should be fine. If you are wanting to also use the machine to play in deep snow, you'll probably want a more aggressive track and a bigger motor.
    I built mine for grooming, but now that it's running and I've experienced how awesome these machines are in and of themselves, tracksleds and using them as utility/exploration/fun machines is turning into a winter activity on its own, not to replace fat biking of course though.
    Here's a vid of mine in 2' plus deep snow. My track is same as yours and does ok. More aggressive would be better though.
    https://youtu.be/ipTiJd1bsAo
  96. #96
    N8R
    N8R is offline
    The tracksled continues to impress me!
    https://www.youtube.com/watch?v=yCFlmrWaCTA
  97. #97
    Fun in and of itself!
    But how does it compact/groom? After 1 or 2 passes shown above can you bike the tread?
  98. #98
    N8R
    N8R is offline
  99. #99
    N8R
    N8R is offline
    Quote Originally Posted by bme107 View Post
    Not with a big high floatation sled behind it. Also, number of passes doesnt matter, the first pass compresses the snow as much as its going to, and addition passes wont compress it any more unless you add weight to the machine and sled or decrease the footprint. I'll be making a much smaller footprint groomer to stand on that will compress the snow enough to bike on.
    This is just a generalization, good hard snow packing depends on variables such as snow consistency, temperature, etc. White fluffy sugary snow does not pack well. Slushy snow does not pack well. Some kinds of wet dense snow do pack very well though.
    Generally, you're never going to be able to make a pass and then bike right away. The groomed trail needs to set up for a while, overnight is usual. With the right wetter snow conditions, I have had the high floatation black sled in the video make a track that overnight set up super hard and was perfect for biking, but generally, you don't want high floatation for grooming.
  100. #100
    mechanic
    Mar 2015
    first try in Rossland BC
    this was our first test on the 13 hp snowdog !! and it worked great with the ghetto drag that we made out of old skis and what ever we could scavenge
  1. Grooming for fatbikes
    By zaab70 in forum Trail Building and Advocacy
    Last Post: 01-26-2017, 09:15 PM
  2. Grooming snow
    By D.F.L. in forum Fat bikes
    Last Post: 10-18-2016, 12:07 PM
  3. Fat-Bike.com Trail Grooming Series
    By JordyB in forum Fat bikes
    Last Post: 02-23-2015, 12:06 PM
  4. Corduroy grooming
    By Welnic in forum Fat bikes
    Last Post: 02-08-2014, 12:03 PM
  5. Duthie Trail Grooming
    By AlpineE30M52 in forum Washington
    Last Post: 07-19-2011, 03:17 PM
Members who have read this thread: 110
