Page 3 of 3 FirstFirst 123
Results 201 to 260 of 260
  1. #201
    Jun 2010
  2. #202
    Jun 2010
    https://scontent-lga3-1.xx.fbcdn.net...4f&oe=5ABD295E Then we welded on a mountain bike forks steer tube. I mounted a stem and mountain bike bar to that. This gives me a wide range of adjustability. It is also easier to play with different width bars. It might look weird keeping the old bar still in place, but this does allow me to go back to more as it originally was. It was a little easier to not relocate the electrical switches. It's less work if I switch out to another sized bar.. and I find the switches better protected where they are. This whole set up shorted the overall length of the machine.. allowing it to fit in even tighter trails. It also changes where the machine pivots as you turn it, also quickening up the handling. So far the down sides.. when folding up the assembly, it doesn't nest as well on the top of the machine. It also takes more physical effort to turn on dirt {I personally don't plan on using this on dirt, but it is also very easy to put it back to it's original handling and nesting positions]
  3. #203
    Dec 2017
    Quote Originally Posted by Fenlason View Post
    https://scontent-lga3-1.xx.fbcdn.net...47&oe=5AF69C21
    The lower bar is the original part of the frame where the handlebar assembly rests.. or what you push down against. With the new mount location.. I needed a new spot to push down agains. Fortunately I was able to use the original handlebar assembly mount locations to bolt in another bar. [a piece of pipe with a piece of threaded rod]
    So rad!! looks like it came like that from factory.
    Great idea. ..Hope the company will learn from hardcore field testors!
    Were starting to see a good amount of solutions here! Thank you all!
  4. #204
    Dec 2017
    Ok geniuses , another thing with the dog; strong, but too light to pull u up a steep climb in deep light snow :-D
    We were lucky enough to get nice dumps lately in Quebec (+-50cm of fluff). Best powder skiing in last couple years. In many cases I hade to step off to unweight the sled otherwise it was sinking in snow. Then realized if I get my weight on the dog it became possible to go forward again.
    What do you think of an attachment distributing body weight on the midpoint of the snowdog? Was thinking of some kind of bike hack with fork in the dog and rear wheel replaced by a cut down snowboard. Dog tracks better heavier rather than dragging weight.
  5. #205
    Quote Originally Posted by radair View Post
    I prepare my sketchiest off camber sections on snowshoes using a grain shovel. It is pretty quick and easy to do a little cut and fill with a shovel. Moving snow is far easier than digging dirt and IME can last all season.
    Put some dry lube on your rollers the next time you pull the clutch off. I had the same problem and it was bone dry in there. Thereís a good YouTube link earlier in this thread about servicing these clutches.
    I have dry lubed them a couple times now. The service manual actually calls for grease. I greased the locations listed in the service manual the last time I had it apart and I have rode it for about 30 minutes with success so far but I have had dry lube last this long as well.
    Something else to watch out for is the hitch. Mine has become quite loose. They are only using rivnuts to secure the hitch to the frame. Doesn't look like I was too far away from having to walk out of the woods. Which is what I would have had to do if it failed. Planning on drilling the rivnuts out and running two bolts all the way through the frame and adding lock nuts.
    The handle-bar relocation idea seems like it would work really well.
    In regards to traction up a hill. It is all about getting that first groom done. I am finding that with the second groom the track is able to bite into the base and pull up the hill with relative ease.
  6. #206
    Dec 2017
    Fenlason: Thank you for sharing those pictures. They explain it all so easily. I'm preparing to modify my bar setup as well since my back can't stand fighting the machine with the deep soft snow we've gotten.
    I was going to groom today but think I will weld up stuff for the snow dog instead since it was -17 when I woke up!
    +1 for having to walk next to the snow dog up hills in deep powder. At least until the first pass is finished.
    My kids and their friends were bummed I couldn't tow 3 sleds in a train up the sled hill since the snow was too soft. At least they were getting rides up one at a time!
    Thanks for sharing tips everyone. If I find something that works I'll be sure to share.
  7. #207
    Oct 2011
    cool to hear about all the mods and such. I am waiting on a new belt (ordered a few since they seem to be hard to come by locally)... I've learned to make the first pass up hill with the clutch side of the machine facing uphill.. for some reason that seems to work... certainly for deep snow anything over a foot, often have to walk next to it, but subsequent passes usually no problem... I added about 6 inches to each side of the handle bar, simply by shoving rebar in and then covering that with ample tape for grips. the wider bar does allow for a bit more leverage when trying to convince the machine where you want it to go at times. overall, I am very happy with it... I have to get myself comfortable with cleaning the clutch... that's the next step.
  8. #208
    beer thief
    Reputation: radair's Avatar
    Dec 2002
    I try to set initial tracks downhill whenever possible. Sometimes "skateboarding" (pushing off with one foot) is enough to handle uphills; rarely do I have to get off to push. Snow is so variable - dry powder is tough to find traction and there are no big paddles on these tracks.
    Attached Thumbnails Attached Thumbnails Best Tracksled Grooming Experience?-lower-shumway-12-2017-medium-.jpg
  9. #209
    I have been perfecting the skateboarding technique as well! That is one heck of a picture! Some great looking winter singletrack.
  10. #210
    Jun 2010
    I have uphills from our start, there is no way around it. So the skateboard kick is utilized here also. I works and I don't really mind it. Snowdog has a rail suspension available that is supposed to substantially help with deep snow performance. I am going to give it a try. I have it on order. They say it is available now... but I haven't seen it yet.
  11. #211
    Oct 2011
    regarding snowdog...I went through my last belt, guessing that the 20 inches of snow and working it a bit too hard did her in....I have watched the youtube video of disassembling and cleaning the clutch..... but wanted to ask here,,,, anything I should watch out for.... is this a DIY type of thing.... or are there special tools and skills needed...
  12. #212
    beer thief
    Dec 2002
    Quote Originally Posted by twright205 View Post
    It's easy enough getting the clutch off the machine; just one bolt on the outside IIRC. From there you need a decent (but not too big) bench vise to hold the base of the drive clutch while you loosen the retaining nut. My vices were not the right size so I ended up buying one with 4" wide jaws - it needs to fit inside the circumference of the clutch base. Once you get the top nut loosened up it's all quite simple. I should have taken a few photos, sorry!
    Where did you get the belts? Were they breaking? The alignment of the primary to secondary drives is not very good, so that has to contribute to it.
    Edit - I tried attaching the CVT drive clutch manual but the file is too big. If anyone wants it, PM me your email address.
  13. #213
    Oct 2011
    radair- thanks for the advice and info.. I've had the snowdog for over a year. probably over 30 hours run time... burned up the belt.. I was being to hard on it... a friend ordered one on ebay but don't think it was a true gates. and within 30 min. it totall delaminated. top strip off, all the threads like spagetti.... but also I was told ( i didn't know) that the clutch surface needs to be quite clean, or else will get belt burn or they will wear out quick...
    link below, racingplanetusa.com is where I found the one that came with the snowdog
    Drive Belt Gates Powerlink Premium CVT 918-22.5-18 | Scooter Parts | Racing Planet USA |
  14. #214
    beer thief
    Dec 2002
    I took my homegrown groomer out yesterday (shown in post #116 of this thread, page 2). I did 3.5 miles in 40 minutes just before sunset in an attempt to smooth out the dents and divots from the bare booters (and deer). It handled really well in the tight twisty stuff and did a decent job cleaning things up. We rode it this morning and the fine corduroy was really good - it was especially obvious when going from touched up to raw trail that I didn't have time to hit. More snow due tomorrow so another round begins...
    Attached Thumbnails Attached Thumbnails Best Tracksled Grooming Experience?-corduroy-1-3-18-medium-.jpg
  15. #215
    Jun 2012
    Radair - nice looking unit. How did you attach the grate and the angle at the front to the wood blocking below? The draw bar, is that 2" by 2" stock?
  16. #216
    beer thief
    Dec 2002
    Quote Originally Posted by wgerow View Post
    Hi Warren - there's some photos on page 2 of this thread, posts #114 & 115 and attached here. The Grip Strut is welded to the angle top & bottom and the 2x6 blocks are screwed on through the bottom flanges of the Grip Strut and bolted to the angle. Yes, that's a 2" square tube steel connecting arm with a funky extension that allows the eye bolt to swivel. I took the angle steel skegs off for the soft conditions we have currently.
    This is definitely a finish sled, not for use in fresh snow. The stock sled works quite well in fresh pow.
    Attached Thumbnails Attached Thumbnails Best Tracksled Grooming Experience?-grooming-sled-hitch-final-medium-.jpg
  17. #217
    Jun 2012
    Cool thanks......grip strut looks to be 20"x20"?
    What are you guys using to scarify hard snow, anything? or you just plowing the duff off once you establish a hard tread?
  18. #218
    beer thief
    Dec 2002
    Platform is 2' x 2', which worked perfectly with two of the Yellowstone Track System 12" combs.
    No scarification, I've just been running more passes with the sled as we get more snow. Today's storm with high winds should make for a challenging effort over the weekend!
    I can look to see what I have for scrap around but may not be in CV for a while.
  19. #219
    Oct 2011
    the sled or stand on groomer that I have is the same width of the 20 inch Snowdog track. so unless there are really deep footprints, the track itself chews up the marks, and then the sled or platform lays it back down... I just ordered the snowcomb. to help make the groomed surface uniform and freeze back up quicker.. something about more surface area I guess. it we get a lot of foot traffic, will have to dream up some blades to run to help deal with those.
  20. #220
    Sep 2017
    POV video
    Here is a video of grooming singletracks with the Snowdog and two axis groomer hitch. Note how easy the off-camber section is...
    https://m.facebook.com/story.php?sto...id=78510558785
  21. #221
    Jun 2010
    Awesome! Thanks... I am sold!
  22. #222
    Dec 2017
    Thanks for the inspiration Knucklehead6. I'm welding stuff up these next few days with some scrap steel and some new bar stock. If I was a better fabricator I'd be done already!
  23. #223
    Oct 2011
    here is a short video of my attempt to rework a pull behind groomer that I had for my Alpine.. to make it a sit on roller groomer for the snowdog... only tested around the house.. hope to get it to the trails sometime this week. ugly yes.. but might work..
    https://youtu.be/_oCmRwAVJKs
  24. #224
    Dec 2017
    I just made a bumper/snow deflector today and tested it tonight in some powdery snow. I made it to help push some snow to the side of the snowdog instead of having it bury itself in powder. Obviously it only works when starting off on a solid surface but for re-grooming a trail after a big storm it seems to have worked well. Now I need to take some pictures and share them. It's basically a curved 2.5" strip of industrial plastic that mounts to the frame at track axle height.
  25. #225
    My clutch problems appear to be fixed after using grease on the primary. I drilled through the riv nuts that were used for the hitch and put bolts straight through the frame. I did hit a good sized rock while grooming and not sure if that is the reason but the frame where the hitch is mounted is now starting to bend. Going to leave it for now and see if it gets worse before deciding if I will reinforce it or not. Off-camber is killing me on this thing. Have resorted to flipping the handlebars back on to the machine and standing in front of it while operating the throttle. Sounds like a bad idea but it does help a lot.
  26. #226
    Jun 2012
    A little grooming action by one of our guys today....still using the sled, but thanks to radair we are in the process of building a copy-cat version of his drag.
    https://www.instagram.com/p/BdtOhbTh...ken-by=crnemba
  27. #227
    Dec 2017
    Hello wgerow,
    Nice snowdog up there in Sugarloaf ME. I'm in Windham and am grooming down here. We should share drag build ideas and tips for what works.
    Here's something that worked pretty well here. I built a front bumper/plow for the deep powdery snow we got here. It actually helps push some snow away from the track and keeps it from digging in as much.
    Best Tracksled Grooming Experience?-img_1192.jpgBest Tracksled Grooming Experience?-img_1193.jpgBest Tracksled Grooming Experience?-img_1194.jpg
  28. #228
    Jun 2012
    Quote Originally Posted by surlyobs View Post
    Hello wgerow,
ID:	1177225Click image for larger version.
ID:	1177226Click image for larger version.
    Cool idea, good to know.
    I actually work in Falmouth, where are you grooming at?
    Thus far I haven't done any of the grooming up in CV, just trying to help those guys out getting a drag of sorts together.....something to tinker with at least.
  29. #229
    Dec 2017
    SnowDog mods
    Because my bikes are never "stock" and I can't help but try to make things better, I've made some changes to my SnowDog even though I've only owned it about 18 days...
    #1 Goodbye cold hands: I was going to add some pogies but I'm constantly removing my hands from the grips to maneuver and adjust things. The stock grips are cold and hard so I ditched them and replaced them with ESI chunky silicone foam grips. They do not transmit cold and are nice and cushy. I also insulated the throttle lever since at least one finger is always on it. A little foam and hockey tape fixed that.
    #2 I adjusted the bars: The stock setup was in the middle hole of the frame. I moved the bar pivot to the lower hole and it helped a bit. I also moved the levers and control box inwards on the bar (the control box is pinned into the bar so it doesn't rotate. You will need to re-drill the bar)
    Finally, I added some old school bike bar-ends for more torque on the handlebars.
    #3 I made a bumper/snow pusher: I thought that adding some device for getting snow away from the groomer and compactor would make things easier for packing in the trail and also easier on the snowdog. Turns out it did help.
    #4 Storage: Those hip packs that were the rage in the 1990's? They work great on the back of a snowdog. I've got spare fuel, dry and warm clothes and other things like stuff for trimming tree branches that get in the way.
    #5 Fabbing up a low pivot swing arm: I'm in the process of copying some other users ideas to build a swing arm that allows the snowdog to be steered by leaning. I can't wait to try that one out. Not done yet, but I have some photos of progress. (the rusty steel was scrap that I am re-using) After I get the bugs worked out I'll paint it.
    Attached Thumbnails Attached Thumbnails Best Tracksled Grooming Experience?-img_1102.jpg
  30. #230
    Oct 2014
    Hello wgerow,
    Yeah, where are you grooming in Windham? Lots of people down here would love to know.
  31. #231
    Dec 2017
    Mdlman,
    I've been out grooming trails almost every day since Dec. 20th. I've groomed Clifford Park in Biddeford, a few personal trails in my Windham area (single track, not snowmobile width) and also behind Congin School in Westbrook. I'm currently waiting to hear back from Gorham trails and some other places about letting me groom their trails. I'm available for hire if anyone is looking for single track grooming.
    NEAT & Tidy Trail Grooming
    Send a PM to: Mike G.
  32. #232
    Oct 2014
    Mdlman,
    Thatís amazing! So great youíre doing that on your own. The Congin trails are super fun in the summer, sounds awesome in the winter. Thatís a big bonus, lots of people winter ride Sunset Ridge snow mo just past Congin, makes a great connection.
    The dream single track groom would be to get the Sebago to Sea from the Westbrook side back to Forest Ave / Dunkins, then River 2 from Corsettiís on the north side of the Presumpscot all the way to Falmouth. Those are lost connections in the winter for sure. River 2 bridges are in bad shape though, might be tricky getting a valuable machine through there safely.
    But if you had those connections you could ride the river trails out of Portland all the way to Congin, then up the sno mo to Prides and all the way to Blackstrap. Mega!
  33. #233
    For FB users, I started a group. Might be good to host some of this information there.
    SnowDog Users Group
    Mark.
  34. #234
    Great idea on the user group on Facebook, request sent!
    Jason
    Disclaimer: www.paramountsports.net
  35. #235
    Oct 2011
    surlyops---let me know how that front bumper goes. with the differing conditions the other night, it seems if the Snowdog got into too deep of wet snow it was trying to plow through... and a lot of packing buildup a few feet infront of the machine... granted, temps were too warm to really be out there ... but some kind of cow catcher, bumper, or for deep snow something to move it to the side a bit intrigues me.
  36. #236
    I've been trying to stay in the -5F to 25F window for grooming. What temps do you groom in? I've never had packing/buildup issues.
    Jason
  37. #237
    Oct 2011
    we were getting a warm up, and then a freeze, so was trying to groom in less than ideal conditions. the first 16 inches from the ground up was chaulky unpackable dry snow. the top 4 inches were wet snow... not a good combination, going along previous packed areas not bad... but I got greedy and tried to get some more that we have not yet groomed... so I was thinking about some kind of snow "pushbar" for those instances..
  38. #238
    Dec 2017
    Quote Originally Posted by Knucklehead61 View Post
    No way! Get back to your shop and start mass producing that off camber demon for us!
  39. #239
    Here are some shots of the two axis hitch that i designed for the Snowdog.
    It attaches to the mid-point of the frame using the existing bolts. It pivots in the X axis at this point. At the rear of the "U" shaped bar is an attachment point that moves only in the "Y" axis and is connected with a 3/4" pin. I have tossed around the idea of producing these if there was enough demand..
    Hey KnuckleHead61, could you post a parts list when you get a chance? Things like the bushings or bearings used for the U-bar to tracksled joint and maybe tubing size and thickness. A few more shots of the drag would be awesome as well, maybe what the bottom looks like.
    Tedsti
    Minnesota Off Road Cyclists www.morcmtb.org
  40. #240
    beer thief
    Dec 2002
    Quote Originally Posted by tedsti View Post
    Tedsti
    Go to post #175 in this thread (page 2). Click on the photo and a pdf with some fab details will pop up.
  41. #241
    Reputation: BlueCheesehead's Avatar
    This video highlights a whole range of groomers. Pretty cool.
    https://gearjunkie.com/fat-bike-trai...te-michigan-up
  42. #242
    I received a letter today from my dealer, looks like the state (MI) has decided to treat Snow Dogs as an ORV/ATV. This means that all ATV/ORV rules apply including trail permit stickers (first-year can be reimbursed). This decision is extremely frustrating.
  43. #243
    Dec 2017
    Quote Originally Posted by woodsbiker View Post
    Like it or not sounds like it meet's there criteria no different than a Snotucker grooming snowmobile trails requires a permit.
    "ORV" means any motor vehicle designed for or capable of cross-country travel on or immediately over land, water, sand, snow, ice, marsh, swampland, or other natural terrain.
    ORV vehicles include, but are not limited to, a multi-track or multi-wheel drive vehicle; an ATV; a motorcycle or related 2-wheel, 3-wheel, or 4-wheel vehicle; an amphibious machine; or other means of transportation deriving power from a source other than muscle or wind.
    Blaine, Mn
  44. #244
    Oct 2011
    hmm, troubling... hoping my State doesn't head that way.... so would a self propelled wheelbarrow, mower, garden tractor, excavator ??? just typing out loud...
    we have permission from Land manager to use atv, mini ex, tractor, and skid steer... so I think we are good, but this development is something to watch.
  45. #245
    Dec 2017
    Think it would come down to when a state permit is required when on private property vs state, federal, county property.
    Blaine, Mn
  46. #246
    Exemption maybe for trail grooming equipment? Is it in fact a vehicle if you walk/snowshoe/ski behind it? I know standing on the sled behind it is preferred.
  47. #247
    Looking through the Michigan ORV handbook, it seems clear they are not talking about grooming equipment. It could be argued that the purpose of a groomer is not as a vehicle, but rather as a tool to improve the trail. There is a specific exemption for agricultural equipment, could one argue that a groomer is similar in function to a rototiller or lawn tractor?
    This seems to be a grey area. The intent of operating the equipment is not in and of itself for "recreation", but rather to "work the land" by improving the snow on top of it.
    I would think a respectful discussion with a DNR officier would at worst result in a warning. This equipment is so rare that they would be confused by it too and not know what to do.
    Just my hunch, no legal background here.
    All that said, looking at the Snow Dog website, they market it as a vehicle to get you from here to there. In that case I can see why they are considering it an ORV. Pay the $26 or 36/year and be on your way.
  48. #248
    Feb 2018
    New here but going to chime in on this. Our club in nh just got a snodog and ran into similar reg. Issues....we ended up registering it as a "groomer", being that is the sole purpose of its ownership.
    Any other clubs in your area using one, and what r they doing?
    Good luck
    Sent from my SM-G950U using Tapatalk
  49. #249
    beater
    Reputation: evasive's Avatar
    Feb 2005
    So a few of us took this around for a rip this afternoon. It was a demo on mostly flat ground in a city park, but with an eye towards potentially using it on singletrack in the future.
    Electric tracksled made by Lockwood Electric in Seeley Lake, Montana. 18 HP.
    We liked it. Thereís a definite learning curve, and it takes some commitment. Speed is your friend. The builder says he prefers a sled to a plate, because he has more options, and commonly rides with a knee on the seat or both feet in one side of the sled. It has a very low center of gravity, and the electric motor just rips when you open it up. It has a 20:1 and makes about 10 mph. I definitely wouldnít want it to be faster on single track.
    This one is owned by MTB Missoula. He makes them to order. It has ~1500 hours and has never been serviced, and never needed to be dug out. Hard to imagine how it would get stuck. Itís all drive.
  50. #250
    Quote Originally Posted by evasive View Post
    That thing is wild! Any idea how heavy it is and how long the battery lasts?
  51. #251
    beater
    Feb 2005
    Itís not light. I rolled it on its side a few times while getting the feel for it. Batteries and an electric motor are pretty dense, but that was an intentional part of the design. Youíd be better off loading it with a ramp than lifting it.
    He said it has a functional life of about 4 hours in deep snow and hills. Where they use it, they commonly have really deep powder, and it just goes. Recharges overnight (6-8 hours).
  52. #252
    Dec 2017
    The lower CG of the electric looks interesting.
    https://www.youtube.com/watch?v=zNw4u49MWT0
    Blaine, Mn
  53. #253
    beater
    Feb 2005
    Quote Originally Posted by Iffykid View Post
    It'd be interesting to see a video of the experienced operators using it now. They're much more dynamic than in the first test runs, and stand up more frequently. For his next tracksled, he intends to have an adjustable height handlebar so that it's easier to muscle it when you're standing.
  54. #254
    Picked up a Snow Dog grooming plate. I will be sticking to our homemade plate though for all but deep snow conditions. Which we have not had this winter. The paint is not durable and the metal is thin so I don't think it would hold up well to low snow abuse.
    It is different then Snow Dog shows on their site and different from the pictures they posted here. It does not have runners on the bottom but instead has edges on both sides. The comb also stretches the entire length. The arm is pretty long and may need to be shortened if you want to stand closer to the bars. It came with the extensions to make it wider but I am loving the 20" width we have been using. Pretty pricey piece of metal, but not many people are making something for fat bikes yet so hats off to them.
  55. #255
    Jun 2010
    Woodsbiker... I just picked up Snowdog's groomer this morning. Mine has a runner at each segment. Mine is as they show it on their website.. excepting mine has a toothed section the whole width of the drag. I found my hitch a little long also, although had altered the mounting position of the bars assembly on my sled.
  56. #256
    Feb 2018
    The other day I drug a wooden pallet down my snowmobile trail to a creek to make a pallet bridge and was surprised by how well it smooth out the trail. After reading through this thread I dug out some old, full size truck tires I had lying around and tied them together in tandem with some rope. The past two days Iíve drug them behind my snowmobile and packed down my trail. I was pleased by how well they worked and liked that if they swung and hit anything they just bounce off. The setup cost me nothing and I was surprised by how easily they towed. Iím thinking of adding a third tire in tandem just to see if the trail gets even better.
  57. #257
    Oct 2013
    Quote Originally Posted by Snowfat View Post
    the problem with tires is they tend to sway, and when the bounce of trees, that's where your sending riders. They also blow off on off-camber sections. We use a rokon and drag a tire, but I am working on building a track with runners on the bottom, so it tracks in line with the rokon. Trust me, the tire thing will get old after awhile.
  58. #258
    Feb 2018
    Yeah, I can definitely see what you are saying about the sway but Iím thinking that has more to do with the rigging of the tow set up more than anything else. But thatís just me hypothesizing on the couch with an iPad so Iíll have to do some real world experimenting. I think the ideal groomer set up would be some type of tracked snowbike. Not the current kits that convert dirt bikes but something lower, slower and more utilitarian. Off cambers would be much easier to negotiate with such a set up and having the front, single ski inline with the track would help to pack things down quicker and better. Have it tow something to smooth out the track footprint and I think it would be perfect.
  59. #259
    beer thief
    Dec 2002
    Snowdog - not just for grooming. It did an awesome job skidding lumber for a bridge replacement.
  60. #260
    beer thief
    Dec 2002
    I also made this little texture drag that i hook on the back of the sled. It does NOT pack anything, just leaves a nice corduroy finish. It's made of a 2" square tube tongue pulling a 4" channel with a 2x4 tapered to fit, which holds the YTS combs.
    This machine is so versatile!
    Attached Thumbnails Attached Thumbnails Best Tracksled Grooming Experience?-img_0471-medium-.jpg
  1. Grooming for fatbikes
    By zaab70 in forum Trail Building and Advocacy
    Last Post: 01-26-2017, 09:15 PM
  2. Grooming snow
    By D.F.L. in forum Fat bikes
    Last Post: 10-18-2016, 12:07 PM
  3. Fat-Bike.com Trail Grooming Series
    By JordyB in forum Fat bikes
    Last Post: 02-23-2015, 12:06 PM
  4. Corduroy grooming
    By Welnic in forum Fat bikes
    Last Post: 02-08-2014, 12:03 PM
  5. Duthie Trail Grooming
    By AlpineE30M52 in forum Washington
    Last Post: 07-19-2011, 03:17 PM
Members who have read this thread: 215
