Results 1 to 34 of 34
Thread: Best rear tire?
    Reputation: backcountryeti's Avatar
    Best rear tire?
    In the market for a new rear tire to replace the aging Endomorph, and since I am new to the fat bike game I am open to suggestions. I am thinking a Nate to pair with Larry in the front, but what are the thoughts on the Husker Du for the rear? Anyone running a Knard 26?
    This is on a Pugs by the way. Thanks in advance!
    Smash Mode: ON
    Reputation: Dustin Mustangs's Avatar
    Best for what?
    Whatever floats your bike, dude
    Reputation: Schott's Avatar
    Nov 2012
    Best rear tire?
    If you aren't going to be running a lot of snow time, I would pass on the Nate. Awesome tire, but noisy and slow. I just put a Husker du on the back for the dirt season and really like it so far. If you can swallow the price for the lightweight ones, do it.
    surly and rigid
    Nate for rocks and mud.
    nvphatty
    Guest
    the kind that never flats.
    Reputation: BoogieMang's Avatar
    Mar 2011
    Quote Originally Posted by nvphatty View Post
    In other words, any tire that you can run tubeless?
    nvphatty
    Guest
    Quote Originally Posted by BoogieMang View Post
    i wouldn't step out that far..
    Nov 2012
    On-One Floaters are 1/2 the price of the 120 tpi Surly tires. I don't think that they can be beat for price/performance right now.
    nvphatty
    Guest
    grass
    I guess I should have been more specific... What would be the best trail tire? I am using the Pugs as my normal, everyday MTB.
    Reputation: BurkeVT's Avatar
    Jul 2003
    I actually love the Nate/Nate combo for trail. It simply hooks up, and will be your best, no-compromise gripper for more aggressive trail use.
    (That said, I'd love to try out a Husker out back for a improved rolling performance.)
    No matter what, I suggest replacing the Larry in front with a Nate. It will change your whole outlook on fat trail riding.
    -Chris
    Reputation: smithcreek's Avatar
    Nov 2012
    I run Nate/Nate. I have a Knard that I have used on the back. If the trails are bone dry it works fine but when they are even damp the Knard has a lot less traction over roots and rocks (which we have lots of). For me it's worth it to just keep the Nate on full time.
    All fat, all the time.
    Reputation: Shark's Avatar
    Feb 2006
    On the trail, I'm very happy with the Hudu. Set it up tubeless & forget about it.
    Best compromise between grip and rolling resistance I've found. The price lately stinks though. love to see em back down to $80 like the first pair I bought.
    Feb 2012
    Knard vs Nate, the Knard is significantly faster.
    The Knard is able to run at lower pressures to make up the loss of grip and still take less effort to move, when pumped up firm (15-18lb) the Knard rolls very easily on hard pack and road. The Nate never rolls very easily, it grips too well even firm.
    If you climb alot and do less smooth rolling trails, then Nate is still the best. So far though this spring my Knard is on the back and not coming off yet. Nate can wait till the winter.
    Reputation: mochunk's Avatar
    Quote Originally Posted by roobydoo View Post
    I can say with the few trail outings I've had, and a bunch of pavement commuting, so much this... The knard is a nice smooth fast tire on the back that still climbs respectively well. Better than Endo I think.
    However, it seems to have one weird drawback. It has a squirm and sort of self steer when squished significantly. At lower pressures or in the saddle over a bump and it squirms to a side if you're leaned over at all. Which on our trails is pretty much always. The lower the pressure, the worse it gets. Anything under about 9psi for me. I am about 240lbs right now though... Anyone else notice this? I remember reading somewhere someone had this issue and tightened their skewer and it went away, no such luck for me.
    I have my reservations about using it as a front tire, for some reason. Still larry for right now.
    Fatbike Chicago on Facebook
    Quote Originally Posted by mochunk View Post
    You don't get that with the larry? All of them have self-steer at way low pressures to some extent. Nature of the beast. Larry isn't too bad, but I do notice it, especially on hard surfaces, down around 5 psi (I'm about 170). Big Larry even more so.
    Oh noes. I'm going to drink the Kool-Aid.
    Quote Originally Posted by jcaino View Post
    I've never had anything but Endo in the rear. I never noticed it with that. I have a habit of crawling over parking stops in my lot when I'm bored or waiting for my GF to come out for a ride, and I immediately noticed it on an angle with the Knard. Never felt that with the Endo. It's pretty pronounced, like it squishes and you counter steer sharply for a split second. It just feels weird is all.
    I've only ever run Larry and BFL up front.
    Nov 2012
    Best rear tire?
    I just switched from a bud front/Nate back to a Larry front/hudu back. Honestly, so far I am as equally unimpressed with the Larry up front on the dirt as I was on the snow. I think I may have been spoiled with the bud up front, but the Larry just isn't doing it for me. We finally have had some rain, so I am going to go out and ride some wet roots and rocks this morning, but I have a feeling the decision has been made already. I think I'll be putting the Husker du on front, and putting the Nate back on the rear. Anybody want to buy a slightly used Larry?
    Nov 2012
    Best rear tire?
    Sold.
    Reputation: SteveF's Avatar
    Put a HuskerDu mounted backward on the rear of my Mukluk last winter and it's pretty great. No more side slide on cross-slope sections like the stock Endo, and real good climbing traction in snow. Next year might put one on front too-price per tire of these makes one per season budget-manageable if barely!
    Dec 2011
    I use my Pugsley as my everyday mtb also and I've been through alot of tire combinations. I am now running Nate front and Knard rear. I like the HuskerDu as a rear but it wore out way to fast, less than 800 miles. The Nate front give great traction and so far so good with the Knard. Nate is 8psi and Knard is 9psi.
    Laramie, Wyoming
    Reputation: alphazz's Avatar
    Oct 2012
    Quote Originally Posted by boogiemang View Post
    in other words, any tire that you can run tubeless? :d
    yep.
    nvphatty
    Guest
    yep.
    negative
    Mar 2011
    I don't have experience with anything other than Larry, Endo, Bud and a HuDu on my Pugsley. Right now, I'm running Bud front and HuDu rear, and the setup works really well in hardpark/loose over hardpack trail conditions. Bud is a killer all-around front tire. I'll echo the comments above about the HuDu wearing out fast... Mine isn't toast yet, but after a year of all season use, the knobs have noticeably worn down. There have also been lots of reports here of HuDu's getting punctured by large sticks. I'll probably go with a Knard or Nate out back next, or perhaps Knard for summer and Nate for winter use, unless I get a Moonlander and can run a Lou year round
    Nov 2012
    Best rear tire?
    negative
    Really though, if you aren't running tubeless, you're just missing the boat. The ride is better, you don't get pinch flats, I don't really have to worry about punctures much here...not to mention it weighs less...and just generally makes you cooler. Takes a little more time to set up, but not compared to fat flats on the side of the trail.
    Laramie, Wyoming
    Oct 2012
    Quote Originally Posted by Schott View Post
    +1, but I guess some aren't bothered with flats while riding.
    dvn
    dvn is offline
    Reputation: dvn's Avatar
    Quote Originally Posted by JoeG View Post
    +1
    nvphatty
    Guest
    I beg to differ, i don't get pinch flats and it may weigh a couple OZ's less at best but then all i need do is insert a toob, add air and its up, i need not mess with split toobs as a liner, foam this or that, valve stems, layers of duct when a toob simply works the way its designed to for centuries.
    Nov 2012
    Best rear tire?
    The first bike tires came around in the late 1800s, so slightly better than a century, at best. :-) . I don't think that you will find a tubeless rider that says a tube doesn't work. It has, it will. An abacus still works, too...but there are now things that work better.
    But the difference lies in that I (we) ENJOY tinkering with our bikes. I see where you are coming from though. My brother gets strung out trying to change a tube. Basic maintenance is beyond him. He doesn't enjoy it, he doesn't do it. I would never even try to convince him to deal with a tubeless setup, especially on a fatbike.
    If you enjoy playing with your bike, setting it up tubeless is a blast. There are many ways to go about it. Read them all, and then figure out your own way. Then, enjoy the many benefits.
    Reputation: vaultbrad's Avatar
    Oct 2007
    Has anybody tried the Vee 8 tire? I think thats what it's called. Looks like it could be a fun tire.
    Nov 2012
    vaultbrad
    AFAIK, they're not available to buy yet.
    These guys got some to test, though.
    Vee Rubber Vee8 ? Spiderman Grip for Your Fat-Bike ? BBRTP Report | FAT-BIKE.COM
  1. Burly rear tire suggestions - light DH tire?
    By TwoHeadsBrewing in forum Wheels and Tires
    Last Post: 07-20-2012, 01:33 PM
  2. Enduro rear tire recs (Specialized tire)?
    By jgusta in forum All Mountain
    Last Post: 07-10-2012, 03:10 PM
  3. Front tire and rear tire size comparison question help?
    By Yellowr6 in forum General Discussion
    Last Post: 02-21-2012, 05:50 PM
  4. Front tire and rear tire size comparison question help?
    By Yellowr6 in forum Wheels and Tires
    Last Post: 01-26-2012, 12:54 AM
  5. WFO Rear Tire Rub
    By agentorangemen in forum Niner Bikes
    Last Post: 07-16-2011, 08:40 AM
