Page 3 of 4 FirstFirst 1 2 3 4 LastLast
Results 51 to 75 of 78
  1. #51
    gone walk about
    Reputation: nvphatty's Avatar
    Mar 2012
    Quote Originally Posted by AC/BC View Post
    Strip of raw hide.
    They sell raw hide by the pound at Axe Man (CHEAP)
    Use scissors to cut them accordantly. wipsh!
    does it come in a rainbow of colors though??
  2. #52
    Dirt Huffer
    Reputation: AC/BC's Avatar
    Quote Originally Posted by nvphatty View Post
    You can dye rawhide or paint it just like shoe leather.
  3. #53
    gone walk about
    Mar 2012
    yippy tie yai aye!!
  4. #54
    Feb 2013
    On a derailleur bike, does the entire stay need to be wrapped, or does just the top of the stay need to be protected?
    I'm wondering if the bottom of the stay ever gets slapped, since the rear derailleur puts that part of the chain further away.
    I'm thinking about cutting up a tire, but then what about that plastic electrical wire tubing stuff? On the back of server cabinets, they'll combine cabling in this tubular sheath, for organization, and then zip-tie it shut. It's plastic, but the ridges could act like shock absorbers and should flex enough to protect the frame, but I guess it wouldn't be air/water tight and muck could get in there.
  5. #55
    gone walk about
    Mar 2012
    Quote Originally Posted by Trilancing View Post
    Personal preference really as the top has the most potential to get chain rub etc it would be wise to atleast cover it.
  6. #56
    If you get "chain suck" you will need protection on the side of the chainstay and sometimes also the bottom side.
  7. #57
    Jan 2013
    Scotch 2228 tape thicker than inner tubes and once wraped its there for good.....
    Home Depot/Lowes 9 bucks
    I LOVE ORANGE keep them coming, if I wanted to change I would have done it 50-60 years ago....
  8. #58
    Nov 2012
    Scotch 2228
    +1
  9. #59
    Oct 2013
    So I'm thinking that I dye up some rawhide to look like bacon. That's gonna fix it.
    Jake
  10. #60
    Reputation: OFFcourse's Avatar
    It amazes me how fugly some people manage to make an inner tube look on a chainstay.
  11. #61
    have seen this cable wrap on many mtb's
    Cable Wrap from Estco Enterprises
    dave
    spez roubaix
    fantom cross - stolen -
    crux
    moonlander
  12. #62
    turtles make me hot
    Reputation: NYrr496's Avatar
    After I finish trimming the excess tube between the tire and rim while doing ghetto tubless, I use the 1" strip on the chainstay. Looks awesome.
    I like turtles
  13. #63
    Reputation: Bearhunter's Avatar
    Mar 2014
    Best chainstay protection?
    I am using rubber splicing tape. You can pick it up at any hardware store.
  14. #64
    Quote Originally Posted by Bearhunter View Post
    I have also used "self vulcanizing" tape instead of the typical "mister tuffy" on certain ones of my bikes it works really well with square or sharp edges since it conforms to them quite easily.
  15. #65
    Mar 2014
    Yeah I like it a lot. On separate note, I really like what you did to your 9zero7.
  16. #66
    Thanks here is one more of the Orange's on my WTB Phoenix, sadly I have not found anymore of that color and shape in many years of searching, Tuffy's suck anyway as tire puncture protection..
  17. #67
    Moderator Moderator
    Reputation: mtbxplorer's Avatar
    Dec 2009
    My LBS did a lovely inner tube wrap when they built the bike, but it got weird and fuzzy, I think from salt water.
  18. #68
    Reputation: digidelia's Avatar
    Oct 2011
    a little off topic, but can you post shots/info of your rear rack setup? i'm in the market for one for my fatboy. thanks!
  19. #69
    Mar 2014
    Quote Originally Posted by digidelia View Post
    Here you go, I did this a few days ago.
    OMM Phat Rack & Specialized Fatboy
    Since that posting I have been talking with Channing from OMM and he will be refining the "fatboy rack package". He is aware that the Fatboy requires larger band clamps (if using the alternate method of mounting as described in the thread linked above).
    I also have some mud shovels enroute, and the plan is to mount them between the tire and rack. OMM siad they would send larger lower brackets if the rack needs to be raised to accomodate.
  20. #70
    Quote Originally Posted by bjfalken View Post
    just as good as singlespeed is Sram Type 2. and to a lesser extent, Shimano Shadow Plus. seriously, i don't know why there aren't any clutch deraileurs on here ever
    This, treat the cause not the symptom.
  21. #71
    Reputation: ADKMTNBIKER's Avatar
    Nov 2014
    I just used some old clear, vinyl tubing I had laying around. I don't have a camera right now, but will post a pic. in a couple of days.
  22. #72
    Reputation: blockphi's Avatar
    Mar 2012
    I go bare. I don't trust a biker whose bike is immaculate. Paint chips and scrapes, mismatched wheels, saddles patched with duct tape, grips that are worn smooth - these are what I expect to see on a bike. Not pristine paint and shiny parts.
    Or get a clutch der to keep the chain from slapping to begin with as others have said.
  23. #73
    May 2010
    I've always just used an old tube as the base layer, then a quick wrap with hockey tape. Easy and cheap.
  24. #74
    Mar 2011
    Here's another vote for the scotch brand thick electrical tape. Stretches nicely so it applies exceptionally well as the chain stay diameter changes. Also is thick so it absorbs impacts well. I did the entire chain stay on the drive side and a few inches on the non drive side where my heel sometimes hits. A few months in and it still looks like I just installed it.
  25. #75
    The good ole grip tape cs protector...cleanliness ftw...
    Get fAt, Stay fAt, Ride fAt
    Doctor recommended...
