• 12-13-2012
    buckfiddious
    Best bang-for-the-buck upgrade?
    Say you've got 3-500 bucks to spend on upgrades for a pugsley. Say you've already replaced everything but the front derailleur, the wheels and tires, and the fork.
    Do you go with better/lighter tires? Never had a problem with the stock tires, but some of the new tire options do look pretty sweet...
    Lighter wheels/rims? A set of Marge lites would be pretty nice.
    Carver O'beast fork? Because carbon.
    Or is there something I've missed?
    Drivetrain is pretty much where I want it, bars, shifters, brake levers, saddle, post, etc, all good. Thought about upgrading to hydraulic brakes but can't see any major benefit.
  • 12-13-2012
    nvphatty
    rims/tires would be my choice.:thumbsup:
  • 12-13-2012
    Morej
    +1 on this one. :thumbsup:
  • 12-13-2012
    Jaredbe
    Although tires would be the most noticeable I think long term going to Rolling D. rim's is the way. Let the best tire for your needs rise to the top of the new heap of choices while you get the rim's now.
  • 12-13-2012
    AC/BC
    Rims and tires are the only things worth upgrading. The fork isn't going to make you any faster.
  • 12-13-2012
    Rabies010
    Maybe go with a IGH ?
  • 12-13-2012
    coldbike
    Number 1 for me would be going to lighter and/or wider rims. Holy Rolling Ds are what i put on my Pugsley, but my heart belongs to the 100mm rims.
    Number 2 would be tires. Although i don't hate the endomorphs or larry's like some folks do, i like other tires better. On my pugsley i had big fat larrys but if it had an Alfine 8 speed so it cleared the wider tires.
    Number 3 would be an alfine hub. I really like the alfine when things get slushy or salty.
  • 12-13-2012
    buckfiddious
    IGH is right out. I like my drivetrain the way it is.
    My goals are mostly lighter weight without any loss of strength- I still want to be able to ride singletrack in the summer...
  • 12-13-2012
    bobkorn
    If you are still running Large Marge's you will be amazed when you switch to Marge Lites. Best place to put your money and lose weight.
  • 12-13-2012
    caminoloco
    Depends on your use of the bike. It could be anything from a GPS to a dropper seatpost. Probably wheels though, which ones depends...
  • 12-13-2012
    BjornS
    If you're running DH thick n'stable tubes, you might save a few grams by switching to lighter tubes. Bontragers from Fatbikes.com for example.
    Or carbon seat post and a carbon bar to give more comfort?
    Bj
  • 12-13-2012
    cozz
    best and cheapest is to drill your rims
  • 12-13-2012
    buckfiddious
    'cept there's no way I could get nearly as light drilling out a pair of stock LM-DH rims as I could replacing them with marge lites...
    Looks like rims is the way to go, followed by tires.
  • 12-13-2012
    boogman
    Is there even a market for the stock large marge wheel set? I wonder what the cost differential would be upgrading to marge kites after selling the LMs
  • 12-13-2012
    Bugeye
    I've been wondering same thing for my Muk 3. I don't have Buck's budget at the moment, but am considering drilling my RD's and installing DH tubes. Based on what I've read on MTBR threads, as well as using tube weights published on fatbikes.com, I figure:
    Drilling RD's: saves roughly 150 grams/wheel = 300g
    Switching to Bonti DH tubes: saves about 160/wheel = 320g
    total savings = about 1.4lbs rolling weight
    1) Does this sound right?
    2) I've not tried DH tubes...if I run my Muk at between 7-10 psi with standard fat tubes, will the DH tubes serve me well? (e.g. sufficient size to hold my weight?...I'm 210 or so).
  • 12-13-2012
    ozzybmx
    Hopefully the spokes are still the right length it could be an easy swap to Marge Lites, if not they are only $80 from jenson's for Revo's.
    BTW Jenson price matched the cheapest price for Marge lites i could find at the time at $136us.
    Going this way and even possibly with lighter spokes will save the the most weight in the best place possible.
  • 12-13-2012
    Nothing's impossible
    Put your bucks in a sock untill you now what you want???
    Marge lites are nice, but if it's for trail riding the 47 mm trial tech rims might be better?
    But maybe you need more float? or a 29'er set??
    You might profit more from a front suspension? A seat dropper, other brakes,..
    In 2 years time bud and lou on 100 mm rims might seem tiny, and you'll want to go 32" and 6" wide, but you spended your budget on a few upgrades on your old bike!
  • 12-13-2012
    buckfiddious
    I'm totally happy with the width of the large marge rims- they seem like a really good balance for what I do with the bike. I just want the bike to weigh less.
    Have had no need for a front suspension, seat dropper or brakes. THe trails around me aren't that vertical.
    I pretty much know what i want- a lighter pugsley. That's why I'm looking at trying to get rid of weight. Lighter wheels, fork and tires are about all that's left for me to lighten up. Doubt it will make earth-shatteringly huge differences in the way the bike rides, but that's OK because I like the way my pugsley rides. Just wish it was a few pounds less.
  • 12-13-2012
    montana_ben
    Hey Buck, for what it's worth, the weight difference between my winter wheelset (stock Mukluk wheelset w/holy rolling darryls, salsa hubs, 27tpi nates, tubeless) and my summer wheelset (marge lites, ultralight nate/husker du, hope hubs, dt supercomp spokes) is almost 3.5lbs. The only problem I can see is realistically getting there for $500 even lacing them up yourself (I did), all those parts add up in a hurry. Maybe with some dedicated deal searching you could get close but might have to skip the hubs/spokes...
  • 12-13-2012
    buckfiddious
    Totally understand- figure I can re-rim my current wheels or build up a new set for 3-500 depending on the quality of hubs I can find at the swap in january, then get new tires next spring when they'll make a difference- the stock tire combo is heavy, but it's not bad.
    I kinda figured I could do one thing- fork, tires or rims, but only one.
  • 12-13-2012
    vmaxx4
    I think one of the best upgrades for your dollar is the cassette. Not many people talk about this. I think I saved close to a pound of rotating mass when I swapped out the "boat anchor" of a cassette that came stock on my Mukluk 2. :)
  • 12-13-2012
    nvphatty
    what came stock and what was the replacement?
  • 12-13-2012
    Velobike
    Lighter tubes and holey rims. Get a hacksaw and cut off the surplus on your seatpost - anything more than the minimum insertion is surplus. Foam grips instead of lockons. So far, cost next to nothing, and major weight saving.
    Next lighter tyres.
    Then lots of money on shiny bits because they look nice and save 10 grams all up.
    Rest to be spent on a barrel of beer.... :)
    Oh, and you can save another 40gms by bonding your seatpost into place and dumping the seatclamp. :thumbsup:
  • 12-13-2012
    smthgfshy
    the best bang for buck weight savings if I had $500.....and your bike...
    #1 - buy carver fork ($300) sell old fork ($50) = 250
    #2 - sell old rims ($100) buy marge lites ($300) = 50
    #3 - buy ashima rotors ($50) = 0
  • 12-13-2012
    Ze_Zaskar
    Best bang for the buck? Easy, lighter tubes
  • 12-13-2012
    vmaxx4
    Shimano HG-50 9-Speed 11-34T is what Salsa lists it at. I think it is about 450 g. I put on a Sram PG 990 which is about 300 g. Close to 1/2 pound I guess. Sure feels like a lot more when your holding them. Still for $55 dollars a good weight savings.
  • 12-13-2012
    nvphatty
    Shimano HG-50 9-Speed 11-34T is what Salsa lists it at. I think it is about 450 g. I put on a Sram PG 990 which is about 300 G. Close to 1/2 pound I guess. Sure feels like a lot more when your holding them. Still for $55 dollars a good weight savings.
    yup thats a worthy change.
  • 12-13-2012
    boogman
    How do you get a pair of marge lites laced for $300
    I am on the same quest.. Just bought new platform pedals.. 350g for the new pair to replace my old 520g pair of pedals
  • 12-13-2012
    Shark
    $ for $, best upgrade for me was switching to husker dus from Larry endo combo. Next was squishy forth.
  • 12-13-2012
    lawfarm
    120TPI Husker Dus, tubeless.
    With rims if you can swing it--Marge Lites or Holy Rolling Darryls.
  • 12-13-2012
    ozzybmx
    You probably wont if you get other people to build your wheels unless you call in a favour with a mate.
    I would say going by comments on other threads theres quite a few of us here build our own wheels. That costs a few hours of your time but zero $$ and = a whole lot of self satisfaction :thumbsup:
    Theres a warm and fuzzy feeling about building your first set of wheels... after that its just a given that you will be building your own from then on in.
  • 12-13-2012
    buckfiddious
    C'mon guys, I'm not a moeron.
    Tubes, replaced. Cassette? cast iron monstrosity replaced with a Ti XTR cassette. xt shadow derailleur. Carbon seatpost, WTB silverado saddle. Boat anchor crank replaced with a much lighter race face crank. Big ring replaced with a lightweight bashguard. horrible deore shifters replaced with super awesome pauls thumbies. Bars, replaced and cut down to fit through trees.Stem, replaced with something lighter.
    I've gotten all the easy stuff.
  • 12-13-2012
    roobydoo
    I've done it all, Lighter tubes, Carver fork, Lighter rims w/ light gauge spokes and lighter hubs.
    Even with heavy tubes and heavy wheels I punctured the tires, surprisingly enough light tubes and light tires have had less punctures!
    By far the lighter complete wheel had the most effect, I ran the same HuDu on the heavier wheel and the difference is remarkable. I never had the front end lift up like it does now. My front wheel built up is 1000g, All in, including HuDu tire was close to your target amount, it's not a cheap fix.
    If you have the skills, smthngfishy's suggestion involving buying and selling and tearing apart old wheels to build new ones seems to be the only way to spread the dough around effectively.
  • 12-13-2012
    roobydoo
    double post - error 505`s
  • 12-13-2012
    roobydoo
    I hesitate on the Ashima rotors, too aggressive on most brake pads. Magura Storm SL would be a safer option
    Only downside is it assumes you have the skills, or a friend who can do it for free.
  • 12-13-2012
    Turtle01
    From my experience and swapping wheelsets from the Large Marges to the Marges Lites, that would be my vote.
    For good pricing on complete wheels, check out AEBike.com:
    Shop for bicycle parts and accessories - AEBike.com
  • 12-13-2012
    smthgfshy
    [QUOTE=boogman;9968556]How do you get a pair of marge lites laced for $300
    lace'em yourself or call in a favor to a friend.
    with that plan, assuming he's got a stock pugsley fork, stock undrilled RD's, and something equivalent to Avid g3's, he'll save somewhere right around 3 pounds. He could also drill them himself, and put the $300towards an E-13 crank which would bring his savings close to 3.5lbs.
  • 12-13-2012
    boogman
    How come i always see laced up rear wheels for sale more often than fronts?
  • 12-14-2012
    Velobike
    Originally Posted by buckfiddious View Post
    ...I've gotten all the easy stuff.
    Then dare I suggest a bit of the harder stuff?
    Singlespeed it. :)
    The biggest improvement you can make to the feel of just about any bike IMO.
    However as a singlespeed rider of longstanding, I actually advocate having gears on a fatbike. This is because if you gear it for the sort of tricky stuff you can ride fat on, you'd be spinning madly to get there on normal trails.
    Setting up as a dinglespeed or tringlespeed may be a light method of having some gearing available though.
  • 12-14-2012
    Smallfurry
    So glad to read this. I'm a single speeder at heart. But have planned a 1x10 drivetrain for my fatbike. As delivery of the frame approachs I find myself with this gut feeling to build it up SS to start with. Basically to get the feel of the bike before I confuse myself with gears. Think maybe I should let my head rule my heart on this one.
    :eek:
  • 12-14-2012
    ozzybmx
    I'll not have been riding SS as long as you but i rode mine constantly for about 3yrs before getting a fatbike (still ride it), depending on where you live and what you ride also, i agree that gears are great fun on a fatty, i can clear techy sections that i wouldnt be able to if i had one gear. Set up as 1 x 10 is good enough, i have a 30t HBC on the front and 10 at the back, so my highest is 30:11 and lowest 30:36 and im hardly in the lowest unless in riding up steps or something silly steep.
  • 12-14-2012
    Smallfurry
    Interesting. Im looking to run 31(also HBC) : 11-36.
    My SS 29er is amazing if you dont need to cycle asphalt for too long. Then spinning the long cranks gets annoying.
  • 12-14-2012
    buckfiddious
    Singlespeed it. :)
    I tried a singlespeed, it just wasn't for me. I really wanted to love it but ended up just cursing it constantly. I gots much respect for anyone who can singlespeed but for me it's not to be.
    I've thought about just running a granny ring up front but I use the middle ring enough to keep 2 rings in the front.
  • 12-14-2012
    Turtle01
    I'm guessing it's because QBP distribution is the widest of the fatties, and up until recently for them the Pugsley offset fork was their mainstay. Soooo, two rear wheels :yesnod:
  • 12-14-2012
    drofluf
    Singlespeed it. :)
    Totally agree. My 29er is perfect as a singlespeed and the Pugsley a lot of fun over the summer as a singlespeed but I've just put an Aline 8 on it and it's made a world of difference! Because I can stay seated I can get far more traction on the climbs and the higher gears mean I'm fast on the flats.
  • 12-14-2012
    smthgfshy
    Wait a second....back the bus up....you're running a 2x setup??
    run 1x9/10 for sure....lots of options to suit your style. there goes another pound at least.....
  • 12-15-2012
    Leopold Porkstacker
    For me, it was the tires. More specifically, replacing the Larry/Endomorph combo with a Nate/Nate combo. Monumental buttloads of traction now, I am on my fourth set of Nates and love them very much.
  • 12-15-2012
    nvphatty
    having used 4 sets would you say the rubber compond is soft compared to others??
  • 12-15-2012
    Leopold Porkstacker
    Yes, and I have come to the conclusion that perhaps Surly/QBP ought to offer a harder compound version, maybe call it the Hard Nate or something whimsical along those lines. Iím not sure if there is enough interest in them going to the trouble though.
    At $90/tire (for the 27tpi versionóhaving tried the $150 lightweight versions I did not notice any stellar performance improvements) Iíd like to think I can get the same number of miles as on high-end (high-dollar as well) 29er race tires, but those last longer than the Nates. Iíve managed between 300 - 500 miles per set of Nates, bike (2012 aluminum 9:zero:7) is ridden on rocky/loose/technical singletrack and fire roads, as well as muddy/mucky stuff and perhaps 13% of the miles on asphalt.
  • 12-15-2012
    nvphatty
    sadly not many miles under those conditions. Would the Knard work for these conditions as an option?
  • 12-15-2012
    Leopold Porkstacker
    For me, the confidence is placed in the 6mm deep tread lugs of the Nates, as I am usually hitting the off-camber loose/gravelly stuff at speed and rely on the tires (especially the front) hooking up. Having not tried the Knards, I have no way to compare them to the Nates in the same conditions. My only comparison fatbike-wise would be the Larrys, of which there simply is no comparison. Iíd love to be able to try out the Bud/Lou combo, but they wonít fit on my current setup.
