Page 2 of 3 FirstFirst 1 2 3 LastLast
Results 26 to 50 of 51
  1. #26
    Reputation: vmaxx4's Avatar
    Quote Originally Posted by nvphatty View Post
    what came stock and what was the replacement?
    Shimano HG-50 9-Speed 11-34T is what Salsa lists it at. I think it is about 450 g. I put on a Sram PG 990 which is about 300 g. Close to 1/2 pound I guess. Sure feels like a lot more when your holding them. Still for $55 dollars a good weight savings.
    2010 Intense Spider 2
    2010 Ibis Tranny SS
    2012 Salsa Mukluk 2
    2013 Salsa Spearfish 1
    2013 Trek Domane 5.2
    2014 Hakkalugi
  2. #27
    gone walk about
    Reputation: nvphatty's Avatar
    Mar 2012
    Quote Originally Posted by vmaxx4 View Post
    Shimano HG-50 9-Speed 11-34T is what Salsa lists it at. I think it is about 450 g. I put on a Sram PG 990 which is about 300 G. Close to 1/2 pound I guess. Sure feels like a lot more when your holding them. Still for $55 dollars a good weight savings.
    yup thats a worthy change.
  3. #28
    May 2012
    Quote Originally Posted by smthgfshy View Post
    the best bang for buck weight savings if I had $500.....and your bike...
    #1 - buy carver fork ($300) sell old fork ($50) = 250
    #2 - sell old rims ($100) buy marge lites ($300) = 50
    #3 - buy ashima rotors ($50) = 0
    How do you get a pair of marge lites laced for $300
    I am on the same quest.. Just bought new platform pedals.. 350g for the new pair to replace my old 520g pair of pedals
  4. #29
    All fat, all the time.
    Reputation: Shark's Avatar
    Feb 2006
    $ for $, best upgrade for me was switching to husker dus from Larry endo combo. Next was squishy forth.
  5. #30
    May 2010
    120TPI Husker Dus, tubeless.
    With rims if you can swing it--Marge Lites or Holy Rolling Darryls.
  6. #31
    Fat & Single
    Reputation: ozzybmx's Avatar
    Quote Originally Posted by boogman View Post
    You probably wont if you get other people to build your wheels unless you call in a favour with a mate.
    I would say going by comments on other threads theres quite a few of us here build our own wheels. That costs a few hours of your time but zero $$ and = a whole lot of self satisfaction
    Theres a warm and fuzzy feeling about building your first set of wheels... after that its just a given that you will be building your own from then on in.
    Trek 9.9 Superfly SL
    Ti O'Beast
    Fatty
    FM190 Fatty
    Indy Fab Deluxe 29
    Pivot Vault CX
    BH G6 Roadie
  7. #32
    Reputation: buckfiddious's Avatar
    Quote Originally Posted by Ze_Zaskar View Post
    Best bang for the buck? Easy, lighter tubes
    C'mon guys, I'm not a moeron.
    Tubes, replaced. Cassette? cast iron monstrosity replaced with a Ti XTR cassette. xt shadow derailleur. Carbon seatpost, WTB silverado saddle. Boat anchor crank replaced with a much lighter race face crank. Big ring replaced with a lightweight bashguard. horrible deore shifters replaced with super awesome pauls thumbies. Bars, replaced and cut down to fit through trees.Stem, replaced with something lighter.
    I've gotten all the easy stuff.
  8. #33
    Feb 2012
    I've done it all, Lighter tubes, Carver fork, Lighter rims w/ light gauge spokes and lighter hubs.
    Even with heavy tubes and heavy wheels I punctured the tires, surprisingly enough light tubes and light tires have had less punctures!
    By far the lighter complete wheel had the most effect, I ran the same HuDu on the heavier wheel and the difference is remarkable. I never had the front end lift up like it does now. My front wheel built up is 1000g, All in, including HuDu tire was close to your target amount, it's not a cheap fix.
    If you have the skills, smthngfishy's suggestion involving buying and selling and tearing apart old wheels to build new ones seems to be the only way to spread the dough around effectively.
  9. #34
    Feb 2012
    double post - error 505`s
  10. #35
    Feb 2012
    I hesitate on the Ashima rotors, too aggressive on most brake pads. Magura Storm SL would be a safer option
    Only downside is it assumes you have the skills, or a friend who can do it for free.
  11. #36
    From my experience and swapping wheelsets from the Large Marges to the Marges Lites, that would be my vote.
    For good pricing on complete wheels, check out AEBike.com:
    Shop for bicycle parts and accessories - AEBike.com
  12. #37
    Reputation: smthgfshy's Avatar
    [QUOTE=boogman;9968556]How do you get a pair of marge lites laced for $300
    lace'em yourself or call in a favor to a friend.
    with that plan, assuming he's got a stock pugsley fork, stock undrilled RD's, and something equivalent to Avid g3's, he'll save somewhere right around 3 pounds. He could also drill them himself, and put the $300towards an E-13 crank which would bring his savings close to 3.5lbs.
  13. #38
    May 2012
    Quote Originally Posted by Turtle01 View Post
    How come i always see laced up rear wheels for sale more often than fronts?
  14. #39
    Reputation: Velobike's Avatar
    Quote Originally Posted by buckfiddious View Post
    ...I've gotten all the easy stuff.
    Then dare I suggest a bit of the harder stuff?
    Singlespeed it.
    The biggest improvement you can make to the feel of just about any bike IMO.
    However as a singlespeed rider of longstanding, I actually advocate having gears on a fatbike. This is because if you gear it for the sort of tricky stuff you can ride fat on, you'd be spinning madly to get there on normal trails.
    Setting up as a dinglespeed or tringlespeed may be a light method of having some gearing available though.
    Latitude: 57ļ36' Highlands, Scotland
  15. #40
    Reputation: Smallfurry's Avatar
    Quote Originally Posted by Velobike View Post
    So glad to read this. I'm a single speeder at heart. But have planned a 1x10 drivetrain for my fatbike. As delivery of the frame approachs I find myself with this gut feeling to build it up SS to start with. Basically to get the feel of the bike before I confuse myself with gears. Think maybe I should let my head rule my heart on this one.
    A big boy did it, and ran away.
    62*28'
  16. #41
    Fat & Single
    I'll not have been riding SS as long as you but i rode mine constantly for about 3yrs before getting a fatbike (still ride it), depending on where you live and what you ride also, i agree that gears are great fun on a fatty, i can clear techy sections that i wouldnt be able to if i had one gear. Set up as 1 x 10 is good enough, i have a 30t HBC on the front and 10 at the back, so my highest is 30:11 and lowest 30:36 and im hardly in the lowest unless in riding up steps or something silly steep.
    Ti O'Beast
    Fatty
    FM190 Fatty
    Indy Fab Deluxe 29
    Pivot Vault CX
    BH G6 Roadie
  17. #42
    Quote Originally Posted by ozzybmx View Post
    Interesting. Im looking to run 31(also HBC) : 11-36.
    My SS 29er is amazing if you dont need to cycle asphalt for too long. Then spinning the long cranks gets annoying.
    62*28'
  18. #43
    Singlespeed it.
    I tried a singlespeed, it just wasn't for me. I really wanted to love it but ended up just cursing it constantly. I gots much respect for anyone who can singlespeed but for me it's not to be.
    I've thought about just running a granny ring up front but I use the middle ring enough to keep 2 rings in the front.
  19. #44
    I'm guessing it's because QBP distribution is the widest of the fatties, and up until recently for them the Pugsley offset fork was their mainstay. Soooo, two rear wheels
  20. #45
    Reputation: drofluf's Avatar
    Dec 2010
    Singlespeed it.
    Totally agree. My 29er is perfect as a singlespeed and the Pugsley a lot of fun over the summer as a singlespeed but I've just put an Aline 8 on it and it's made a world of difference! Because I can stay seated I can get far more traction on the climbs and the higher gears mean I'm fast on the flats.
    If you need me I'll be at the bar
  21. #46
    Wait a second....back the bus up....you're running a 2x setup??
    run 1x9/10 for sure....lots of options to suit your style. there goes another pound at least.....
  22. #47
    PRETENDURO
    For me, it was the tires. More specifically, replacing the Larry/Endomorph combo with a Nate/Nate combo. Monumental buttloads of traction now, I am on my fourth set of Nates and love them very much.
    QUOTE from MTBR.COM: You have given Brewtality too much Reputation in the last 24 hours, try again later.
  23. #48
    gone walk about
    Mar 2012
    Quote Originally Posted by Leopold Porkstacker View Post
    having used 4 sets would you say the rubber compond is soft compared to others??
  24. #49
    PRETENDURO
    Yes, and I have come to the conclusion that perhaps Surly/QBP ought to offer a harder compound version, maybe call it the Hard Nate or something whimsical along those lines. Iím not sure if there is enough interest in them going to the trouble though.
    At $90/tire (for the 27tpi versionóhaving tried the $150 lightweight versions I did not notice any stellar performance improvements) Iíd like to think I can get the same number of miles as on high-end (high-dollar as well) 29er race tires, but those last longer than the Nates. Iíve managed between 300 - 500 miles per set of Nates, bike (2012 aluminum 9:zero:7) is ridden on rocky/loose/technical singletrack and fire roads, as well as muddy/mucky stuff and perhaps 13% of the miles on asphalt.
  25. #50
    gone walk about
    Mar 2012
    sadly not many miles under those conditions. Would the Knard work for these conditions as an option?
