Results 1 to 6 of 6
    Reputation: Nitatunarabe's Avatar
    Bashring bonks (?) for Moonlander
    I've lost three of four bonks (not sure, whether it is a correct name for them) from the bashring of my Moonlander?
    Here are some pictures:
    Detailed view:
    Does anyone know, where I can buy them?
    Please, sorry for my English. It's not my native language.
    Reputation: BoogieMang's Avatar
    Mar 2011
    Call Surly and buy a tube of loctite
    I've emailed them about a week ago. No answer.
    Aren't those chainring bolts? I reckon you can try your local shop. I remember on a bike when I switched to 1x9 I had to get BMX chainring bolts from my LBS for the new front ring. So apparently there are different sizes.
    '15 Specialized Fatboy
    '14 Kona Zone Two
    '13 Surly Big Dummy
    Reputation: Schott's Avatar
    Nov 2012
    Yup, chainring bolts. LBS, you may have trouble finding the spacer. Surly shouldn't be bothered for such mundane things. I don't blame them for not replying.
    Dr Gadget is IN
    Reputation: wadester's Avatar
    That looks like a normal chainring bolt for double rings - with a spacer so you can run a single.
    For that purpose, I looooove these:
    Truvativ Steel Chainring Bolts
    Set of 5 steel chainring bolts. 5mm hex bolt and 6mm hex nut. 8.5mm nut length. Washer for single chainring. Exclude washer for use with double chainrings. Black.
    I especially like that you tighten them with 2 hex keys, and can actually get them tight.
    This isn't a "you're doing it wrong" topic.
    WSS/OSS: Open Source Sealant
  1. Replies: 9
    Last Post: 06-04-2013, 10:26 PM
  2. Replies: 12
    Last Post: 09-12-2012, 05:49 PM
  3. Replies: 2
    Last Post: 03-26-2012, 02:10 AM
  4. '07 RIP9 Chainring clearance, bashring recs?
    By Kristatos in forum Niner Bikes
    Last Post: 09-23-2011, 01:22 PM
  5. MRP XCG vs a Bashring.
    By Tinier in forum All Mountain
    Last Post: 05-11-2011, 07:43 AM
