Page 3 of 5 FirstFirst 12345 LastLast
Results 201 to 300 of 403
  1. #201
    Reputation: blekenbleu's Avatar
    Aug 2016
    No Malus
    Quote Originally Posted by Rhino81 View Post
    So I'm gonna pull the trigger on the argus sport from nashbar.
    I would have considered a Malus, if it had an alloy frame.
    Motivation for maintaining a bike with rusting frame is hard to find.
    Mongoose is just a name. Pacific/Dorel make tons of bikes;
    some are great values; some are great bikes; others are neither.
    This thread is a corollary to The fat bike bubble has burst
    in that fat bikes are largely about tires, and it takes a Pacific to generate volumes that excite tire manufacturers to develop good cheap fat tires.
  2. #202
    Aug 2016
    Quote Originally Posted by Lovespicyfood View Post
    Nashbar has a 25% coupon
    Amazon's 2015 large Argus is now $590..
  3. #203
    Jun 2016
    Tho talking to local bike shops they speak very lowly of mongoose(Walfart bikes)
    You can't really cast the Wallmart Mongoose bikes in the same light as the "real" Mongoose bikes.
    Just like you can't compare the crappy "Gourmet Line" of Wusthof kitchen knives on Amazon with real Wusthof knives (especially when the Gourmet ones start to rust).
    Mongoose sells many bike models that cost thousands of dollars in retail shops.
    Look at their 2016 dealer catalog to see how much higher end stuff they make; and you won't see any of it at Wallmart:
    https://issuu.com/alexandrpanasovsky/docs/mongoose_2016
  4. #204
    Aug 2016
    Quote Originally Posted by vid1900 View Post
    Expert/Comp rear brake hose apparantly runs along down tube front; that seems unnecessarily vulnerable.
  5. #205
    Jun 2016
  6. #206
    Sep 2016
    Yeah I didn't reallize till I started researching mongoose was owned by a parent company that made other higher end bikes and they had separated the mongoose brand into a store brand and non store brand. Which I think has done wonders for creation of a higher end bike at still a good price point for people like me.
    An comparing store bought items to non store bought has no comparison in a lot of items we as consumers buy. So I agree that trying to compare the one to the other is like apples to oranges.
  7. #207
    Jun 2016
    Quote Originally Posted by blekenbleu View Post
    The line does run off to one side, but you could reroute it if you wanted to.
    Attached Thumbnails Attached Thumbnails Argus:  A fat bike for the masses? Review & Assembly-argus-expert-line.jpg
  8. #208
    Aug 2016
    2015 small Argus bigger than 2016?
    small standover should be about 1/2 inch lower than medium
    2016 catalog lists different Argus seat tube lengths than BikeAndRide.cz;
    2016 small top tube should be about 1/2 inch lower than medium at head tube and 1 1/4 lower at seat tube.
  9. #209
    Jun 2016
    Exactly.
    The volume that Mongoose sells allows us to have a bike like the Argus Expert for even less money than a company like BikesDirect sells a comparable one for.
    So if the Dolomite is the gateway drug of the fatbike world, let the public keep buying them up....
  10. #210
    Aug 2016
    horses for courses
    Been wanting a fat bike for awhile but not sure
    I apologize for not addressing an implicit question.
    Specifically, 100mm rims are one key Argus attribute,
    and those wider rims increase flotation and support, along with wider forks and stays, even wider tires appropriate for traditional fat tire bike environments: snow, mud and sand.
    However, many riders, perhaps including you, are now more involved in curb and rock hopping and/or downhill root riding, for whom wider rims can be disadvantageous: more vulnerable to damage and, particularly with wire bead tires, reducing shock absorbtion.
    80mm and narrower rims can be more suitable for those riders, making e.g. Nashbar's proprietary fat tire bike or one of Bikesdirect's offerings a better recommendation, IMO.
  11. #211
    Jun 2016
    If you want an Argus with narrower rims, get the 2015 Argus (under $500 when on sale):
    https://www.amazon.com/Mongoose-Argu...mongoose&psc=1
  12. #212
    Aug 2016
    Per the mongoose website the 2015 bike has 93mm rims so thats not exactly narrow.
  13. #213
    Jun 2016
    Quote Originally Posted by Jd10ac View Post
    Looking at both bikes side by side, the Argus 2016 look much wider than the Argus 2015.
    I did not measure the 2015, but the 2016 is 101mm on the calipers.
  14. #214
    Interesting, thank you for all the info! I sure like that blue on the '15 and it seems to be a bit better spec'd. Wish I could ride a small as that is under $500 right now. According to Camelcamelcamel the medium I need only went down to $583 which was not too long ago...
  15. #215
    Aug 2016
    bye, gone tinkling
    Tinkling is still audible. I'm beginning to suspect brake pads.
    Unlike BB7s to which I will upgrade,
    stock calipers lack pad spring-loading.
    Stock calipers were magnetic, but evidently not enough.
    Tinkling disappeared after replacing rear caliper.
    Similar sound from BB7-updated front wheel when cornering
    seems more likely attributable to spokes.
  16. #216
    Aug 2016
    Took both my bikes out for a little ride today and even though they both have the same size tires one sure does require a lot less effort to ride.
    Attached Thumbnails Attached Thumbnails Argus:  A fat bike for the masses? Review & Assembly-20160911_160814.jpg
    Argus:  A fat bike for the masses? Review & Assembly-20160911_160829.jpg
  17. #217
    Sep 2016
    Man, so detailed! thanks for this! I just got the next model up Argus (SLX, Deore, Sram Crank, Tektro Hydros). Amazon had it for $688 (crazy one time deal, it is back up to $999 now) and I guess Performance is trying to get into the online bike service game b/c they offered FREE shipping/assembly/tuning when the bike is sent to their store closest to you. Of course, they try to sell you a service plan but I didn't bite. I WILL, however, follow your recommendations. Again, great job! I was back and forth about the size but I am glad I went with the MED. I did need to get an aftermarket 400mm seatpost but the standover and top tube were perfect for a 5'11" 32" inseam guy.
  18. #218
    Aug 2016
    widths
    I wonder whether Expert/Comp rims (more comparable to 2015) measure the same.
    FWIW, chainstay width measures ~131mm @ widest sidewall,
    while forks measure ~ 136mm. Seatstays measure ~141mm.
    In other words, not ideal for Snowshoe 2XL tires.
  19. #219
    Aug 2016
    Quote Originally Posted by chepato View Post
    Mongoose recently cut a deal for Amazon to handle online 2017 sales, while Mongoose/Pacific handle customer service.
    Mongoose?s new bikes for 2017 ? the Tyax Supa plus bike, Argus 24 mini fat bike, Teocali and more - Mtbr.com
    A resonable move, with many US bike shops avoiding Mongoose and shopper whines about higher than Walmart prices.
  20. #220
    Jun 2016
    It may be cheaper for Mongoose to pay shops to assemble the bikes, rather than have end-users quickly kill them by riding on too tight bearing cones, or rubbing brakes.
    Around here, a bike costs about $100 for full prep and assembly.
    Mongoose might be paying $50 to the shop, and the shop gets a new customer (Who will probably want a more comfortable saddle, a rear rack, a helmet.....). If a LBS really makes it appear that they are "full service", "experts", and "bending over backwards", they could earn a customer for life.
    Win/win
  21. #221
    Mar 2011
    argus expert
    Here are a few photo's of my Expert, still in winter mode. I wouldn't recommend these tires for summer use
    up front
    thru axle front and rear, Saint brakes, Mulefut rims, custom rim stip, Dunderbeist rear tire. not stock
    That purple!
    shreddy ready
    Mongoose product development
  22. #222
    Jun 2016
    Quote Originally Posted by skota23 View Post
    Great looking shop, and I like those rim strips!
  23. #223
    Sep 2016
    Man that argus expert looks awesome!
  24. #224
    Sep 2016
    To me, it depends on costs and benefits.
    twice
    True, and i considered an Expert for Bluto, but am comfortable with QR for rear hub and hope 15x150mm front hubs will drop from current $80 or so.
    It's unclear >>for me, beach riding<< how much better is Bluto than would be an ebay $100 fat squish fork, and it seems that a Wren may turn out to be cheaper and better,
    except heavier, than Bluto,
    so my total personalized Sport cost could be somewhat lower than for a personalized Expert, even if some components (specifically juice brakes, BB and rear hub, about which I personally care less) are not so nice.
    At any rate, I am more comfortable with costs for incremental improvements,
    which are also learning experiences.
    Other than thru axle provision and tapered head tubes,
    Sport frames appear similar to Comp/Expert.
    At 41 pounds, a heavier fork for my Sport is not so attractive now;
    with fewer tourists trampling sand, speeding along the beach with a rigid fork is less jolting.
    You don't happen to have a link to any of the fat squish forks from eBay that work with the argus sport model? For $100 to upgrade to a squish fork, I might be tempted for the dirt road riding which has plenty of whooped whoops!
  25. #225
    Jun 2016
    This one looks correct AFAICT, but double check your measurement.
    ....and with 16GB storage capacity, how can you go wrong?
    fat tire bike fork snow bike fork spread 135mm suspension fork 26 steerer 255mm
    Attached Thumbnails Attached Thumbnails Argus:  A fat bike for the masses? Review &amp; Assembly-pasak.jpg
    Argus:  A fat bike for the masses? Review &amp; Assembly-zzz.jpg
  26. #226
    Sep 2016
    Haha yeah I'm sold with 16gb of storage that is impressive!
  27. #227
    Aug 2016
    don't try this at home
    No guarantees; may require a hub change to replace QR axle with thru:
    Snow Beach Sand Fork 4 0 Fat Mountain Bike Electric Suspension Cruiser 135 150mm | eBay
  28. #228
    Sep 2016
    Thanks guys for info
  29. #229
    up front
    That purple!
    shreddy ready
    When will we see that for sale in the US? I keep suggesting that bike and see its sold out.
    ƃuoɹʍ llɐ ʇno əɯɐɔ ʇɐɥʇ
  30. #230
    Jun 2016
    Quote Originally Posted by bitflogger View Post
    It's in stock, in all 3 sizes at Nashbar right now.
    Mongoose Argus Expert Fat Bike
    Every few weeks Nashbar will have their 25% off everything sale, making it $1199
    Today, Nashbar has a 23% off sale, so it's $1231 <<<--- don't pay it, unless you have $31 to toss away!
  31. #231
    I meant the Mongoose direct site and the black bike I'm the 2017 catalog.
    Thank you.
  32. #232
    Jun 2016
    Thank you.
    Right now, you would probably have to go to your local Mongoose dealer, because I have not seen them at any online retailer.
    Same as the Argus Competition; no USA online shops ever picked it up.
    Attached Thumbnails Attached Thumbnails Argus:  A fat bike for the masses? Review &amp; Assembly-zzzgoose.jpg
  33. #233
    Mar 2011
    Not sure when the 2017 bikes will be in stock, I'm pretty sure we are going to be only selling bikes on Amazon for 2017.
  34. #234
    Perfect. You probably know who I am and why I ask! Let's get organized on that for our next "global fat bike day".
    Thx.
  35. #235
    Aug 2016
    I'd feel worse about salting and sanding a bike that pretty and pricey.
    Folks may toss that $31 at another saddle;
    Mongoose could consider some deal with e.g. WTB;
    customers could select both frame and saddle sizes..
    The ~ Army green 2016 Sport has more off-road vibe,
    but I expect that 2017 Sport in red finish will sell really well.
  36. #236
    Aug 2016
    rear rack
    This rack fits well, seems sturdy and is relatively inexpensive:
    Bicycle Carrier Rear Luggage Rack Bracket Aluminum for Disc Brake V Brake Bike | eBay
    It was cheaper from Amazon in early August, but is currently unavailable
    https://www.amazon.com/gp/product/B01F8RZF2W
    Brazeon mounts space braces out further than necessary,
    but arguable help protect rear brake and derailleur.
    Splash board is presumably less effective than a dedicated rear fender.
    Spring-loaded clamp is less flexible than bungee cords.
  37. #237
    Jun 2016
    Argus Expert
    Here is the Argus Expert unboxing:
    Argus:  A fat bike for the masses? Review &amp; Assembly-1.jpg
    Specs:
    • BRAKES Hayes Radar Comp hydraulic disc w/ 180mm rotors front/rear
    • LEVERS Hayes Radar Comp hHydraulic
    • BOTTOM BRACKET FSA MegaExo
    • CASSETTE Shimano HG50 10-speed, 11-36T
    • CHAIN KMC X10 10-speed with EPT anti-rust coating
    • CRANKSET FSA Comet with Mega Tooth 38/24T chainrings
    • FORK Rock Shox Bluto Solo Air RL, 120mm travel, 15x150mm thru-axle
    • Headset: VP-J203PE
    • STEM 3D forged aluminum, 35mm clamp diameter
    • FRAME Mongoose MTB aluminum fat tire hardtail
    • FRONT DERAILLEUR Shimano SLX M676 direct mount
    • GRIPS- Mongoose
    • HANDLEBAR Double-butted aluminum, 35mm clamp diameter, 760mm width
    • PEDALS Alloy platform w/replaceable studs
    • REAR DERAILLEUR Shimano XT RD-786 10-speed
    • SEATPOST Aluminum 31.6mm x 350mm
    • SHIFTERS Shimano Deore M618 2x10-speed
    • TIRES Kenda Juggernaut 26x4.5 Gumwall
    • WHEELSET Rims: 26" aluminum, 32 hole, 100mm wide with cutouts; Hubs: Alloy disc, 32 hole, Front=150mm thru-axle, Rear=190mm thru-axle; Spokes: Stainless steel
    SIZES S M L
    Large Size Measurements:
    Where Seat Tube meets Top Tube: 30.25"
    Where balls hit Top Tube if you slip from seat: 31.5"
    Where Top Tube meets Head Tube: 38.25"
  38. #238
    Jun 2016
    One tight bundle + a goodie box.
    Attached Thumbnails Attached Thumbnails Argus:  A fat bike for the masses? Review &amp; Assembly-2.jpg
  39. #239
    May 2015
    Love those tires... can't seem to find them anywhere.
  40. #240
    Jun 2016
    4.5" Gumwall tires look badass on a Fatbike.
    Rims are Anodized; a more durable finish than paint:
    Attached Thumbnails Attached Thumbnails Argus:  A fat bike for the masses? Review &amp; Assembly-3.jpg
  41. #241
    Jun 2016
    For shipping, the Stem is installed upsidedown.
    Every pic of this bike on the web shows final assembly with it still installed upsidedown, I don't know why.
    Attached Thumbnails Attached Thumbnails Argus:  A fat bike for the masses? Review &amp; Assembly-4.jpg
  42. #242
    Jun 2016
    The Roxshox Fork
    Attached Thumbnails Attached Thumbnails Argus:  A fat bike for the masses? Review &amp; Assembly-5.jpg
  43. #243
    Jun 2016
    The Arm is self-extracting, so you don't need a puller tool to remove it.
    All you need is an 8mm Allen.
    Attached Thumbnails Attached Thumbnails Argus:  A fat bike for the masses? Review &amp; Assembly-6.jpg
  44. #244
    Jun 2016
    The Arm being removed:
    Argus:  A fat bike for the masses? Review &amp; Assembly-8.jpg
  45. #245
    Jun 2016
    The Arm removed revealing the Spacer, Washer and Spring Washer (sometimes called Wavy or Belvidere Washer).
    Attached Thumbnails Attached Thumbnails Argus:  A fat bike for the masses? Review &amp; Assembly-9.jpg
  46. #246
    Jun 2016
    Make sure these go back on the correct order when you reassemble:
    Attached Thumbnails Attached Thumbnails Argus:  A fat bike for the masses? Review &amp; Assembly-10.jpg
  47. #247
    Jun 2016
    The open ended BB tool is nice because you can use it to tighten things up without removing the pedals.
    Shimano TL-FC32 BB Cup Installation Tool > Accessories > Tools > Bottom Bracket Tools | Jenson USA
    Attached Thumbnails Attached Thumbnails Argus:  A fat bike for the masses? Review &amp; Assembly-11.jpg
  48. #248
    Jun 2016
    Here you can see that the factory put No-Ox on the threads.
    (Of course I put more on, and covered all the deeper threads too)
    Attached Thumbnails Attached Thumbnails Argus:  A fat bike for the masses? Review &amp; Assembly-12.jpg
  49. #249
    Jun 2016
    Full Speed Ahead MegaExo BB Bearing:
    Attached Thumbnails Attached Thumbnails Argus:  A fat bike for the masses? Review &amp; Assembly-13.jpg
    Argus:  A fat bike for the masses? Review &amp; Assembly-14.jpg
  50. #250
    Jun 2016
    10 speed Shimano cassette.
    Attached Thumbnails Attached Thumbnails Argus:  A fat bike for the masses? Review &amp; Assembly-15.jpg
    Argus:  A fat bike for the masses? Review &amp; Assembly-16.jpg
  51. #251
    Jun 2016
    Hub with Cassette removed:
    Argus:  A fat bike for the masses? Review &amp; Assembly-17.jpg
    Argus:  A fat bike for the masses? Review &amp; Assembly-18.jpg
  52. #252
    Jun 2016
    Rear Axle
    Attached Thumbnails Attached Thumbnails Argus:  A fat bike for the masses? Review &amp; Assembly-19.jpg
  53. #253
    Jun 2016
    Rear Bearings are NBK 6903-2RS
    30mm x 17mm x 7mm
    Those are actually a good brand of bearings, and cost about $6 to replace.
    Attached Thumbnails Attached Thumbnails Argus:  A fat bike for the masses? Review &amp; Assembly-20.jpg
  54. #254
    Jun 2016
    Here is the Left side of the Rear Hub with the Bearing removed.
    Lightly grease the outside of the bearings before replacing them. This will allow easy removal in the future.
    Attached Thumbnails Attached Thumbnails Argus:  A fat bike for the masses? Review &amp; Assembly-21.jpg
  55. #255
    Jun 2016
    Front Axle
    Attached Thumbnails Attached Thumbnails Argus:  A fat bike for the masses? Review &amp; Assembly-23.jpg
  56. #256
    Jun 2016
    Front Bearings are NBK 6804-2RS
    32mm x 20mm x 7mm
    Attached Thumbnails Attached Thumbnails Argus:  A fat bike for the masses? Review &amp; Assembly-22.jpg
  57. #257
    Jun 2016
    Front Hub with bearing removed:
    Attached Thumbnails Attached Thumbnails Argus:  A fat bike for the masses? Review &amp; Assembly-24.jpg
  58. #258
    Jun 2016
    Front Hub with Bearing and Axle reinstalled.
    After greasing the outsides of the bearing, find a socket with the same size OUTER diameter as the bearing. Gently tap the bearing into place, using the socket to transfer the blows to the outer race.
    Only tap on the outer race of the bearing, never tap the inner race.
    Attached Thumbnails Attached Thumbnails Argus:  A fat bike for the masses? Review &amp; Assembly-25.jpg
  59. #259
    Jun 2016
    Saddle and Post pics
    Attached Thumbnails Attached Thumbnails Argus:  A fat bike for the masses? Review &amp; Assembly-27.jpg
    Argus:  A fat bike for the masses? Review &amp; Assembly-26.jpg
  60. #260
    Jun 2016
    Stem, Spacers, and Headset parts
    Attached Thumbnails Attached Thumbnails Argus:  A fat bike for the masses? Review &amp; Assembly-28.jpg
    Argus:  A fat bike for the masses? Review &amp; Assembly-29.jpg
    Argus:  A fat bike for the masses? Review &amp; Assembly-30.jpg
  61. #261
    Jun 2016
    The factory had **some** grease on the Fork bearings, but you should grease it like you mean it.
    The grease will keep water out of the bearings, especially Marine Grease.
    Attached Thumbnails Attached Thumbnails Argus:  A fat bike for the masses? Review &amp; Assembly-31.jpg
    Argus:  A fat bike for the masses? Review &amp; Assembly-32.jpg
  62. #262
    Aug 2016
    Front hub bearing
    How can the bearing be removed without applying force to the inner race?
  63. #263
    Mar 2011
    those gumwall Juggernaut's are something Kenda did special for us. Thanks Kenda. Thought the gold ano would look super rad too!
  64. #264
    Jun 2016
    Normally, you pull the bearings and throw them away because they are clicking or something.
    Often they are corroded because of the dissimilar metals and are really stuck in there, so you have to forcefully drive them out.
    But on a brand new bike like this one, they just slid right out with gentle pressure. Greasing the outsides will hopefully allow them to be removed as easily a year from now.
    But any strong pressure on the inner race will usually damage the bearing, so get in the habit of only driving bearings using the outside race, whether they are going in easy or not.
  65. #265
    Jun 2016
    Fill the cup completely with grease, then install the completely greased bearing cage.
    Argus:  A fat bike for the masses? Review &amp; Assembly-33.jpg
    Attachment 1094414
    Argus:  A fat bike for the masses? Review &amp; Assembly-34.jpg
  66. #266
    Jun 2016
    Install the Ring, Adjusting Race and Adjusting Sleeve.
    Grease the Adjusting Race.
    Argus:  A fat bike for the masses? Review &amp; Assembly-35.jpg
    Argus:  A fat bike for the masses? Review &amp; Assembly-36.jpg
    Argus:  A fat bike for the masses? Review &amp; Assembly-37.jpg
  67. #267
    Jun 2016
    Drop on your cap and spacers.
    The Gold Anodized spacer is a cool piece of bling.
    Wipe off all your sloppy grease, and clean the top of the fork tube to make sure it is completely grease free.
    Attached Thumbnails Attached Thumbnails Argus:  A fat bike for the masses? Review &amp; Assembly-38.jpg
  68. #268
    Jun 2016
    Install the Stem (right side up, please), and Cap.
    Stand over the bike and tighten the cap bolt (5mm Allen) so the stem is centered over the wheel. Don't make this too tight, the fork should spin freely.
    Tighten the Stem clamp bolts.
    Attached Thumbnails Attached Thumbnails Argus:  A fat bike for the masses? Review &amp; Assembly-39.jpg
  69. #269
    Jun 2016
    The Expert came with a pair of really nice alloy peds.
    They spun crazy butter smooth, right out of the box.
    Replaceable pins too.
    Argus:  A fat bike for the masses? Review &amp; Assembly-40.jpg
    Removing the service cap, you can see the bearings are deep within.
    Argus:  A fat bike for the masses? Review &amp; Assembly-41.jpg
    The peds were perfect, so I did not adjust the bearings in any way. You could not make them better.
    Argus:  A fat bike for the masses? Review &amp; Assembly-42.jpg
    You don't need a specialized wrench to install these peds, they install from the backside of the arms with an 8mm Allen.
    Argus:  A fat bike for the masses? Review &amp; Assembly-43.jpg
  70. #270
    Jun 2016
    The Hayes Radar brakes grab so hard it's amazing.
    My woman was skidding donuts around in the street, giggling with delight.
    I wish I had some old rubber to destroy, because I feel guilty killing these gumwalls.
    Attached Thumbnails Attached Thumbnails Argus:  A fat bike for the masses? Review &amp; Assembly-45.jpg
    Argus:  A fat bike for the masses? Review &amp; Assembly-44.jpg
  71. #271
    Jun 2016
    Random Argus Expert bike Pr0n pictures for your viewing pleasure.
    Attached Thumbnails Attached Thumbnails Argus:  A fat bike for the masses? Review &amp; Assembly-46.jpg
    Argus:  A fat bike for the masses? Review &amp; Assembly-47.jpg
  72. #272
    Jun 2016
    Front Rotor
    Attached Thumbnails Attached Thumbnails Argus:  A fat bike for the masses? Review &amp; Assembly-48.jpg
  73. #273
    Jun 2016
    Fsa
    Attached Thumbnails Attached Thumbnails Argus:  A fat bike for the masses? Review &amp; Assembly-49.jpg
  74. #274
    Sep 2016
    I'm kind thinking I should've bit the bullet spent the money in the expert now!
    Thanks for the awesome tutorials vid1900 on both the sport and the expert!
  75. #275
    Jun 2016
    10 cas
    Attached Thumbnails Attached Thumbnails Argus:  A fat bike for the masses? Review &amp; Assembly-51.jpg
  76. #276
    Jun 2016
    Front by front
    Attached Thumbnails Attached Thumbnails Argus:  A fat bike for the masses? Review &amp; Assembly-52.jpg
  77. #277
    Jun 2016
    Last pic (unless someone has a needed request)
    Attached Thumbnails Attached Thumbnails Argus:  A fat bike for the masses? Review &amp; Assembly-50.jpg
  78. #278
    Jun 2016
    Yeah, I was totally impressed by this bike for the price.
    Even the little things like the pedals or the grip locks were really well done.
    The Roxshox alone is worth the difference in price from the Sport, but then add on those Hayes brakes, the rear through axle, the 4.5" gumwalls, the FSA BB/crankset.........nothing else is even close value wise.
    You are very welcome, sir.
    I'd like to get my hands on the Argus Competition, too.
    It would be fun to build one of those and put it through it's paces.
  79. #279
    Aug 2016
    Thats one sweet bike.
  80. #280
    Dec 2009
    Bow hunting and yeah that's the idea to get where other won't go or are too lazy to go.
    Same here... I just sold my 29er hardtail, looking for something softer on my bod. I bow hunt too, sometimes pull small homemade carts as needed. Really looking for quiet faster travel rather than slow walking and carrying stand on back. Getting older and all is getting harder, having minor back issues now. My current locations all have bike friendly gentle terrain trail systems.
    Also considering a (gasp) ebike, but the Argus at the beginning of this post is very interesting too. Hope to decide something in next 2 weeks. Need to look over fatbikes in person for awhile. Never even saw one up close yet.
    Thanks to OP and everyone who took the time in this extremely informative post!
  81. #281
    Jun 2016
    Through Axle pics for Rob & Great8
    Attached Thumbnails Attached Thumbnails Argus:  A fat bike for the masses? Review &amp; Assembly-54.jpg
    Argus:  A fat bike for the masses? Review &amp; Assembly-53.jpg
  82. #282
    Jun 2016
    Here you can see where the Rear Axle threads into the Derailleur Hanger
    Attached Thumbnails Attached Thumbnails Argus:  A fat bike for the masses? Review &amp; Assembly-55.jpg
  83. #283
    Jun 2016
    Anyone order one of these yet?
    $1,073
    https://www.amazon.com/Mongoose-Argu...222.1474078978
    Attached Thumbnails Attached Thumbnails Argus:  A fat bike for the masses? Review &amp; Assembly-91adrc9xmul._sl1500_.jpg
  84. #284
    Jun 2016
    And this is now listed:
    $1,568
    https://www.amazon.com/Mongoose-Argu...mongoose+argus
    Attached Thumbnails Attached Thumbnails Argus:  A fat bike for the masses? Review &amp; Assembly-91ccwumonal._sl1500_.jpg
  85. #285
    Jun 2016
    And this in red:
    $629
    Attached Thumbnails Attached Thumbnails Argus:  A fat bike for the masses? Review &amp; Assembly-91rsav39rdl._sl1500_.jpg
  86. #286
    Reputation: Luis_fx35's Avatar
    Aug 2015
    I'm glad I haven't pulled the trigger yet
    I'm boss and I know it
  87. #287
    Aug 2015
    The rims cut outs and the color are worth the extra 300 on the expert. The waiting time is a pain. I would go crazy.
  88. #288
    Jun 2016
    Quote Originally Posted by Luis_fx35 View Post
    How cool is the gloss logo on the matte finish frame?
  89. #289
    Aug 2016
    80mm rims and juice brakes for 2017 suggest that 2016 Sport is a better low end snow/sand bike, except for (7) small riders who can still grab 2015.
  90. #290
    Feb 2012
    Historically people make fun of Mongoose since they sell in Walmart, but the gold rim Argus Expert is one of the best deals in fatbikes for 2016 and is pretty up to date on hub and rim widths.
    The only major faults are the short seatpost (can't max pedal efficiency and I am only 173cm) and their tire rim combo which I couldn't get to work ghetto tubeless; tire was just too loose on the rim and seeped sealant through the gumwall casing.
    Hope someone tries a different tire and gets tubeless to work.
    Sadly this black 2017 model looks to have the same rim profile but different cutouts so might also be hard to go tubeless unless you change to a tighter tire.
    I hope someone at Mongoose is reading this thread and specs a longer seatpost and tubeless rims for 2018.
    Totem KDS-D fatbike, Brompton M2L-X Ti, 6kg Dahon Dove, 1998 GT Forte Ti road bike
  91. #291
    Jun 2016
    Quote Originally Posted by ttakata73 View Post
    The local Mongoose dealer claims that he can't even order those Wally bikes.
    They are not in the dealer catalogs, nor are any replacement parts.
    He says he is careful not to put down the Wallygooses when people ask. He just tells them "That entry level line of Mongoose bikes is unavailable to professional bike shops".
  92. #292
    Sep 2016
    Heya, after reading this thread i ordered the 2016 argus sport from nashbar (great info on this thread and it's link btw). Only thing that was wondering is (with nashbars great return policy) is would the red argus be better because of the 80mm rims? the hyd brakes isn't a big deal to me and other than the rims the spec looks identical.
    Basically are the rims worth the extra 160.00
  93. #293
    Jun 2016
    Quote Originally Posted by knarrly View Post
    Myself, I'd rather have the wider rims.
    But it all depends on what kind of riding you do.
    The whole goal of selling different bike models is to make each model one feature away from being the **perfect** bike.
    If you are not losing sleep over some small difference, then the marketing department is not doing their job properly.
  94. #294
    Aug 2016
    rim worth
    Literally, I can find 80mm pierced rims for about $150 a pair and 100mm rims for about $215. Practically, narrower rims are less vulnerable to damage from rocks, etc and put more curvature into tire carcasses than do 100mm rims. Increased curvature can translate to more shock absorption, particularly with lighter and higher thread-per-inch tire construction.
    Wider rims improve sand or snow traction and hold more air. More air translates to lower spring rate for better large bump absorption. More nearly flat tread increases small bump harsness for a given inflation pressure. Wider rims reportedly reduce Juggernaut rolling resistance on hard surfaces.
  95. #295
    Aug 2016
    pointless grease syringe
    A friend's freewheel needed maintenance.
    Waterproof grease is readily available in our beach town,
    but specialized tools - not so much.
    Fortunately, our market had a cheap marinade injector,
    much like https://www.amazon.com/dp/B004RDPM3Q
    which, after removing hollow needle point,
    works fine for precise lube application,
  96. #296
    Jun 2016
    Those are great!
    You can get them at the local pharmacy if you ask for a "horse syringe" (I'm not kidding). No prescription necessary.
    I use them for injecting epoxy.
    .75 cents:
    BettyMills: Monojectâ„¢ 60 mL Syringe - Medtronic 86562802
  97. #297
    Aug 2016
    RST Renegade Fat Bike Fork
    I expect RST's Renegade could be fitted an Argus Sport or Comp,
    and might be better than a Bluto, but not ideal for salty beach sand.
    This one currently has only 1 bid ($250 + $15 shipping)
    with less than 5 hours to go: RST Renegade Fat Bike Fork | eBay
    I'm saving for a Lauf Carbonara..
  98. #298
    Reputation: Erock503's Avatar
    Oct 2014
    Great thread vid1900, thanks for all the info. I'm a bit confused on something though. I'm considering the regular teal Argus on Amazon. What am I losing out on by not getting the red sport model?
  99. #299
    Jun 2016
    The Teal Argus (2015) is better speced than the Red Sport 2017, so you are getting the better bike if you go with 2015.
  100. #300
    Oct 2014
    Thanks vids. Im 5'7", with a 29" IS. Think I would be better off on a medium or small?
  1. Replies: 30
    Last Post: 04-21-2017, 06:00 PM
  2. Mongoose Argus dead or alive
    By Captlink in forum Fat bikes
    Last Post: 10-11-2015, 09:39 AM
  3. Question for the masses. ..
    By belikemike in forum Fat bikes
    Last Post: 05-06-2015, 07:28 AM
  4. Fat bikes for the masses!
    By djork in forum General Discussion
    Last Post: 04-27-2014, 11:01 PM
  5. Getting the Masses Involved!
    By Ricisan in forum General Discussion
    Last Post: 12-19-2009, 08:52 AM
Members who have read this thread: 17
