Results 1 to 35 of 35
    Reputation: druidh's Avatar
    Alfine vs Rear Mech
    Over the last few winters I've had trouble with rear mechs freezing up. A combination of temperatures just below freezing and the occasional splash of melted water often means the poor thing is frozen in place completely.
    Building up a Fatbike, I reckoned I'd deal with the problem by going Alfine. However, I'm a bit unimpressed by the gearing and I can't really fix that without completely ignoring Shimanos recommended gearing ratios. Even the Rohloff would be a problem, and I don't think I'm ready to shell out that sort of money.
    Looking at photos off this site (and others) most folk seem to have stuck with traditional front and rear mechs.
    So - what rear mech problems and solutions have you experienced? Are there makes and models you would rate more highly than others?
    Reputation: vikb's Avatar
    I've been running an Alfine 8 32T x 21T setup in my Pugs for years with no complaint - winter/summer. I've snow/sand biked with it, toured with it and been pleased with the performance and lack of drama.
    Lately for really steep techy MTB trails I put a bigger cog on the back 23T I think [bike isn't in front of me]. I haven't used it enough with that gearing to comment yet.
    I'm building up a new 29er hardtail and it's getting an Alfine 11 IGH. I also own 2 Rohloffs. I wouldn't want an IGH for every bike I own, but for the snow/sand/bikepacking fatty it seems like a great choice to me.
    Safe riding,
    Vik
    www.vikapproved.com
    Reputation: motorman's Avatar
    It is funny you post this up, I was going to ask how you were getting on with the alfine/philcentric set up.
    Thanks to a feckin big stick, I smashed my hanger & rear mech at the weekend. The drivetrain is pretty shot after 1200 or so wet & sandy miles, so I am changing everything out.
    I was planning to change over to alfine, but I can't get my head round the idea of small gear range & your post kind of confirms my concerns.
    I ride most trails with a 32 up front & 12/36, but for really soft bog & sand, I like to have the option of using 22t granny.
    I am sticking to steel deore rings & X7 rear mech, both have worked well for me. Just need to service the jockey bearings regular during the winter months.
    Biggest problem for me is the 907 hanger - it is really weak. Good job I had a few spare, otherwise it would have been a long wait to get rolling again.
    Drink coffee....ride bikes....eat cake
    http://morayfatbike.blogspot.com
    Reputation: Velobike's Avatar
    You'll want to ride through thick heather at some point.
    It's the best cure for derailleurs known to man.
    (My previous post on this has disappeared.)
    Put a hub gear on it.
    (BTW I haven't seen any minimum ratio recommended for the 8 spd Alfine, but if you follow the guide for the 11 spd, you end up with the same bottom gear as the 8, so unless you have high speed road transits, the 8 is the better buy IMO.)
    Latitude: 57º36' Highlands, Scotland
    I have a pugs that is being converted to Alfine - I like them a lot. I did however just recently order a Mukluk Ti, which is Alfine incompatible. I might one day put a rolhoff on the mukluk, but I am not sure how they perform at -30 and since I ride at -30 at least once per year, I was reluctant to start with a rohloff.
    Just below freezing is definitely the worst temperature for stuff icing up, I find that fenders help immensely with the stuff accumulating on my derailleur or brakes.
    Quote Originally Posted by coldbike View Post
    ...I might one day put a rolhoff on the mukluk, but I am not sure how they perform at -30 and since I ride at -30 at least once per year, I was reluctant to start with a rohloff.....
    That's the reason for the Surly offset fork. Your front wheel can be swapped with the rear.
    However I've never had the problem of ultra low temps.
    Frt Range, CO
    Reputation: pursuiter's Avatar
    Quote Originally Posted by motorman View Post
    I ride most trails with a 32 up front & 12/36, but for really soft bog & sand, I like to have the option of using 22t granny....
    I run an Alfine 8 on three different MTBs, Pugs, Moonie and 29er. On my Moonlander I'm
    running a 30x24, it has the same low gear as 22x34 (18") and the same high gear as a 32x16
    (58").
    How high a gear do you need? I am able to ride the streets to the trail without spinning out too
    much.
    Are you keeping the Pugs? What drove your Ti Muk purchase?
    I haven't found a satisfactory way to get a Rohloff into a 170mm fatbike. Between the chainline, spoke tension and torque control there seems to always be something incompatible or compromised. No point using a super expensive IGH if it's not going to be a good fit for a frame.
    Safe riding,
    Vik
    www.vikapproved.com
    Reputation: coastkid71's Avatar
    An Alfine 8 or 11 IGH is a great idea for a fat bike, esp for an offset bike like a 9zero7 or pugsley with the back up of swappable wheels using the Surly offset fork and another rear hub.
    Loads of folk keep posting they do not need swappable wheels, and never needed to do so...fair enough, but it is a nice `get out of jail free card` option (a UK saying ),
    And as happened to myself last year and yesterday to my Friend Jason, he had to swap wheels around to ride the rest of the day when his Alfine failed and locked up due to ingress of salt water from a previous dooking (thats a Scottish dunking or er drowning...),
    Tyninghame by coastkid71, on Flickr
    Scottish Sunday results;
    North Sea 2 - Alfine Hub 0
    Alfines are ace, except they do not go low enough geared for real soft sand and definitly do not like salt water
    plan it...build it....ride it...love it....
    http://coastkid.blogspot.com/
    Fat!Drunk!Slow!
    Reputation: JordyB's Avatar
    Oct 2007
    Is it expected that once you dunk or ride in axle deep salt water that service should be in order? Or at least inspection? Sounds like a wheel swap could have been avoided by doing this? Gotta love the backup options of a pug!
    Bicycle Obsessed
    Reputation: jpettit's Avatar
    Dec 2011
    I'm just in the process of putting together a Pugsley with an Alfine 11. I haven't had the wheels built yet, but it will be a Alfine 11 with 21t cog matched with a Middleburn 7 Uno Crank with 34t. Once I get the thing built up I'll post some pics and thoughts.
    I'm doing the Alfine mainly for the reasons you stated. I'm a bit tired of riding my current MTB with a traditional derailleur setup. It seems to freeze a lot, ice up, shift poorly and involves a lot of cleaning, lubing etc every ride. When it's -20 the last thing you want to have to do is adjust your derailleur setup to get home!
    Quote Originally Posted by pursuiter View Post
    (58").
    much.
    That is good info right there.
    I can't really see me going alfine on my current 907, as it requires a tensioner or Philcentric BB.
    Might hang on for the new frames with the sliding drop outs & make it a trail bike with alfine & keep the old one for beach with the really low ratio's.
    I really like "normal" gears for most of the time, but when heading off the beaten track, the minimal setup of alfine has the advantage as there is nowt to get ripped off.
    JordyB
    In an ideal world yes!, How ever here in the Uk no one seems to know anything about Shimano Alfine hubs , and servicing them, riding on the coast can or will (in warmer summer waters!) involve crossing estuarys, riding or pushing through sumerging the bike, often totally nearly every weekend for us lot!,
    I just repaced the hub bearings on a rear Hope Pro 2 after 3 years, WITH NO SERVICE after some post build prep,
    I opened up and degreased then repacked all the bearings with marine grease (previously used to use Wurth graphite grease), a smear around the pawls as well as oil for the fee hub and so far no probs with rear hubs, if i wipe out a rear mech then i swap wheels , cut the chain and SS it home!
    Quote Originally Posted by JordyB View Post
    I wouldn't submerge any MTB hub underwater - especially not an IGH or in saltwater. If it were to come t that I carry my bike or find another route. I don't enjoy servicing hubs regularly.
    Safe riding,
    Vik
    www.vikapproved.com
    I just posted, we do it reguarly Vik! and have found with sealed free hubs its not been an issue, with a bit of preperation
    Quote Originally Posted by coastkid71 View Post
    If you want to submerge an Alfine or Rohloff in saltwater be my guest, but I won't be doing it... My experiences don't agree with yours and frankly I'm not keen to experiment. So far I haven't been unable to get where I wanted to go without submerging my hubs, BB, etc...
    If my hubs are submerged I'm getting wet either way so I just pick up my bike and carry it across the water obstacle. If it's too deep to ford that way I find another route.
    I'd be less concerned with a standard MTB hub, but I still wouldn't submerge it voluntarily.
    BTW - I must admit submerging/floating a bike does make for a great action video!...
    Safe riding,
    Vik
    www.vikapproved.com
    Quote Originally Posted by vikb View Post
    ...If my hubs are submerged I'm getting wet either way so I just pick up my bike and carry it across the water obstacle. If it's too deep to ford that way I find another route.
    Me too.
    But I appreciate the efforts of those who do submerge them - useful info is the result.
    aka DummyDiva
    Reputation: cowboygrrl's Avatar
    Jan 2011
    Quote Originally Posted by jpettit View Post
    My build is very close to yours, also an Alfine 11 going on it's 2nd year without problems. Middleburn crank, running 32:20. With regards to submerging, one advantage of the 11 over the 8 is that it's sealed.
    Quote Originally Posted by cowboygrrl View Post
    The seals on an Alfine or Rohloff won't keep water out if you submerge the hub.
    Safe riding,
    Vik
    www.vikapproved.com
    I run a 22x22 on my alfine 8spd. been riding for about a year with no issues thus far. Will tear apart the alfine this spring for servicing.. it'll be 3 winters of riding so might be about time.
    (a) I'm encouraged by the fact that some folk are running lower gears without issue. That 30T Extralite ring is looking tempting.
    (b) Motorman - it's not the range of gears that's the problem. It's got to be an exceptional circumstance to need the 10th/11th gears. It's just that the range seems to start too high.
    Reputation: jason-l's Avatar
    As Coastkid said above, I was glad to have swappable wheels on Sunday to get me home
    Front wheel drive will never catch on
    RIP Alfine 8 spd by jason-l, on Flickr
    But quite enjoyed the lightweight (rear end) liberation of singlespeed (even though 32/22 is useless for sand!
    Singlespeed Fat Bike by jason-l, on Flickr
    My Alfine 8 lasted approx 1300 miles in 11 mths of almost exclusively sand/beach/coastal riding here in Scotland - with numerous fordings and a few full immersions. So, yes, it's had a brutal life. And right up to the moment of failure I loved riding it - just found it perfect for this kind of terrain and enjoyed it's relative simplicity. Nothing to get snagged on vegetation or be bashed against rocks, ability to change gear while trackstanding, and the cleaness of a singlespeed style layout.
    ...but ultimately I have decided, very reluctantly, to revert to derailleurs with a Hope Pro2 EVO hub for the simple reason I need a hub that is better sealed. I don't want to alter my riding to protect my gear, rather I want my gear to better withstand my riding
    Quote Originally Posted by jason-l View Post
    I wonder if it would work the other way. Minimal sealing to keep grit out but allow fluids to pass. The original hub gears were oil lubricated. Get it wet, drain it, run some fresh oil through it to flush it. The only hassle was giving the hub a few drops each week. The hubs were good for 10s of thousands of miles of road use and many members of the RSF preferred them for offroad too.
    ...riding on the coast can or will (in warmer summer waters!) involve crossing estuarys, riding or pushing through sumerging the bike, often totally nearly every weekend for us lot!...
    Saw this on Hubstripping and thought it may be of interest.
    aaronsbicyclerepair
    February 27, 2011 at 6:09 pm
    The best grease we have found for IGH hubs is specifically: Sta-Lube
    We use it on the ball bearings and the planetarty/sun/ring gear teeth.
    The rest of the hub we use Phil Wood Tenacious Oil (available at any bike shop). Phil Wood takes high quality oil and adds rust inhibitors. It has worked and been recommended for Sturmey-Archer hubs for years.
    It mixes will with any grease and keeps the grease from drying out and getting hard. We have over 25 years success using this combination!
    Many comments here and elsewhere online talk about excess “friction”. Higher viscosity causes more drag but no additional friction. Even with heavy grease the drag is minimal! A small price to pay for preventing rust!
    We do this lube-upgrade to every IGH hub we sell.
    The rusty hubs that come in that were purchased elsewhere! The Alfine hub, in our opinion, needs a complete lube change before it is ridden in the wet as the right cone is not sealed well against water. We put blue grease there, of course. The Alfine 11 looks about as well sealed as the 8 speed’s right cone. The oil bath is an improvement, but really all IGH hubs should have an oil bath! The real improvement is the sealing, not from keeping water out, but keeping the oil from making a mess!
    Quote Originally Posted by Velobike View Post
    I wonder if it would work the other way. Minimal sealing to keep grit out but allow fluids to pass. The original hub gears were oil lubricated. Get it wet, drain it, run some fresh oil through it to flush it. The only hassle was giving the hub a few drops each week. The hubs were good for 10s of thousands of miles of road use .
    "the only hassle was giving the hubs a few drops each week" and "get it wet, drain it, run some fresh oil through it to flush it" are conflicting statements!
    flushing the entire hub out every time it gets wet isn't an option.
    if your hub gets a full flush with fresh oil every time you ride in the wet, then yeah it could last decades with no seals at all!
    If steel is real then aluminium is supercallafragiliniun!
    Quote Originally Posted by byknuts View Post
    It was only a few drops of oil needed. In the old days most of us carried a small oil can in the saddle bags.
    @adelorenzo
    Reputation: anthony.delorenzo's Avatar
    My wife and I ran Alfine 8s for several years on our Pugsleys with excellent results. A few thoughts:
    Low gearing is possible. I ran 33x22 which is an extremely low range, and it held up to a big, strong rider pushing on 190mm cranks.
    The hub always engaged and shifted flawlessly at temps down to -40. The only time we had an issue was when the cable froze on my wife's bike.
    Once a year in the off season I took the hub apart (just the basic dissassembly, not the full tear down) and put a light coating of regular bike grease in there. No fancy oils, potions or lotions. I did try the ATF bath one year but it didn't seam to make any difference, plus the ATF seemed to seep out of the hub pretty quick. Now, this is riding 6 months/year in cold and snow but not a lot of muck or moisture so YMMV.
    The biggest downsides of the Alfine for me were the inefficiency -- you can definitely feel drag in the hub -- and the 'sloppy' feeling, the latter I think is because of the clutch design. I have a Saint hub now and it feels so much better just in terms of engagement and standing up to hammer on it. That's why I sold the Alfine and built a new rear wheel. My wife's is still on her bike although she sold the bike as she upgraded to a fatback.
    Alfine Pugsley by Anthony DeLorenzo, on Flickr
    Another get you home option if you are using a 100mm front.
    That's a good solution, though you'd need to be carrying a centrelok adapter tool and large wrench for the required torque to remove the disc. Still, nice to have that as an option for non-swappable wheels.
    Depends.
    I'm already running one of those adapters on my Alfine (because the centerloc disks rub on my disc calliper)
    So all I need to carry is the cog.
    [QUOTE=Velobike;8948053]Another get you home option if you are using a 100mm front.
    Unless you have an offset fat bike, in which case, you won't be able to flip your wheel without re-lacing it.
    Cool.
    My mistake in skim-reading... Hadn't realised this also served as a centrelock adapter too.
    Good point. Scrub that idea!
    I'm a bit surprised that Surly didn't give the ML swappable front to rear wheels. Given that it's an even more "go anywhere and explore" bike than the Pugs the ability to keep rolling after a rear hub failure seems like a natural fit.
    Safe riding,
    Vik
    www.vikapproved.com
    Reputation: Lone Desert Walker's Avatar
    Yeah
    I'm a bit surprised that Surly didn't give the ML swappable front to rear wheels. Given that it's an even more "go anywhere and explore" bike than the Pugs the ability to keep rolling after a rear wheel failure seems like a natural fit.
    Agreed bro. If the Moonlander had swapable wheels I may have gon that route instead of the pug.
  1. Trek Fisher Marlin 29er SS to Alfine 8 speed
    By Gary McCray in forum Internal Gear Hubs
    Last Post: 07-19-2012, 07:51 PM
  2. Specialized Ground Control
    By SLIMBOY in forum Vintage, Retro, Classic
    Last Post: 06-07-2011, 08:54 PM
  3. Adjusting Long Gauge Shimano Lx rear mech
    By TopCat in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 12-02-2007, 10:49 AM
  4. Sunday owners.....rear mech cable problems
    By ChamMTB in forum Downhill - Freeride
    Last Post: 05-10-2007, 03:49 PM
  5. If you need to know this.
    By KevinVokeyJ24 in forum General Discussion
    Last Post: 12-24-2004, 09:40 AM
