Results 1 to 3 of 3
    Jan 2014
    Air Pressure Suggestions
    So I recently purchased a fatbike and have been learning a lot about the air in the tires.
    What pressures are folks running for what conditions?
    Any suggestions on the best bike mounted pump for these fatties?
    nvphatty
    Guest
    Quote Originally Posted by GiantTrek View Post
    The conditions will dictate but for a baseline start for fresh snow or sand 6r & 5f. For hardpack single or dbl track trail riding 10r & 8f and adjust as you ride to suit.
    Reputation: masterofnone's Avatar
    Ok, I'll bite. There are endless variables on ideal fatbike tire pressure, only to be outdone by the endless threads on the subject. I weigh about 175ish, and ride a mukluk with rolling darryls and 27tpi nates. I've settled on about 9r 8f for rocky singletrack, if a dusting to 2 or 3 inches of snow I drop to 5r 4f, if deeper snow is involved I will deflate to the point where the sidewalls are on the verge of wrinkling, around 2.5r 2f for maximum flotation. Don't take these numbers as the rule or the norm, your mileage will most certainly vary.
    To appreciate the flowers you must also walk among s**t to know the difference
  1. Tyre Pressure & Front Suspension Pressure on 2009 Badboy
    By fumi in forum General Discussion
    Last Post: 07-05-2013, 10:30 AM
  2. AIR Pressure
    By JKoenig1980 in forum 29er Bikes
    Last Post: 08-28-2012, 10:03 AM
  3. jet 9 air pressure help
    By leonidas 119 in forum Niner Bikes
    Last Post: 03-30-2012, 08:59 PM
  4. Need tire suggestions for Snowshoe trip, any suggestions?
    By TheTwanksta in forum Downhill - Freeride
    Last Post: 09-29-2011, 11:48 AM
  5. RP2: Pressure
    By kirchhoff in forum Shocks and Suspension
    Last Post: 04-24-2011, 07:05 PM
