Results 1 to 33 of 33
    Loser
    Reputation: Jisch's Avatar
    Air pressure gauge that works to low PSI?
    My Lenzyne floor pump (awesome pump BTW) just doesn't read low pressures at all, seems highly inaccurate below 15 PSI. What are you guys using to measure how much air is in your tires?
    Fat Biker
    Reputation: wyoracerX's Avatar
    Accugage 0-15 psi presta valve fitting
    But nowadays I just do a squeeze test and go up or down from there.
    Rolling on 2 Fat Tires-BlogUpdated when I feel like it or when I get mail
    Reputation: mtuck1's Avatar
    I have a Hercules Airace pump that is digital and seems to work very well.
    Loser
    Thanks, have to calibrate my fingers to low PSI, that's what I do when I pump up a tire on the trail for my Niner right now (pretty accurately).
    Reputation: duggus's Avatar
    $4. Mine has been great for a year's use and having in and out of my pack.
    Slime Low Pressure Tire Gauge: Automotive : Walmart.com
    Also available anywhere that has tire gauges... if you don't support the wally world.
    You obviously will have to get a presta to shrader adapter... but those are usually only $1 or so at a bike shop... if not free if you know them or support them.
    ...Be careful what you're looking at because it might be looking back...
    WNC Native
    Reputation: nitrousjunky's Avatar
    I use and like the SKS Airchecker digital gauge!
    "I ride to clear my head, my head is clearer when I'm riding SS. Therefore, I choose to ride SS."~ Fullrange Drew
    NMBP
    Reputation: crashtestdummy's Avatar
    Jun 2005
    I have a Topeak D2 SmartGauge and a SKS Airchecker digital gauge (^^^^). The Topeak is a little easier to use, but doesn't show tenths of a psi. The SKS is smaller and lighter, and it will show tenths. Both will accept Presta or Shrader.
    Riding Fat and still just as fast as I never was.
    Re: Air pressure gauge that works to low PSI?
    Quote Originally Posted by Jisch View Post
    Which Leyne pump? I bought the "precision high volume" floor pump with the metal barrel and nice aluminum base. The guage only goes up to 70psi. Is it that one?
    Just wondering because I bought it specifically for my fatbike. Bummer if its no good.
    Sent from my Nexus 4 using Tapatalk 2
    Oslo, Norway
    Feb 2012
    Beto makes a basic digital gauge that works great. Reads from 3psi in 0.1psi increments.
    Weighs only 36g and is small and sleek. Fits nicely in the jersey pocket.
    Espen Wethe
    www.kindernay.com
    Kindernay on BikeRumor: https://goo.gl/iQtWxu
    Loser
    I'm not sure what model I have, but it goes up to 200PSI if I recall correctly, I'm sure it goes to 120, cause that's what I put my road bikes at.
    Laramie, Wyoming
    Reputation: alphazz's Avatar
    Oct 2012
    A low pressure pencil gauge works great if you have schrader valves.
    Reputation: thickfog's Avatar
    Oct 2010
    Quote Originally Posted by nitrousjunky View Post
    I like mine. Btw, the slime gauge is way off from my experience up against to other different type digital gauges- Schwalbe gauge and sks.
    Sent from my SCH-I535 using Tapatalk 4
    CRAMBA Chairman
    Reputation: mongol777's Avatar
    Related question - which pump would you guys recommend? Mine is getting old and it is cheapo unknown brand anyway. Would like one with accurate gauge for low and high pressure (up to 125 should do it) and since I have more balloon and fat bikes then road - probably geared more towards high volume.
    And which one do you take to the trail (for your fatty)?
    I use a Slime ATV dial type guage. 0 to 20psi. I got it through Cabelas. Have to use a presta adapter though. The Slime "dial type" seems to be more accurate than the "pencil" type.
    Reputation: INEVTBL's Avatar
    Sep 2012
    +1 Works great for high & low pressure and presta & shrader.
    I'll have to try a digital one, as it seems I killed my accugauge by over ranging it. Thought I pumped up a Big Apple to less than 30, but it was somewhat more than that. Needle went all the way to max then dropped to zero and hasn't moved since.
    Yeah... I guess if a pencil guage is off by 1psi I could give a flying frick anyway... my test to see if I have the right pressure is usually just to push on the tire... or ride it. That's all that really matters anyway.
    Personally I dont think you really NEED a guage for fat bikes.
    Reputation: Rcksqrl's Avatar
    Aug 2013
    Look in the off road industry. We frequently run super low psi for rock crawling. (7-8 in my crawler, have a low psi guage.)
    The slime guages have not been very accurate in comparison.
    Just my .02
    Sent from magic wish granting phone
    Oct 2012
    My LBS just sold me an SKS Airchecker with my new fatbike...
    Laramie, Wyoming
    Oct 2012
    Quote Originally Posted by duggus View Post
    1 psi makes a large difference when riding in snow and it's nice to know the different pressures needed for different snow conditions. The key is to not buy a cheap Walmart pencil gauge.
    Reputation: marathon marke's Avatar
    Sep 2012
    Quote Originally Posted by evandy View Post
    I just got one and I'm very happy with it. Works well for accurate pressure on my Moonlander.
    - Mark Ehlers
    The Prodigal Cyclist
    Dec 2012
    How much does the SKS digital weigh?
    I have the Meiser brass gauge and it's pretty heavy.
    Fatbikes.com - Solutions for low tire pressures Meiser Presta-Valve Dial Gauge with Pressure Relief: 30psi
    Sep 2012
    Quote Originally Posted by maelstromwbc View Post
    I don't know what the SKS digital weighs, but it's light. OTOH, I see that it won't work in extremely cold temps, where as the Meiser Dial gauge will. Good to know seeing as fat bikes are very often cold-weather bikes!
    - Mark Ehlers
    I got the same Dial Gauge from Amazon for < half the price. Its a "lawn tractor" gauge, rated 0-30psi. Works great in any temp. I often have to lower my pressures on the way home from work after a blizzard.
    Dec 2012
    Quote Originally Posted by marathon marke View Post
    That's interesting. I like the Meiser because its' mechanical and is 'more reliable' than a digital gauge.
    I dunno. If it feels too firm in the snow I let some air out... if it feels too soft I put some air in. It takes a whole 2 minutes. Just posting that gauge for people that can get by with a $4 gauge. And also... if it says 6psi but is actually 5psi, its not going to matter if it is off... I'm always going to go by what that 6psi felt like. You guys who have been around for a long time know this is true Come on.
    Reputation: lancelot's Avatar
    I've used one of these for the last few years without any issues.
    Slime Digital Tire Gauge - Normal Shipping Ground
    The LPG
    gone walk about
    Reputation: nvphatty's Avatar
    Mar 2012
    define more reliable please.
    "ORANGE IS THE NEW BLACK"
    gone walk about
    Mar 2012
    are walmart pencil gauges any good?
    Reputation: Solo-Rider's Avatar
    Sep 2013
    Accu-Gage
    This is the one I use for my car / motorcycle. Best gage I ever owned. It's not travel friendly. To be honest, I'm not sure how good this will work with those presta valves even with an adaptor.
    I will find out today.
    Nov 2007
    My experience:
    - I can't accurately do the "squeeze test". I'm off by 2-3psi sometimes.
    - A 1 psi difference is noticeable to me on the trail. 6 feels good, so does 5, but I get pinch flats. I'm not tubeless.
    - I have the Accu Gage 0-30psi and a Topeak Digital. The Accu Gage is indeed more reliable (repeatable). The Topeak often gives weird readings. I also don't like using a presta-to-schrader adapter.
    YMMV.
    Loser
    I just found a digital gauge I had in the bottom of my tool box (forgot I had it), its a Michelin that has a switch for presta or schrader - it worked great. When I get my bike I'll mess around more to find the sweet spot, but the difference between 8.5 PSI and 10 PSI was incredible, went from a cushiony ride to a harsh ride (just in a lawn riding test).
    Sep 2013
    I found this online. I'm going to order it because it has the presta fitting on the end. It's an accu-gage, so it's good. Best of all, its a lot more portable then the one I own now.
    Anyway, thought I'd share.
    Meiser Presta-Valve Dial Gauge with Pressure Relief: 15psi
  1. Recommend pressure gauge please?
    By mforness3000 in forum Wheels and Tires
    Last Post: 02-08-2017, 01:49 PM
  2. low pressure gauge?
    By Ant-Eater in forum Fat bikes
    Last Post: 03-06-2013, 11:56 PM
  3. Digital pressure gauge
    By trap121 in forum Wheels and Tires
    Last Post: 02-02-2013, 07:21 AM
  4. Finally... a pressure gauge that does it all!
    By meltingfeather in forum Wheels and Tires
    Last Post: 04-30-2012, 06:45 PM
  5. Low pressure tyre gauge?
    By chuggboy in forum Wheels and Tires
    Last Post: 01-09-2011, 01:06 PM
Members who have read this thread: 4
