Results 1 to 6 of 6
    Jul 2017
    adapter for QR (190mm) hub in a TA (197mm) frame
    I have a need to use a hub made for QR 190mm frame in an 'odd' 197mm TA (actually, through bolt I believe frame). Reasons in a follow up post, but I'm confused by old threads that say this isn't possible:
    • the quick release doesn't do anything except clamp the frame to the locknuts (and located the assembly _while loose_ so that clamping takes place at the correct location)
    • So I would think that with the correct spacer/adapter, one would be successful clamping a QR hub into a TA dropout.
      • If the difference in size was large, you would be placing unanticipated stress on the axle and mating surface, but if it's very close as in 190/197 This seems moot.
    Here are my through axle / through bolt dropouts:adapter for QR (190mm) hub in a TA (197mm) frame-surly_big_fat_dummy_dropout_detail.jpg
    I've seen this asked in some very threads (4yrs 190mm rear hub for a 197mm frame?) but figured i shouldn't resurrect a zombie that old.
    Jul 2017
    Heading off the inevitable: "don't do this, buy a new hub!"
    I have a big fat dummy. It's perfect as-is with human-only power for the commuting, kid-carrying, and bikepacking/trail-building I do. However, a am going to taking it backcountry hunting, and along the lines of a Rokon (2WD motorcycle) I am building a 2nd wheelset with front and rear hub motors. Presently, there are no mainstream companies** offering a TA197 hub motor ... but there are several QR190's.
    I could go mid-motor for the rear, but that is much more difficult to mount/dismount. I want electric only for hunting (where often you have to walk along side the bike on thoroughly UN-ridable off-trail scenarios. Front-motor is required for being able to work the bike, loaded, over large obstructions and to avoid rear wheelspin. I am doing both front and rear because i'll likely need the traction and also rear-motor will be easier on the frame with the anticipated loads. Last the hub-motor won't stress my drivetrain which is a huge benefit when really far out from services.
    Reputation: BlueCheesehead's Avatar
    Given the Surly name in your pic I Googled and found:
    https://surlybikes.com/parts/small_p...dapter_washers
    According to Surly the frame will take a 190 or 197. I would call and talk to them.
    Jul 2017
    Quote Originally Posted by BlueCheesehead View Post
    The dropouts you have look to be for solid axles. Is this a Surly frame? Which one?
    That looks like it would do the trick. Thanks for correcting my google-foo-failings
    Yep, its a surly BFD. This is the axle. I'm not sure what the right word is... is "through bolt" correct?
    Jul 2017
    Pics of BlueCheeseh's recommendation:
    https://surlybikes.com/parts/small_p...dapter_washersName:  surly adapter washers.jpg
    Quote Originally Posted by high_desert_mud View Post
    Yes, a thru axle, but one that utilizes a dropout like a solid axle would. Unique for sure.
    Again, I would talk directly with Surly. I suspect you are going to have to go there for parts anyway.
  1. Will 197mm Wheel fit in a 190mm Rear Fatbike?
    By Fattyrider38 in forum 26+/27.5+/29+ Plus Bikes
    Last Post: 06-12-2018, 05:53 AM
  2. Replies: 33
    Last Post: 04-22-2018, 12:41 PM
  3. Replies: 3
    Last Post: 03-10-2015, 07:41 PM
  4. Replies: 0
    Last Post: 03-06-2015, 07:58 AM
  5. 190mm rear hub for a 197mm frame?
    By Rich24 in forum Fat bikes
    Last Post: 10-14-2014, 07:34 AM
Members who have read this thread: 24
