Results 1 to 24 of 24
    Feb 2015
    Accurate reading low pressure pump
    Hello ya'll.
    Ne guy on this site, and new to the fat bike world, wondering if any of you can recommend a high quality Accurate reading presta valve air pump??
    The Park tool pump I have s a piece of crap, I cant tell if i have 5psi or 20!!
    Dan
    wjh
    wjh is offline
    Feb 2012
    Reputation: tundratrader's Avatar
    I think the joe blow has a model with low pressure. The gauge referenced is good as well.
    Feb 2015
    Thanks guys, I just ordered the GH Mieser
    since 4/10/2009
    Reputation: Harold's Avatar
    I don't think you'll be able to get more precise than this one:
    SILCA SuperPista Ultimate Floor Pump The Finest Bicycle Floor Pump The world has ever seen
    FWIW, I have a Meiser gauge and the same cheap floor pump I've used for over a decade. or an air compressor.
    Jul 2013
    I use this Topeak one which seems to work well:
    Topeak Smart D2 Digital Gauge - Black: Amazon.co.uk: Sports & Outdoors
    It certainly seems far more accurate than the gauge on my track pump pressure gauge.
    John
    2014 Trek Fuel Ex 8
    2015 Trek Farley 6
    2016 Trek Stache 7
    Reputation: Hunyak's Avatar
    Dec 2014
    I bought a 0-15 psi gauge for $5.00 on eBay and resurrected my old Joe Blow floor pump. Now I have a dedicated pump for my fattie.
    I've got a blue oval digital Schwalbe gauge and I'd recommend against it. First the shape makes it awkward to hold and press against the valve. Second the valve fitting is very tight making it difficult to get it seated for a reading without letting out a bunch of air. Third the auto shutoff is very fast, not even giving you enough time to tighten the nut on one valve and open the next one.
    Also I'm not sure when the lower limit is on it, but quite a few times its failed to give me a reading at all around 3 psi. Though for low pressure inflation I mostly go by feel / putting weight on the bike and watching tire deformation.
    I had one of those accu-gages but killed it by using it on my mountain bike. I thought my tire pressure was within the rated range, but I was off ... oops.
    Just wondering why you need an accurate pump? I've only ever pumped mine up to 10-12 on whatever pump I use to start the day, then while riding I go by feel. On my regular MTB I'm concerned about the pressure, but never have been for the fat bike.
    Aug 2010
    Quote Originally Posted by Boone701 View Post
    15 or 30psi?
    Sam Adams Fan
    Reputation: DG40's Avatar
    Feb 2014
    Ordered the mieser 15 psi yesterday. Last one in stock where I bought it. These 15psi gauges seem to getting hard to find.
    I have a 15psi gauge for my ATV that I bought from the local motorcycle dealer but the presta-Schrader adapter doesn't work well at all for me.
    Aug 2010
    It looks like the Meiser has a bleed function? That would be handy if you don't have to remove gauge between readings.
    since 4/10/2009
    Quote Originally Posted by racefit View Post
    Yes, it does bleed. I usually overinflate with my pump intentionally, then bleed off with my Meiser.
    is buachail foighneach me
    Reputation: sean salach's Avatar
    Quote Originally Posted by Wide_Open View Post
    I asked the same question years ago to people concerned with knowing exact psi numbers. They just like to know. You've gotta leave them to their geekery. None of them are going out and taking enough samples of snow density, surface pressure, surface temperature etc to generate anything tangible to base their precise estimations of the perfect psi level off of. It just comes down to them liking to know and liking to fiddle with it, in the hopes that they can come up with numbers that will help.
    Reputation: Tripower's Avatar
    Jan 2011
    I have found the accuracy of the gauge to be secondary to the repeatability. In other words, I am not really interseted in the gauge giving me the exact psi. I want the gauge to be ale to repeat itself time after time.
    Quote Originally Posted by Tripower View Post
    This. It's not the number that's important. It's getting to what number I feel comfortable in so I can get it back to the same number every ride.
    Cactus Cuddler
    Reputation: tehllama's Avatar
    Jul 2013
    Go digital - same deal with sprint car tires, the expensive bespoke low pressure gauges are basically still less awesome than the basic digital ones that can at least produce consistent results down to 5psi. The calibration may not be perfect, but repeatability is really what's wanted for both applications anyway.
    Reputation: NorthernMN's Avatar
    Feb 2013
    +1---it's cheap and accurate! Can't beat it!
    Just get out ride it & have fun!
    ATV shops
    Sep 2014
    Quote Originally Posted by NorthernMN View Post
    I have this and a Topeak digital and they line up well every time. I think the Messier is handy at 5 psi and below just because of it's sensitivity.
    Jul 2013
    I find pressure is a lot more crucial on the rigid fat bike compared to my full suspension bike and the reason I wanted an accurate pressure gauge is because I didn't know where to start pressure wise while my normal MTB, plenty of the others in my group were able to help with what the feel should be.
    John
    2014 Trek Fuel Ex 8
    2015 Trek Farley 6
    2016 Trek Stache 7
    Reputation: efuss's Avatar
    Dec 2011
    Feb 2015
    I have the topeak D2 which I'm generally happy enough with. It's light and pretty accurate. I found it a bit fiddly with presta valves, I'd have to try a few times to get a reading while releasing a chunk of air, however you can unscrew the front face where the input hole is and remove the internal spring, which makes it a lot easier to use without releasing too much air. I guess you could install a weaker spring too. Don't do this if you need to use schrader as well though.
    May 2014
    The PR30BX was recommended to me by Acme Bicycles in Rapid City, SD. Although I've only had it for a few weeks, it seems like quality gear. The bleeder valve is very useful. Light weight, it is not.
  1. Replies: 7
    Last Post: 01-10-2015, 11:43 AM
  2. Air Pressure Gauge Not Reading
    By Edcft in forum Wheels and Tires
    Last Post: 12-31-2014, 06:37 PM
  3. How accurate are digital pressure guages?
    By FM in forum Wheels and Tires
    Last Post: 07-28-2011, 12:34 PM
  4. Monarch 4.2 Not Reading Pressure?
    By bavarian3 in forum Shocks and Suspension
    Last Post: 05-31-2011, 08:34 PM
  5. Nashbar pump psi reading?
    By Josh-L in forum Wheels and Tires
    Last Post: 05-08-2011, 11:36 AM
