Results 1 to 2 of 2
    907 with rear racks
    Looking for a rear rack for my 2012, 907. Pictures would be appreciated.
    Thanx!
    Reputation: druidh's Avatar
    Here is a photo of my 907 with rack.
    It's a fairly cheap/basic/generic MTB rack but is easily wide enough for the seatstays.
    The nearside stay attaches on the outside of the seatstay - the farside stay attaches on the INSIDE of the seatstay. This keeps the rack centered.
    I had to cut the vertical rack stays to get the rack a bit lower. They normally have three holes for adjusting the height. I made my cut just above the bottom hole, then added another hole much higher. I had to cut the piece of rod that fits inside the stay too, by about the same amount.
    Rather than attaching to the upper rack mounts on the 907, I used a Giant rack-mount seat-clamp. This makes the routing of the top stays a bit less tortuous. This may not be a problem on larger frames (mine is a medium) as the upper rack mounts will be a little higher.
    I've extended the usefulness of the rack as a fender/mudguard by using an old RRP neoprene fork fender at the front and a cut-off section of a frame-mount (crudguard-style) fender at the rear.
    It's a bit cobbled-together but it works fine
