Results 1 to 15 of 15
    Dec 2013
    9 Zero 7 Rear Hub Bearings
    Anyone know the bearing sizes for the 9 Zero 7 190mm rear hub? Both hub and freehub..thanks
    I think this link has some useful info.
    9:ZERO:7 Rear Hub Junk. New Personal Record
    Rocking on a Rocky
    Reputation: RockyJo1's Avatar
    Look up The hub doctor on ebay I bet he will have a prepackaged set.
    It doesn't matter what I ride as long as I ride it Rubber Side Down●~●.
    turtles make me hot
    Reputation: NYrr496's Avatar
    I'll tell you what size bearings go in a 907 hub...
    Unlace the 907 hub and lace in a Hope.
    I like turtles
    Feb 2006
    Quote Originally Posted by NYrr496 View Post
    Unless you are just practicing wheel building for when you lace a real hub to that wheel, not sure why you'd choose a Hope, unless you just like wheel building and can't wait to do it again.
    ^boomroasted
    turtles make me hot
    I know people keep bashin' Hope hubs but I replaced my 907 with a Fatsno and it's been fine.
    I like turtles
    Feb 2006
    Hope's fat hub failure rate is only second to Specialized. Much like Specialized hubs, you'll meet some people who have had good luck with them, but overall, they have proved themselves to be very unreliable. At this point, it isn't even debatable anymore.
    not only did litespeedaddict provide the roast, but he also brought the potatoes and carrots too! Time for lunch HOPE!!
    Rocking on a Rocky
    What's the problem with hope hubs? Is it bearing quality?
    turtles make me hot
    I couldn't tell you. I know to run an XT cassette on mine and I clean and lube the driver a couple times a year and it works.
    My 190 one has been fine and I have 135mm hubs on a couple other bikes with zero problems.
    I actually just bought a 130mm Chosen hub (same as 907) for my Dahon folding bike with 20" wheels because I can't imagine I could harm it.
    I like turtles
    Quote Originally Posted by RockyJo1 View Post
    Users of 170 and 190mm Hope hubs have experienced a higher than average failure rated when compared to hope 135mm hubs, based on internet feedback.
    Reputation: schnee's Avatar
    Shall I relate how I ripped the axle and spider clear off of a Hope hub one time?
    Clydesdale + 29er + granny gear + steep incline = BOOOM
    This, and the 135mm is more durable than the fat sizes?
    Go DT Swiss. Trust me on this - I've hauled my Salsa Vaya up 6k feet in one day with 280 pound me and 45 pounds on the bike. It can handle torque far better than Hope.
    Dec 2013
    I've got a mixture of 9 Zero 7 and Hope on my bikes, used both for years...I've had better luck with the Hopes than friends of mine, 9 Zero 7 hubs have been great for a couple of years..need to replace the bearings now...does anyone know the sizes?
    Attached Thumbnails Attached Thumbnails 9 Zero 7 Rear Hub Bearings-image.jpg
    turtles make me hot
    I used to have access to hubs to check things like that. Store closed up and moved to Idaho.
    It honestly takes about a minute to take the end caps off a 907 hub and see what size the bearings are.
    I like turtles
  1. Replacing rear hub bearings (joytech)
    By arisaast in forum Beginner's Corner
    Last Post: 06-27-2013, 01:58 AM
  2. I keep destroying rear hub bearings.
    By Phillbo in forum Arizona
    Last Post: 10-10-2012, 07:03 PM
  3. Rear Hub bearings
    By petey49 in forum 29er Components
    Last Post: 04-27-2012, 10:03 AM
  4. Anthem Rear Triangle Bearings
    By Jamone in forum Giant
    Last Post: 08-29-2011, 11:15 AM
  5. Replacing Bearings Rear Hub Revolution 36
    By gideon in forum Transition Bikes
    Last Post: 05-14-2011, 09:13 AM
