Results 1 to 34 of 34
Thread: 9:zero:7 build
    9:zero:7 build
    I am planning a new bike build.
    9:zero:7 135 mm frame with sliding dropouts
    Carver carbon fat fork
    Alfine 11spd rear
    Marge lite rims
    Shimano xt m785 brakes
    I now have to decide on a few further bits.
    Front hub - possibly a Hope fatsno. I do have a spare CK ss ISO hub in my parts bin but as I am unlikely to be touring or similar it seems overkill to have a rear wheel up front too. Any reasons to use something other than the fatsno hub with this fork?
    Crankset - looking for something that is ideally external BB, but has to fit the 100 mm BB shell and give a decent chainline. It appears the alfine cranks won't do this.
    Tyre choice - the frame is specced for four inch tyres, so thinking about a Fat Larry or Huskder Du. The bike is mainly to be used for trails, then beeches and sand.
    Other parts - should I go for a Hope build - headset, bb, stem, seatpost etc, or use a combination of Chris King and Thomson bits.
    Any help/advice would be gratefully received.
    Thingamejigger
    Reputation: Flying_Scotsman's Avatar
    Sounds like it will be great I went for Hope / Thomson bits myself....
    You could even get hope brakes to match the hub!
    i have the same shimano brakes on my 29er and the bleed kit and fluid for them
    am struggling to find an appropriate set of cranks here in the uk, 100mm external bb would be my preferred choice
    Reputation: druidh's Avatar
    My Alfine-d 135mm 9zero7 frame uses a raceface crankset. I've used a Phil Woods Philcentric BB for chain tensioning but since went 2x11 with an Alfine tensioner. Eitehr way it works fine.
    FWIW I chose drilled Rolling Darryls and love the Husker Dus. I mostly ride trails, not beach.
    Thingamejigger
    Raceface or truvative both do 100mm external bearing bb's and cranks, you can get them here in the uk no problem.
    which model of raceface cranks would you suggest?
    PRETENDURO
    Quote Originally Posted by dancing james View Post
    My recommendation would be the Atlas cranks. You can still find some online retailers who have some of the anodised ones in stock (red, blue, orange, gold, etc.).
    QUOTE from MTBR.COM: You have given Brewtality too much Reputation in the last 24 hours, try again later.
    Reputation: thickfog's Avatar
    Oct 2010
    This site is your fatbike friend: http://fat-bike.com/2013/06/first-lo...bike-crankset/
    Sent from my SCH-I535 using Tapatalk 4 Beta
    CRAMBA Chairman
    Thingamejigger
    Here is a uk supplier:
    Race Face Turbine Fat Cranks Arms & BB 100mm
    This place has e13 100mm cranks and the external bb
    Bikes | Mountain Bikes | Road Bikes | Cycle Clothing | Tredz Online Bike Shop
    Happy shopping!
    Reputation: Wombat's Avatar
    The Truvativ 100mm Howitzers are external BB. You can match them to any ISIS crankset. A quick search found the BB for 52 pounds, but it might be cheaper getting it from the US, even with postage
    Tim
    i am thinking of getting the raceface turbine cranks, which chainring would people suggest to work with the alfine. is there a 104 bcd single speed ring that will work best with the alfine sprocket
    Thingamejigger
    RaceFace Single Non-Shift Chainring | Buy Online | ChainReactionCycles.com
    A single speed ring, you might want to add a bash ring.... are you going to be doing much riding on the beach??
    the costs of the build continue to spiral! any suggestions for a bashguard too?
    Thingamejigger
    RaceFace Light Bash Ring | Buy Online | ChainReactionCycles.com
    Wiggle and Chainreaction is your friend.....
    alternatively if you want to take the hassle out of it go and see Tim @ Sideways Cycles... he sells 9:zero:7 frames along with the lovely carver carbon forks and would keep you right!
    have recently lost patience with wiggle, they changed courier company and UKmail are a bunch of oxygen thieves.
    Tim has been a great help so far with many aspects of the build
    mildly shocked that the bashguard costs more than the chainring!
    Thingamejigger
    I just got a thomson stem from wiggle last week and royal mail delivered it.... I use wiggle as they deliver faster than Chainreaction but if they are using ukmail, which will be a pain if I am not in, then I will stop using.
    I got my bike from Tim and he was great, used his 'off the peg' spec as a starter with a few tweeks and since then have been changing bits and bobs as I go along.
    9:zero:7 build-8962756864_cf4fb8df06_b.jpg
    So thanks to the advice and information from here, mtbr, Tim at Sideways and Bobby at Kinoko it appears the spec for this has been resolved.
    Raceface Turbine cranks
    Hope BB and headset
    Hope Fatsno front
    Husker Du tyres
    Thomson stem, seatpost and bars
    More than a little excited
    Hope to have the frame fully dressed by next week.
    Also props to smllfrry for sending me some grips to match the black and white build.
    Thingamejigger
    Great stuff, will be interesting to see the hope headset with the matching frame and fork?
    I was into see Tim today and treated myself to some Knards for the summer, he was trying to tempt me into the lovely Thomson bars but I managed to keep my money in my pocket
    my frame and fork were still with him today, due to be posted tomorrow
    There is what appears to be a bit of a problem with my frame. The drive side of the BB is threaded with a British thread, but the non drive side is Italian threaded.
    Has anyone else encountered this problem and how did they resolve it without resorting to buying two different bottom brackets?
    Thingamejigger
    Tim fitted my BB for me as he said it was awkward
    Scott at 9zero7 has responded to my emails amazingly quickly, so hope we can come to a speedy resolution soon.
    Thingamejigger
    Great stuff, how did they manage to put 2 different threads in??
    No idea, they don't understand so want the frame returned. Problem is Sideways are on holiday until 19th July and I am getting bored of waiting. I am not good at being patient. Have had other shenanigans to deal with, such as finding a pair of marge lite rims in the UK, Hope saying they were now making 100mm BBs but not actually doing so, UK distributor not having Thomson carbon bars in stock....
    Any other 135mm offset frames with sliding dropouts that people could suggest? I have all the parts to hang on a frame.
    Thingamejigger
    Your looking at a pugsley, or a moonlander. That about it for the 135mm spacing.
    neither of which appeal...
    really frustrated by the whole thing right now
    Thingamejigger
    Correct, hang in there.... the wait will make it even better when you swing your leg over the finished bike!!
    Resolution is not happening as quickly as I had hoped for.
    Despite it being clear that there is a manufacturing flaw I have had to push quite hard for 9zero7 to agree to pay for the cost of returning the frame to them for them to inspect.
    Even though a video has been sent to them showing the problem with the BB and how it has been produced with an Italian threaded non drive side. They have now agreed to cover the shipping costs but it does not look like they will send a replacement until they receive the one that is not fit for purpose. I am finding the process quite frustrating as I'd like to get a useable frame ASAP.
    FWIW, I had to return something to 9zero7 and there was no quibble about postage costs. I think your major problem here is that you bought the frame in the UK. As far as 9zero7 are concerned, their relationship with Sideways will be that they should be handling all UK-based issues. Their pricing to Sideways will likely reflect this. They are now having to deal directly with you, something they really shouldn't have to do. If you were dealing with Sideways it would be up to them to source a new frame for you and that wouldn't be dependent on the old frame hitting the US first.
    I appreciate that, but given the frame has clearly been shown to be faulty I am not clear as to why a replacement can't be shipped to me, until the faulty one has actually been received.
    The same outcome will be achieved, but just a little bit faster.
    Thingamejigger
    By them asking to do it this way it makes sure you return the original and dont just keep it once you have the replacement..... I am sure this would not be the case but there are a few chancers out there who would!
    i had offered to pay for the replacement and them to reimburse me
    no dice
    Thingamejigger
    How did you ever get on with this build?? I am hoping by now you have are enjoying the ride??
    Pictures please?!
    I don't have any suitable photos but this is getting regular use.
    Alfine 11spd is working well and the bike feels so comfortable to ride, it just ambles over anything put in its path.
  1. First SS bike/build, putting together build list...
    By Nubster in forum Singlespeed
    Last Post: 06-15-2013, 07:12 AM
  2. niner build help newbie to build world
    By desflurane in forum Niner Bikes
    Last Post: 12-18-2011, 04:19 PM
  3. 1996 Dirt Research Kobuk Build (Updated build pics!)
    By fallenleafs in forum Vintage, Retro, Classic
    Last Post: 09-18-2011, 03:28 AM
  4. Soul Cycles Clydesdale Build: My First Bike Build
    By Shocker99 in forum Clydesdales/Tall Riders
    Last Post: 06-21-2011, 03:16 AM
  5. Yeti 575 2010 build Sram xo build
    By britishboy in forum Yeti
    Last Post: 05-02-2011, 04:28 PM
