That would be the difference in what you have to give you no chain rub.
Where did you come up with the washer is it a bike part or hardware store item?
Correct. This is why I have chain-tire clearance with full ten speed. It is just a carbon steel washer that I got when I visited Craig Smith at MendonCycleSmith for my Lefty. It is nothing special, I don't think it is even bicycle specific. Just a flat washer 1/16 th thick with a big enough ID. to go over the crank. Probably get one at any hardware store.
Thanks again!
The MWOD for a moonlander comes with one of those washers for both sides.
I will locate a washer tomorrow and put this issue to rest.
what bearings are you using the ones that came with mine are black
Thanks again!
The bearings that came with the crank lasted one ride through some deep water and set up like concrete. I changed them out for a set of Shimano bearings. Can't remember if they were road or mnt. I work part time at a local shop so I just went through the stock until I found a set that fit. The inner seal was much tighter on the crank so I think they keep water out better from the inside any way.
First real ride on my Tusken, just a quick spin after work. Thanks to the guys at fatbikes.com for creating this animal. Cant wait to get more quality time with it during Christmas holidays.
Did I mention that it is completely silent when in use?
(sorry for crap photo quality, mobile phones...)
im 6 ft what sz? i have an opertunity to grab a xl frame cheap would that be a good sz im between a lrg & xl ,i have a lrg Turner spot and feels like i could go xl but different brands differ in sz a bit.
thanks
thanks
I am also 6' tall, and I started fatbiking riding a size large Pugsley (ran a Thompson setback seatpost), and now am on a size large 9:zero:7… no need to run a setback seatpost, everything feels just fine. My inseam is around 33.5" however, I’m kind of a long-legged freak. I had a size extra-large Santa Cruz Superlight I used to race, but I consistently got a backache after each race and training ride—this was what made me consider just trying out a size large. But yes, from manufacturer to manufacturer the geometry of “size X or Y” varies.
QUOTE from MTBR.COM: You have given out too much Reputation in the last 24 hours, try again later.
thanks
According to this size chart that can be found at fatbikes.com, you should be choosing the large frame. At 6ft I ride a large 9zero7 with a 65mm stem and a slight setback seatpost in order to attain a center of gravity that is a bit further back. The size and geo are spot on. I would not even consider getting an extra large frame unless I wanted to maximise the space in the main "triangle" to house a larger frame bag. With the large, as opposed to the XL, you will also appreciate the lower stand over height of the frame and thus maintain your ability to sire children if you so wish to.
When in doubt and falling in between frame sizes, I have held it as a general rule of thumb to always go with the smaller option. It is easier to adjust a bike to make it a tad "bigger" than to make it "smaller" if you catch my drift.
End of my 2cents.
Like Porkstacker, I am getting my wife a 9:Zero:7 for Christmas
Can someone help an old singlespeeder get a clue? What front derailleur do I need exactly? I'm looking at SLX level. Currently it has a SLX Shadow+ rear derailleur, 9 speed SRAM chain, 9 speed Shimano cassette, King BB, and Middleburn 2 piece crank just in case compatibility matters. http://www.flickr.com/photos/bikecen...n/photostream/
Can someone help an old singlespeeder get a clue? What front derailleur do I need exactly? I'm looking at SLX level. Currently it has a SLX Shadow+ rear derailleur, 9 speed SRAM chain, 9 speed Shimano cassette, King BB, and Middleburn 2 piece crank just in case compatibility matters. Bottom Bracket Area of 9:Zero:7 | Flickr - Photo Sharing!
I am 5'-7" and the small is just right. Prior to getting my 9:zero:7 I rode a small Salsa Mukluk. It only had a 90mm stem which felt a bit crampt. On this bike I have a 110mm stem which puts my weight out over the front wheel and is much more compfortable. You have a very nice looking bike!
2nd year for mine
still no regrets on getting a small
I'm 5'10 going on 5'9
Hey your bike looks sweet, I'm planning on ordering one myself and working to figure the proper sizing, most likely a small. I was surprised you are riding a small. I'm 5'7", 29" inseam , 68.5cm top of saddle to the center of the bottom bracket spindle. What I you saddle height as shown in your recent picture?
Merry Christmas,
Jeff
Merry Christmas,
Jeff
I will measure tonight when I get home from work
I know my 400 mm post is right at about 100mm insertion into the fram
I have a measured 32 inch inseam
I went small because bdundee trys to rides a medium and it just looks like a circus act
He is overcompensating for something
Sj
P.S. bdundee stop playing with my light you are going to wear it out
Originally Posted by Tone's
mate if theres grass on the wicket its time to play cricket.
Next time chop it for all its worth...
Merry Christmas,
Jeff
I'm 5'7" and ride a medium (as recommended by Fatbikes.com)
Merry Christmas,
Jeff
I tried to reply to your question to me, but the Forum said I need to have 3 more comments before I can reply to a private message. I measured my bike, and here are the measurements you asked for:
1. The distance from the center of the bottom bracket spindle (crank center) to the top of the seat is 68 cm (26- 3/4")
2. The handlebar drop or rise compared to seat height.
*The height of the top of my seat from the ground is 95.89 cm (37-3/4")
*The height of the top of my handlebars from the ground is 100.33 cm (39-1/2")
I have ridden this bike a lot in the past couple of weeks, and I am VERY happy that I went with a "small" frame. I did put on a 110 mm stem to give me a bit more room. I heard that it is better to err on the side of smaller when selecting a Fat Bike size. Good luck!
Hey thanks for the info, your fit is identical to what I'm after, looks like I will go with my orignal gut feeling and order a small. BTW- how tall is your stack of spacers under the stem?
Jeff
