Results 1 to 11 of 11
    Anchorage, AK
    Reputation: Lars_D's Avatar
    70mm Uma Rim Problem
    I can't seem to get tires to seat properly on this rim with tubes. I have tried both Dillinger and Husker Du tires and no matter how much pressure I add the tires don't seat. With the Surly rims I add apply a little soapy water air up to 25-30 psi and the beads pop right into place. With the UMAs no matter how much pressure I add the beads don't seat properly. Has anyone else had this problem?
    --Peace
    aka bOb
    Reputation: bdundee's Avatar
    Maybe try something slippery-er.
    I have this problem. It is random, sometimes they seem to pop, sometimes not. I have Endos and Nates.
    How high have you gone with the pressure? It seems like they'd have to pop at some pressure....60, 70 psi?
    Reputation: veloborealis's Avatar
    No trouble here, so no advice to give. My '09 uma 70s have accepted endos, larrys, nates, huskers, and floaters with little trouble. had to use soapy water only once. big fan of this rim. still true after 4 seasons and i'm a clyde.
    Veni vidi velo!
    Fat!Drunk!Slow!
    Reputation: JordyB's Avatar
    Oct 2007
    I sometimes have to go up to 40ish PSI but I also seat dry. They eventually pop into place. Same as Velo, true as they day they were laced, super clyde.
    Reputation: BurkeVT's Avatar
    Jul 2003
    I usually set up my '10 Uma's w/ soap, and only pump to 30 psi. Once there, I eyeball the beadline to look for any spots that haven't seated, and then "massage" the bead on. This results in a very satisfying "pop." This method has worked w/ several Surly sneakers and a pair of Dillingers.
    I think the beadlock on the Uma's may make them a bit tougher to mount compared to others, but I'm glad it's there.
    -Chris
    Quote Originally Posted by BurkeVT View Post
    I hadn't tried working it in like this - I'll give it a shot.
    Reputation: Steve Balogh's Avatar
    I put a little soap on the bead, and use a water bottle to spread a tiny amount of water to carry the soap around. I haven't tried it, but I believe Schwalbe makes some sort of tire lubricant.
    Reputation: Schott's Avatar
    Nov 2012
    Massaging is the way to go. I doubt it will fit fattie, but this makes life easier for your favorite wrench to do the job. http://www.treefortbikes.com/product...FQya4Aodjn4Aaw
    "You're like a Ferrari engine driving a dump truck"
    It aint gonna ride itself
    Reputation: MauricioB's Avatar
    Oct 2007
    I used Pledge furniture polish on the rims and got Larrys and Endos to seat usually just south of 25 psi. Wiped the beadlock ledges out good before mounting the tire.
  1. Ripley with 70mm or less stem? Handling?
    By canuck_tacoma in forum Ibis
    Last Post: 01-03-2014, 07:49 AM
  2. Thomson X4 70mm stem -- $49.99
    By eurospek in forum Where are the Best Deals?
    Last Post: 05-02-2013, 05:09 PM
  3. 70mm Speedway rim problem?
    By davefj40 in forum Fat bikes
    Last Post: 06-12-2012, 05:44 AM
  4. Anyone with a Big Fat Larry on an Uma II 70mm?
    By VT Mike in forum Fat bikes
    Last Post: 09-20-2011, 10:33 AM
  5. 70mm to 100mm?
    By campykid in forum Fat bikes
    Last Post: 01-15-2011, 01:03 PM
