Results 1 to 10 of 10
    Reputation: gcappy's Avatar
    4" NATES on Clownshoes
    Any body done this? Will the rims make the tires too wide?
    I can't see any reason why they'd be to wide.
    I had some Devist8r's on the Walmart 100's, which is pretty much the same combination.
    Reputation: Saul Lumikko's Avatar
    Oct 2012
    I've read reports of this combo with pictures. The tire itself isn't really problematic, but the rim is so wide it's vulnerable to rocks if you ride in rough terrain. Any particular reason not to use the Bud and/or Lou instead, which were designed for the Clown Shoes?
    Reputation: duggus's Avatar
    ...Be careful what you're looking at because it might be looking back...
    Reputation: yxan's Avatar
    I have ridden 100mm rims for a while now and have had no issues using Nates on them.
    works great! But if you haven't bought the Nates yet and have the clearance, you may find yourself wondering why you didn't buy Bud and Lou -
    Reputation: coastkid71's Avatar
    I put my Nates on my Moonlander to see what they looked like. But side walls were so low the rims were far too exposed to being damaged to ride them anywhere near rocks or other potential objects that could cause damage
    plan it...build it....ride it...love it....
    http://coastkid.blogspot.com/
    I ran Nates on Clownshoes/Moonlander for about 8 months. I really liked them a lot. Geared up I weigh about 200#. The optimal weight for me to keep the tires from being too bouncy was about 5# to 6#. But I had to run 7# to 8# or else I'd get pinch flats. I ride almost exclusively rocky rooty singletrack. Loved the traction compared to the BFL's. (Off of the pavement I am no fan of the BFL's.) The Clownshoes do take a bit of a beating with Nates on them but it's mostly cosmetic. Lou and Bud have a bit of a weight penalty but they're the best tires I've used so far. Especially Bud -- Bud is awesome.
    If you put Nates on your bike you will really enjoy them. If you can afford a Bud and a Lou they are even better. (If a little heavy.)
    This is my Moonlander with Nates:
    Thanks guy's. I would love to run Bud and Lou but they don't fit this current frame,9-0-7, 170. The BFL's fit as long as I keep the pressure below 10 psi. Any thing higher and they rub both the chain and seat stays. I am going to put the Nates on the 9-0-7 because my wife stole the bike from me and I want her to have more traction. I will order a new 9-0-7 for myself with the 190 rear spacing and run Bud and Lou on that.
    Reputation: lancelot's Avatar
    They work great! I have a set slightly used if you want a set.
    The LPG
  1. Bud on Clownshoes Tubeless Works
    By alphazz in forum Fat bikes
    Last Post: 10-24-2014, 12:50 PM
  2. Another Tube Thread! (for Clownshoes)
    By Volsung in forum Fat bikes
    Last Post: 03-13-2013, 06:04 AM
  3. Clownshoes on Mukluk or Moonlander?
    By Zeitlupe in forum Fat bikes
    Last Post: 01-08-2013, 04:17 AM
  4. Nates on clownshoes?
    By Boatracer in forum Fat bikes
    Last Post: 10-17-2012, 12:53 PM
  5. Tubeless Big Fat Larry's on Clownshoes?
    By gcappy in forum Fat bikes
    Last Post: 09-18-2012, 09:33 AM
