Results 1 to 10 of 10
    Jul 2017
    36 spoke hub, 190/197mm dropouts - does it exist??
    I'm trying to build a very strong wheelset. having more than 32 spokes would be a big benefit there, however i can't find any hubs that support this. They are all 32 or 28.
    48 spoke would be even better!!
    help!
    Contact Onyx, they will build you anything.
    Latitude 61
    Jul 2017
    Quote Originally Posted by 2LO4U2C View Post
    Thanks for the suggestion.
    I emailed them, and you're right Onyx will get me a hub ... it's expensive. $600 something for the 36 hole version, versus already steep high-$400's for the stock 32hole.
    So I suppose the question is answered; but I'm trying to decide if this is worth it. once I get into the 800-1000 per wheel; does that open me up to some other solution that would offer more strength
    For your reference, my options right now look like
    1. Hope pro 4 fatsno 32h + sun ringle duroc 29 40mm 32h ~$450 built, no tire)
    2. Onyx 36h + the same duroc, in 36 hole (nearly $900 built, no tire)
    Discussing those on another thread; is option #3 the most effective way to get more durability in that price range.
    If anyone else comes back with less expensive hub options it would certainly be awesome
    Quote Originally Posted by high_desert_mud View Post
    So are the benifits of four additional spokes worth $450.00?
    Latitude 61
    Rocks belong
    Drop bikehubstore.com an email (or call) and see if they can get you a FB190 in 36h
    FB190 Rear FatBike Disc Hub
    I like 'em long, low, slack and playful
    Anchorage, AK
    Reputation: Lars_D's Avatar
    Try Aliexpress. I found a few options there.
    Sent from my SM-G900V using Tapatalk
    --Peace
    Jul 2017
    Quote Originally Posted by 06HokieMTB View Post
    Done, thanks - they don't carry anything
    Quote Originally Posted by Lars_D View Post
    Try Aliexpress
    Thanks for the suggestion; due to my specific needs (ultra-bomber setup for safety & durability hauling a ~400lb system weight), I'm going to stay away from direct importing. But alibaba is quite a resource if you have the right skills.
    This place needs an enema
    Reputation: mikesee's Avatar
    Aug 2003
    Done, thanks
    BTW, I replied to your PM, basically asking for you to contact me directly.
    Reputation: Luis_fx35's Avatar
    Aug 2015
    The quando hubs on eBay. You can get a set for less than a 100$ (Quick Release, 36holes, 135/190mm)
  1. Which chainring offset for RF Aeffect 190 crank on a fat bike with 197mm rear hub?
    By JackWare in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 09-22-2017, 03:22 AM
  2. Replies: 2
    Last Post: 11-13-2015, 05:51 AM
  3. 197mm Rear Hub Options
    By Negotiator50 in forum Fat bikes
    Last Post: 07-21-2015, 08:53 AM
  4. Replies: 0
    Last Post: 03-06-2015, 07:58 AM
  5. 190mm rear hub for a 197mm frame?
    By Rich24 in forum Fat bikes
    Last Post: 10-14-2014, 07:34 AM
