Results 1 to 3 of 3
Thread: 29+ fatbike
    Reputation: funnyjr's Avatar
    29+ fatbike
    Anyone know what the minimal chainstay length is for a fatbike in order to fit 29+ Knards/ Dirt Wizard on rabbit holes?
    Re: 29+ fatbike
    I also have been wondering this.
    Jan 2013
    The only experience I have with this is on my pugsley. I had to shave down my front derailleur a little to fit the rabbit hole and knards on my frame. Surly list the chainstays as 17.6'' which is also the same on the Krampus. I would say that is pretty close to the min if you want to run gears in the front. If you are running a 1x setup, you might be able to get away with slightly shorter.
    Just a heads up, the chainstay or seatstay bridge has been an issue in some fat frames with 29er+ wheels.
  1. Replies: 9
    Last Post: 12-03-2014, 01:37 PM
  2. Best Fatbike for $$$$
    By richccc in forum Fat bikes
    Last Post: 09-15-2013, 02:06 AM
  3. New Fatbike Build (LBS or experienced FatBike shop)
    By synthesis in forum Fat bikes
    Last Post: 02-23-2013, 03:56 AM
  4. Best all around fatbike
    By buconine in forum Fat bikes
    Last Post: 09-30-2011, 01:21 PM
  5. Replies: 2
    Last Post: 06-06-2011, 05:12 AM
