Results 1 to 28 of 28
    29+ 3.0" contact patch -vs- 26 inch 3.8" contact patch
    How does a 29+ 3.0" contact patch compare to a 26" wheel 3.8" at low psi?
    Anyone measure both?
    How about wheel weight?
    Have not measured, but have seen both side by side. A 3" Knard is dwarfed by a 3.8" Knard. Not only is the 3.8" almost an inch wider, it is also a lot taller than the 3".
    That is all I have to offer.
    I ride the Krampus when there's only an inch or so on the ground, and compared to my pals running Dillingers, I'm dead in the water on climbs. Knards run out of traction really quickly compared to fat tire. Now, compared to the guys on regular 29" tires, the Knards kick butt. It's definitely an in between size, and as soon as the 29" Dirt Whizards shows up, that will be more Krampus tire. Definitely want more traction, especially in the light snow.
    When the snow is deeper, it's back to the Nates and the Fastback.
    The size of the contact patch is largely a function of rider+bike weight and the inflation pressure of the tire. One can run a significantly lower pressure in a 3.8" tire than in a 3.0" tire, so a 3.8" set-up can and should have a larger contact patch. But if you're running the same psi, the size of the contact patches will be nearly identical (ignoring minor factors like tire stiffness).
    A 29+ contact patch will of course be generally longer and narrower than a 26x3.8 contact patch.
    It's hard to get around the extra width of 0.8" of tire and 60mm+ rim so a 29+ set-up will almost always be lighter. That said, I'm guessing you could come up with a fairly light 26" set-up using a 47mm drilled single-wall rim and a Black Floyd.
    Quote Originally Posted by jnroyal View Post
    Thanks. Yeah LOVED the traction, hated the fat bike wide q factor. That's where I am thinking plus size so I can keep the same 73mm bb width. If I ride in snow, it's hard packed and typically a studded 2.0" works as well if not better than true fat without studs. That's my dilemma...
    My buddy has a Krampus and he manages/struggles on most days with the rest of the crew who are all on Fatbikes. That said, he's built like a TDF rider 5'7" and 125lbs soaking wet, with great balance and huge horsepower. He's able to make up for the lack of float in other ways but it's a LOT of work!
    Personally I think you'd just get used to the Q factor after some time on the bike. Admittedly it's an adjustment each season but it's probably good for the body to change things up.
    Reputation: Tibor's Avatar
    a pic from last year... its an 26"x3" tire... but the width should be the same...
    Re: 29+ 3.0" contact patch -vs- 26 inch 3.8" contact patch
    Quote Originally Posted by Tibor View Post
    This pic doesn't really show much. For a more accurate comparison, both tracks would have to be in the same frame, not two different photos shopped together.
    I don't have a Krampus though, so...
    Sent from my Nexus 4 using Tapatalk
    i shot both pics from the same hight... maybe i do a photo tomorrow...
    gazza vs nate...
    is buachail foighneach me
    Reputation: sean salach's Avatar
    There is no way that photochop is anywhere near accurate. How do I know?
    WW '2.55', Stout, Endomorph, all ridden by me, within a 5 minute time frame, no 'photoshop' involved(except the border). Your photo makes the 29 x 3 look 1/3 the width of a Larry.
    endo by anrothardonn, on Flickr
    If you want to measure the contact patch to see what's really happening, don't do it by rolling the tire across snow, lift the rear end up, hop on the bike, and get a non-moving "footprint" of each tire combo. A 26" x 3" Gazzolida at 25psi will be a lot smaller than a 29" x 3" Knard at 12psi. And a 26" x 4" fatty will be bigger than the Knard. But that will show you what's gripping the ground at any given time while you're riding.
    I'll try and get a Knard footprint vs a Nate footprint tomorrow, we've got snow in the forecast tonight.
    Quote Originally Posted by RickyB View Post
    Thanks, yeah ^this^ seems like the smart thing to do.
    I'm not really riding really snowy trails. *MAYBE* a few times a year and as of right now and I can ride my 29er with studded Nokians as fast if not faster in sections than than my friends on their 4.0+ fat bikes (no studs) on the packed out trails.
    Basically I am looking for fat bike traction (more for dry trails) but I don't want a 26" fat bike because IMHO the wide q factor pedals like poop to put it bluntly. Also, I'm done riding 30+ pound rigid bikes. Thinking custom ti 29+ with segmented ti fork in the 20-ish pound range on the 52mm Stans 29er hoops they have coming out some time soon.
    If I have to go 26, then I have to go 26 - but I don't want the rubber weight, rim weight, and wide q factor that goes along with it. The Stans light weight 500-ish gram 29+ rim and Knards, Dirt Wizards or soon to be released Vee 29+ sure look appealing. So that's why I am interested in what the contact patches of say a 170mm bb 26 inch 4.8 look like compared to a 73mm bb 29+ 3.0" look like.
    <img src="http://1d8piv1xedxt3k9gin22z4pqb30.wpengine.netdna-cdn.com/wp-content/uploads/2013/09/fat-bikes-at-interbike-2706.jpg">
    ^Sounds like you are a ww and really have no business in the fatbike world.
    The type of riding you do can be accomplished on a 29+ bike. Leave fat to the types who pay the weight penalty to play in the fun stuff.
    GSJ - if you go back to the fat-bike.com article from Interbike, that 52mm rim is the 26" rim that Stans is making, not a 29er. At 500 grams, and only 52mm, he didn't really do his homework. Fat tires were designed for fat rims, otherwise the shape is compromised. I wouldn't want to push a Nate hard through a corner on a 52mm rim at 5psi, I'd worry about rolling it off the rim.
    Overall weight is a tricky thing, and so is Q factor. I'm going to guess you don't like wide handlebars and short (50-70mm) stems. It took me a while, but if I get in a bike with 26" bars, I hate it now. All my bikes are just over 30", and that's what works for me. I think it opens up my chest and I breathe better, and I have more control of the bike at high speed, not as twitchy as narrow bars for sure. Do I hit more trees? Absolutely, and that sucks, but I know where the tight gaps are, and just need to focus. I'm 5'11" and the wider Q factor doesn't bother me. If I also was road riding, it would probably drive me crazy.
    Here's my bottom line. I started riding a Mukluk2 just for fun. Then I switched to a Fatback with some decent components, and it was more than fun, it was fast, Strava says so. I'm in the process of putting the Fatback on a diet to see what it can really do. It's 31.25 pounds now with Nates on 90mm rims, and the new breed of carbon fatties are hitting 23 pounds. If I get down to 26 I'll be ecstatic, and I'm not giving up my Nates. Other tires roll faster, and are lighter, but nothing grips like a Nate for all year long riding. And yes, I ride this all 4 seasons, along with my Krampus that has front suspension. I'm finding that the more fun I have, the faster I ride, and weight isn't the limiting factor.
    aka bOb
    Reputation: bdundee's Avatar
    I don't think 29+ ever should have been in the fat forum in the first place, they are not fat!!
    aka bOb
    Quote Originally Posted by MiniTrail View Post
    ^ we've had the 3" equipped 1X1s since the start
    can't say they don't belong
    Yeah I guess that makes sense, my first fat bike was almost a 3.0 but everyone said real fat was so much better.
    Someone call the forum police
    nvphatty
    Guest
    I'm surprised they still let us discuss 3.8
    i resemble that
    Jan 2013
    GSJ1973,
    When I got my 29er+ wheels I was surprised by how fat the tires are compared to my 3.8 nate. That said, it feels much different. The volume just isn't there on a 29er+ the same way it is on the 26er fat tire. The ride is completely different. It is hard to say how that platform would do in the snow because there are not many tires available. The knards aren't snow worthy compared to nates and although the dirt wizards look like an improvement, they are still a far way off from the aggressive tire options we have in 26er fat tires.
    Everyone is different with how they respond to Q factor and I felt as though I had made a mistake after buying my fat bike because of the wide Q and my narrow hips. But after an adjustment period of a few weeks it hasn't been an issue and I have had zero knee pain since riding the fat bike. Good luck with your purchase.
    Reputation: lancelot's Avatar
    Quote Originally Posted by jonshonda View Post
    29+ Knard is almost 50mm larger in diameter than a 3.8" Knard. It's even taller than a Bud. I own both but prefer to ride my fattie in snow and my 29+ in dirt.
    http://surlybikes.com//uploads/downl...Geometries.pdf
    The LPG
    Reputation: marathon marke's Avatar
    Sep 2012
    What ntm1973 said about hip width being a factor in wide Q factor tolerance makes sense. I also think leg length is something to consider. Even though I have narrow hips (including a fake one after a spill on black ice last year), my long legs might be why I've never had a problem with my Moonlander. Longer legs decreases that angle. I also come from riding 12,000 a year on my road bike, and haven't had a problem making the switch.
    - Mark Ehlers
    The Prodigal Cyclist
    Quote Originally Posted by lancelot View Post
    Sorry, I meant that the physical distance from the inner to outer diameter of the tire is a lot larger. Like the difference from larry to bfl.
    I hear ya.
    The LPG
    Thanks everyone for the input. Yeah, I think I will be more 29+ category since we really don't have snow that sticks around and the ^above^ quote sums it up. I really do like the traction but the Q factor, bike and wheel weight I can live without If I have no aspirations to ride in deep snow or snowmobile packed terrain.
    When is that Dirt Wizard in 29" due to be released?
    Jan 2014
    52mm wide was indeed envisioned for 3" tires or the "plus" market, not 3.8 Nates. For a 3.8, you would generally run a 80mm or wider rim for the tread patch to contact whatever surface you ride on and not have too much oversteer at low PSI. 3.8" tires on 52mm rim is like 32c tires to a triathlete's 15mm rim...foolish. If you need the grip of Nates, you are likely riding softer terrain than the OP is...so different, unique needs and rightly so. As far as the 52mm only offered for 26", this was the first release, as Stan has personally indicated that there will be a second release of 52mm Hugos, but in the size of 29" or 622ERD! Not all fats need be compared and few should be, lest there be reasonable argument to do so. IE you run 3s for one thing, and 4s for another. Op stated he rides on 1" of snow most of the time when there is snow! I don't need my fat bike for that, do you? I may however want a little more traction...hence 29 studs or 3" tire as the compromise. Personally I'd have a weight weenie's 29+ with a spare 29er lightweight wheelset laced to compatible hubs. That way, I can throw on the "pluses" with more grip for snow/dial back the pressure for grip ALSO When I want to trail ride with the friends, I'd throw on my arch or crests with some lighter, skinnier tires.
    Jan 2014
    Have you seen the newish Bontrager Chupacabra?! I know, a blast from posts past! Did you ever buy a bike? These tires run tubeless on a Hugo 29" rim with Sapim CX Ray or Evolution spokes and light hubs would be RIGHT up your alley.
  1. Replies: 64
    Last Post: 09-01-2014, 07:43 PM
  2. Replies: 7
    Last Post: 06-14-2014, 10:29 AM
  3. Contact Patch
    By Cartski in forum Fat bikes
    Last Post: 07-20-2013, 02:52 PM
  4. Replies: 16
    Last Post: 11-23-2011, 06:29 AM
  5. 29er tire contact patch, mud
    By Drea in forum 29er Bikes
    Last Post: 10-05-2011, 11:11 PM
Members who have read this thread: 4
