Page 1 of 16 1234511 ... LastLast
Results 1 to 100 of 1559
Thread: 26x5.05 XXL
    Reputation: Beard of Power's Avatar
    26x5.05 XXL
    Via Instagram from Taipei show.
    __________________________________________________ __
    Bike is the New Black
    Reputation: Velobike's Avatar
    The 6" tyre can only be a year away now...
    Latitude: 57º36' Highlands, Scotland
    aka bOb
    Reputation: bdundee's Avatar
    I'm passing on this one and waiting for the 5.057 version.
    WNC Native
    Reputation: nitrousjunky's Avatar
    So will it be 4.5" wide?
    couldn't resist...
    "I ride to clear my head, my head is clearer when I'm riding SS. Therefore, I choose to ride SS."~ Fullrange Drew
    Allegedly measures bigger than stated size so maybe 5.12"
    Professional Crastinator
    Reputation: Fleas's Avatar
    $h!+, my frame is already obsolete!
    -F
    It's never easier - you just go faster.
    Reputation: WSUPolar's Avatar
    Sep 2014
    From that angle that tread looks pretty aggressive, is that the same tread pattern of the other two snowshoe sizes?
    Reputation: AllMountin''s Avatar
    Not sure why they choose to piggyback on the same name that has an established negative association from the original snowshoe, but whatever. Probably a rigid only tire if you want one up front.
    Aug 2014
    Quote Originally Posted by AllMountin' View Post
    I wonder how the size compares to a Bud/Lou, or a Dilly 5? I mean actual width because we all know the numbers on the sidewall really have little relation to the actual tire size, especially when it also says Vee Rubber on it. :-) Nothing against the Vee tires, but my one bike has a 4.7 Snowshoe and a 4.5 snowshoe on it and both are the same tire and only about 4.25 in reality... And they are the same width as the H-Billie 4.25 I have.
    bigger than you.
    Reputation: Gigantic's Avatar
    Quote Originally Posted by Destr0 View Post
    My Snowshoe 4.7 (now rebadged 4.5) is noticeably wider than my H-Billie, easily by a 1/2". Jus' sayin'.
    Sep 2014
    Quote Originally Posted by Gigantic View Post
    Tire snob... :-)
    Aug 2014
    I have all three and swap them out - layed flat they measure within 2mm of each other. Haven't put calipers on them but visually they are identical (I have an H-Bille and snowshoe 4.5 on my Bucksaw as well). I just went back and checked my spreadsheet - the H-Billie measured 242mm wide, the two Snowshoes 240 and 242mm wide at the beads. The two with the same sizes went on my Bucksaw. The other one went on my Sturgis to replace one 72TPI snowshoe... I do see on the tire size .pdf on the "True Tire Size" thread that there is a large variation on the width of the Snowshoes bead to bead: listed ones go from 233 to 245 in measured width. That is 12mm variation on the "same" tire.
    Hooligan
    Reputation: dirtdawg21892's Avatar
    Any other pix? What's the tread like?
    Sent from my DROID2 using Tapatalk 2
    Quote Originally Posted by Optimus View Post
    Hell of a jump, dawg. Even though they're baggy shorts, I'm surprised that you can fit your balls into them.
    Anchorage, AK
    Reputation: Lars_D's Avatar
    I like it.
    --Peace
    turtles make me hot
    Reputation: NYrr496's Avatar
    2XL is a way of life with me.
    I like turtles
    Dec 2014
    Pump it up to 20lbs then let us know the width!!
    djrez4
    Reputation: djrez4's Avatar
    Excellent. This will increase my fatness to proper levels.
    Engearment - Your Gear Concierge
    Reputation: bepperb's Avatar
    My understanding is that the 4.7 and 4.5 snowshoes are the same tire different label, 238~240mm bead to bead. The 4.8 is 260mm bead to bead, the same as a Bud/Lou.
    No doubt this will be a big tire and I doubt it's alone. Lugs look huge but it's hard to say from an obscure angle pic such as this.
    Somebody's got to have a contact there. Checking out the map, they are next to Fox and a stones throw from FSA, Mavic, Hutchinson and WTB.
    Nangang 4F - L1327a
    Go!
    Hooligan
    not FAT free
    Reputation: RFX big foot's Avatar
    Mar 2011
    Quote Originally Posted by Velobike View Post
    i'm waiting with You
    cheers
    Anchorage, AK
    Quote Originally Posted by bepperb View Post
    The Snowshoe XL is a really huge tire. On 100mm rims it didn't fit my Borealis frame unless the pressure was fairly low. My guess is that few frames will fit this tire with 100mm rims. I want one!!!
    --Peace
    Dirt Huffer
    Reputation: AC/BC's Avatar
    I know someone with a frame this will fit.
    Oslo, Norway
    Feb 2012
    Quote Originally Posted by AC/BC View Post
    It is 5.65" at 20 psi.
    32" overall diameter.
    Espen Wethe
    www.kindernay.com
    Kindernay on BikeRumor: https://goo.gl/iQtWxu
    I've yet to see it on an actual bicycle.
    -F
    Elitest thrill junkie
    Reputation: Jayem's Avatar
    2000 grams?
    Reputation: gcappy's Avatar
    I'm going to measure my frame now! I could push a pair of those!
    Sep 2014
    Quote Originally Posted by Espen W View Post
    That's on your 103mm rim, right? What would that make it on a 90mm rim at 8psi? Or 2, even? :-)
    Oslo, Norway
    Feb 2012
    2000 grams?
    Approx 1590g
    Espen Wethe
    www.kindernay.com
    Oslo, Norway
    Feb 2012
    Quote Originally Posted by MaximumX View Post
    Yep, 5.65 on the 103 at 20psi. 5.45 at 3psi. Quickly measured to approx 5.30 at around 10psi on a Sarma 80mm
    Espen Wethe
    www.kindernay.com
    Approx 1590g
    Have you applied the kenda correction factor?
    Oslo, Norway
    Feb 2012
    Hehe, the studded version was 1680g with 280 studs, so might go below 1590
    Espen Wethe
    www.kindernay.com
    You can't handle my rare girth, says the XXL. I prolly can fit it out back, but would need a rigid fork.
    I wonder how wide it is on a 47mm. ;-)
    Reputation: yxan's Avatar
    This is a very cool development and I for one wont bash this tire just because it cant fit my bike bring on the mega tires!! hoping we see much more of this.
    26x5.05 XXL
    Delete
    Pedaling
    Oslo, Norway
    Feb 2012
    Espen Wethe
    www.kindernay.com
    Jan 2013
    wow!!
    Reputation: worldskipper's Avatar
    Jul 2013
    Is that a Dilly 4 or 5 next to it? That is a tire.
    Trust me, I have a beard and gray hair.
    Reputation: watermonkey's Avatar
    Sweet zombie Jesus!!!!
    Reputation: Aceldama's Avatar
    Jan 2005
    So... which new frame/forks are going to fit this behemoth?
    Jan 2013
    how about the same pic next to a lou?
    Add a 26x2.1 next to the 45nrth for the full spectrum of progression.
    I'm almost thinking it's getting silly now. That's a tall tire. IMO, diameter is pushing the limits more than width. Maybe the direction should be 24x5.05?
    Jul 2013
    I think the only frame that will fit this tire right now is my GMC Yukon at the house!
    Jan 2005
    Oslo, Norway
    Feb 2012
    Quote Originally Posted by joeduda View Post
    The D4 measured 3.85 on a 82mm. Here vs a D5 that measured 4.60'' on a CS 100mm:
    Espen Wethe
    www.kindernay.com
    Reputation: Swerny's Avatar
    nvm. my bad
    Mike
    Toronto, Canada
    2017 Trek Farley 9.6 with Lauf
    2017 Diamondback Haanjo Trail Carbon
    2016 Scott Solace 10 Disc
    Sep 2014
    Quote Originally Posted by bme107 View Post
    Truth. I'd love the width, but that's a tall tire to be fitting in a frame for lil'ol me...
    Jul 2013
    Now if they would just make a bike hub that could take a 6 bolt pattern for my SUV, I could have a snow machine!
    Espen, if it would be to much trouble could you take it outside and show it next to a car/truck/Personal Carrier tire. I want to send my dad a picture of a real FAT BIKE tire!
    Jul 2014
    N
    DAAAAAMMMMNNNN... That is a monster! After seeing this photo, I don't see that tire fitting in many current production frames, if any.
    '17 Cutthroat
    '16 Bucksaw Carbon
    '15 Fatboy Expert
    Oslo, Norway
    Feb 2012
    Here vs. a Maxxis Ikon 29 2.2.
    (these are all pics that I took back in Norway. We are in Taiwan at the Taipei show right now, and the 2XL at the Vee booth was mounted on a 80mm.
    Will take the requested pics vs car/truck/Lou tires when back at the office next week
    Espen Wethe
    www.kindernay.com
    is buachail foighneach me
    Reputation: sean salach's Avatar
    WOW! I'm glad I like xc bc skiing, since I'm pretty sure that would still be faster/more fun in conditions that warrant this tire. Should save me some money. That thing is a monster.
    Oslo, Norway
    Feb 2012
    The biggest Lezyne floor pump took 100 strokes to take this one from 0 to 20psi on the 103mm rim. For comparison, the 4.8 with the biggest casing (Jumbo Jim at 265mm bead to bead (this is 315mm)) took 65 strokes. In other words, more than 53% more volume in this one.
    Espen Wethe
    www.kindernay.com
    I dont think it will fit my KX250
    I retract my previous statement. Can't handle that girth. I'm thinking they'll downsize this before it hits production. There is no market for it yet, so who will buy them? That, or make this the 3XL and put it on ice for a bit. Split the difference between this and an XL and you have a marketable product.
    Have you actually tried it on any frame?
    I hope they made a 150mm bb/crank to go with it.
    Oslo, Norway
    Feb 2012
    Quote Originally Posted by gcappy View Post
    I was able to get it into our alminum frame, but it would not turn, since the knobs overlapped with the SS and CS bridges.
    Will build a new frame that will take it (and keep 197 spacing and current 1x cranks (and around 76mm chainline) as well as current Q as well as the current 120mm BB shell.
    That is not doable with a 10/11s cassette, but there are now other options for getting 11 speeds and 197 spacing, though...
    Espen Wethe
    www.kindernay.com
    Oslo, Norway
    Feb 2012
    That was not a bad guess, and could easily have happened if I had not convinced them to keep this one. A new 11sp system will enable the use of this one with current BB/hub/Q standards.
    It might very well be renamed 3Xl and a 'tweener 2XL might show up too.
    Espen Wethe
    www.kindernay.com
    Sep 2014
    Well if you're doing IGH, make sure that frame is belt compatible! :-)
    Nov 2008
    Looks like a nice tire. Hey they should call it XL plus.
    Lucky neighbor of Maryland's Patapsco Valley State Park, 39.23,-76.76 Flickr
    Aug 2013
    I certainly agree with this. Develop a 24" version of the tire, keep the tire diameter similar to 29/29+, still utilize 26er fat wheelsets/ 29er wheelsets for different uses on one frame. It's easy enough to say, but I'm guessing theres more to it than that?
    Not complaining one bit though! Got the tire, the rest will follow! I'm certainly interested in seeing where this goes!
    aka bOb
    Quote Originally Posted by TrailCrawler View Post
    This makes sense^^^^^^^^^^^^^^^^^^^^^^^^^^
    This thing is a prototype. It's main purpose is not to be a teaser for the general public. Vee Rubber and their main players have chosen to include the public, to a certain degree, in their prototyping process. This is really exciting and fun for us as the viewers, and I appreciate the risks Diamant/Nakamura/Espen/Vee Rubber/Wienmann are taking with this item. Pushing the limits is where it's at, and is why I have the loyalty to Fatback that I do. I'm watching with interest to see what this tire is capable of and thank the industry players for letting us watch the process.
    Apr 2014
    HOLY DUCKING SHIT. I'm speechless. PLEASE PLEASE TELL ME THESE WILL FIT IN MY NEWLY PURCHASED MOONLANDER!!!!!!
  67. #67
    Think think people complain about long chainstays now...just wait until they see what the chainstay length on any bike that would fit this tire would be.
    Espen, I am very curious to understand why you always seem to over inflate tires and then post measurements. What you are doing is similar to what the EPA does for MPG.
  68. #68
    wjh
    wjh is offline
    Feb 2012
    At some point, the negatives of larger tires will outweigh the benefits. That point may have been reached here. Those have got to be damn heavy
  69. #69
    Dirt Huffer
    Quote Originally Posted by wjh View Post
    Not too heavy
    Now for rolling resistance...
  70. #70
    Nup, I have places I could ride with that tyre. I suspect Norway has plenty of the same sort of terrain too.
    I think there's a case for 24" rims with very large section tyres - if only to keep the wheelbase within normal limits.
  71. #71
    Sep 2014
    I'd be all over it. For me, rolling resistance is irrelevant on a snow tire at 2psi...
  72. #72
    Apr 2014
    PEOPLE!! Will they fit in a Moonlander? Does anyone know? *pouts*
  73. #73
    bigger than you.
    Quote Originally Posted by OfficerFriendly View Post
    No, this is a whole new platform. Its doubtful that they will fit on any current frames.
  74. #74
    Reputation: Meriwether's Avatar
    Espen W -
    I know this is a lot to ask and may not be possible but...if you could post a few more tire dimensions I think we could better assess if it'll fit in current frames (which it likely won't), but I already have an order for a frame to fit this tire, if it actually goes to production.
    Stats that would be super helpful beyond tire diameter and max width on different rim widths would be:
    - radius to widest point casing and that width,
    - radius to widest point of tread with that width too.
    For me it's helpful to have the measurements of width and diameter at at least 10 psi to show the full extent of the tire.
    Thank you!
  75. #75
    Oslo, Norway
    Feb 2012
    There is no set rule for the pressure used for size rating, but 20psi is commonly used within the industry for fatbike tires.
    (35psi for 650b+)
    For example D4 and D5 are marked 4.0'' and 4.8'', so they must have been measured for width at higher pressure than 20psi by the factory, since I measured 3.85'' (on 82) and 4.58'' (on 100) at 20psi.
    However, I definitely do agree that the measurements at lower pressure, like 3.0psi is much more valuable for evaluating the potential footprint in loose snow, as that takes casing stretch and expansion from sloppy beads at higher pressures out of the equation.
    A tubeless ready tire will grow less at higher psi as the tighter beads will keep the tires from creeping up and out over the sidewall of the rim.
    At 3.0psi pressure, all on 103mm rims, except the D5, which was on a 100mm:
    ''2XL'': 5.45''
    Surly Lou: 4.59''
    Snowshoe XL: 4.72''
    Dillinger 5: 4.43''
    Jumbo Jim : 4.67''
    Espen Wethe
    www.kindernay.com
  76. #76
    Apr 2014
    Thanks for the reply, just saw that the tyre diameter is 32"!! I wonder how hard it would be to ride and jesus, I wonder what kind of frame would fit these tires. It would seem for the first time ever, Vee rubber is one step ahead of Surly haha
  77. #77
    I seem to be the only one here that thinks the larger diameter is a benefit. I'm no amazing snow biker and I can ride a 4.8in tire until my progress is halted by the cranks/pedals digging into the snow, not necessarily the flotation or traction of the tire. That's unavoidable, no matter how wide of tires you have your progress will be more or less stopped when your pedals are digging through a few inches of snow. So a taller bike will be beneficial there, and to be blunt I don't see a market for these on hardpack trails so a longer wheelbase I wouldn't see as a big issue.
    I think the 24" is a good idea but to me a 5.5 inch wide tire should probably be a pretty tall tire too.
  78. #78
    May 2013
    Espen:
    Thanks for the look into what the future may hold.
    The biggest objection IMO, is with the overall diameter, seems like something in the neighborhood of 29 -30" would make the product more marketable. BTW, any guess what a weighted rolling diameter could be expected?
    130 - 145mm rim width in the works?
    Again, thanks for the peek into this process
    "Courage is being scared to death and saddling up anyway" John Wayne
  79. #79
    Dec 2005
    It does not require a taller tire to raise the BB higher. That is more a function of frame design. As a more gravity challenged rider a wider tire is very welcome. The trails i ride tend to be lightly used mostly by pedestrians. Traction and float are always highly desired. Not a summer tire though. Curious to see how many current frames or forks could handle the girth.
    phat fingered from my phone
  80. #80
    will rant for food
    I will totally make some big ol' frames for this @#$*er. Can't wait.
  81. #81
    Apr 2014
    Quote Originally Posted by Drew Diller View Post
    That must be really awesome to just want a frame and just be able to make one! I really wish I could make bike frames, I'd make some crazy stuff ;D You better show us what you come up with!
  82. #82
    will rant for food
    My life depends on it!
    HAHA
    ha
    haaaa....
  83. #83
    Jul 2013
    Drew, just a little thought bubble, with the emergence of 'fat' 24" commercial tires (vee) I wonder if a pair 24x4" tires laced together put on a 100mm (cough carbon) rim might work with standard 190 fatty frame...
    Just a thought.
  84. #84
    HAHA
    ha
    haaaa....
    Said Genesis
  85. #85
    arc
    arc is offline
    Sep 2004
    Call it the Nut Crusher. Deep soft snow and top tubes seem like a bad combination.
    How do you see frame geometry working out for a tire like this? Lots of bottom bracket drop to keep the center of gravity down and lengthen the chain-stays so the tire clears the seat-tube or high bottom bracket to keep the pedals out of the snow and a Knolly type seat-tube to keep the chain-stays short?
    What about the front end? Riding in deep snow is going to be slow. Steering response on that big of tire at low pressure will be slow too. An extra steep head angle would probably be best but then how do you deal with winter boots and toe overlap?
    It'll be interesting to see how this all turns out.
  86. #86
    will rant for food
    Quote Originally Posted by arc View Post
    ...but then how do you deal with winter boots and toe overlap?
    My favorite among your questions is this one. As it pertains side-to-side as well. Some folks are already having Q trouble as is.
    Short answer is I don't know. I never saw this tire coming in any sort of quantity. I'm pleasantly shocked.
  87. #87
    Short answer is I don't know...
    The answer to that is a revision of how we pedal.
    With a non rotary motion our heels don't have to intrude past the back of the BB which allows lots more room for tyre. The thin wire drive also can be diverted around the tyre with a pulley, so that removes the tyre width restrictions.
    This is a pic of my Alenax, and you can see the basic principle here. It is a bit awkward to get used to it, but no harder than learning fixed. Once I mastered it, I was able to leave my sons in the dust riding this on a mtb course while they were on quality 29ers. The basic principle works ok, there's lots of improvements I would make though.
  88. #88
    The lower the BB is to the axle height, the more clearance you get. Shorter cranks will also give you a smidgen more.
  89. #89
    Quote Originally Posted by Sand Rat View Post
    With an Alenax system, it would be possible to adjust the operating arc of the pedals to change the height depending on conditions.
  90. #90
    Oslo, Norway
    Feb 2012
    Quote Originally Posted by SADDLE TRAMP View Post
    Espen:
    Surly Bud/Lou are around 31'' overall diameter, so 32'' isn't that dramatically much bigger.
    We discussed 110mm rims with Alex Rims (they make the Surly rims, etc) last year, and they wanted to do it, but at that time, we didn't have the new drivetrain ready, so a 4.8 on a 110mm would cause rubbing issues with 190 spacing and a regular 11 speed cassette setup.
    The new ''5.5'' has a nice profile (I prefer flattish for a powder tire) on the current 103 rims, and will have that on the new tubeless ready 100s as well.
    It retains a pretty nice powder profile even on 80s.
    Espen Wethe
    www.kindernay.com
  91. #91
    will rant for food
    I'll consider it if you want to transmogrify it with a Whyte PRST-1 =D
  92. #92
    Oslo, Norway
    Feb 2012
    Espen Wethe
    www.kindernay.com
  93. #93
    Mar 2015
    Sad thing is is that the sidewall casing will still extend beyond the knobs like the current slowshoe offerings. No bueno.
    knard.
  94. #94
    Jan 2013
    That wont be fitting on my Yampa anytime soon. And I thought my bud and lou were ridiculous! Thanks for the pic.
  95. #95
    Holy tread pattern knock-off Batman! Don't they copyright tread patterns or something.
    In the world of engineering, if 2 different companies independently arrive at the same solution, you have to think that that solution is pretty strong.
    ...or that someone stole it.
    That's OK. Not only will we all need new frames and new forks, but we'll need new car racks, too. I'm all out of $$$ for now so I'll wait 'til it shows up at Wal-Mart.
    -F
  96. #96
    This place needs an enema
    Reputation: mikesee's Avatar
    Aug 2003
    People that think this is too big or too heavy should unsubscribe. There are heaps of smaller tires--pick one and go ride it.
    Bud/Lou on 100mm rims are better than everything that came before but still aren't big enough.
    29" (700c rim) x 6" is probably not too big either. Bring it.
  97. #97
    not FAT free
    Mar 2011
    saint words !
    i want this tires
    no matter what !
  98. #98
    That looks way more than a 1" increase in diameter...
    I'm assuming you're not going to give more detailed measurements so I'll have to wait till it comes out
    The current drivetrain options are now the limiting factor not just the frame. Unless you run it single. Or set the rear der limit-screw to the cog before the chain hits the tire.
    Anyone's that has not been able to ride in deep pow knows that this will be a popular tire. What did our ancestors do on big pow days? Make bigger snowshoes!!
    [/QUOTE]
  99. #99
    Imagine pushing these monsters through untracked snow. You'd need the lactate threshold of a prime Lance Armstrong at the height of his PED abuse.
  100. #100
    Aug 2003
    Quote Originally Posted by ultraspontane View Post
    No bike will ever be able to be ridden through truly untracked snow. But if there's a base of any sort, this tire under a capable rider will be more rideable than anything that came before.
Members who have read this thread: 327
