Results 1 to 93 of 93
    May 2010
    Reputation: MuruCycles's Avatar
    Sep 2012
    nice. can't wait to try it
    Geordie biker
    Reputation: saltyman's Avatar
    Nice one
    2014 milage so far - 2,485
    www.ukfatbikes.co.uk
    Oct 2010
    WHere do you think this will fit in with the Nate and HuDu? Any mention of availability?
    Reputation: modifier's Avatar
    I wonder what the design purpose is? Rather than just another shoe to buy. Maybe to replace the Larry which is getting long in the tooth.
    You know what I would really like to see? A fat 29er. And no 3" is not fat. Maybe 3.4" with a 32+ diameter. Maybe too heavy but who knows until someone tries it.
    No it never stops hurting, but if you keep at it you can go faster.
    May 2010
    Quote Originally Posted by seewhatididther View Post
    No--no mention of availability.
    My guesses:
    Knard v. Nate: Knard will be lighter, faster rolling, less aggressive. Better for dry, worse for wet. More predictable when banked over, and narrower.
    Knard v. HuDu: This will be an interesting one to see. Knard will be narrower, but I wonder how the rolling resistance and traction will compare.
    not FAT free
    Reputation: RFX big foot's Avatar
    Mar 2011
    i see knard as a best candidate for home made studded tire ! just my opinion
    Dec 2010
    I'm assuming if the 26" Knard sets up well tubeless, then the 29" Knard may too?
    Quote Originally Posted by lawfarm View Post
    My guesses:
    What makes you think the Knard will be narrower?
    May 2010
    Quote Originally Posted by Traktor View Post
    Knard is a 3.8, by label. I'm guessing it's on the same casing as the Larry. HuDu is 4, by label.
    HuDu is significantly wider than Larry.
    At first I saw this and thought big deal. But then I realized what this meant. I'm looking to replace my Larry. A 32" Knard would also require a whole new wheel. A Husker Du or this 26" Knard would be the cheapest and easiest upgrade.
    I wonder if the Knard will be less than the $150 Husker Du, and when it will be available...
    I'm sure there are other numbers out there but what I could find searching the forums is HuDu on a 80 mm rim 95.25 mm and Larry on same rim 96mm.
    Latitude 61
    May 2010
    Quote Originally Posted by sryanak View Post
    I don't have the mm measurements in front of me at the moment, but as tried, back to back, on my 82mm Rolling Darryls, the HuDu was appreciably wider than a 3.8 Larry.
    I find Larry and HD basically the same and Nate wider. Haven't seen BFLs.
    nvphatty
    Guest
    good to have more options
    Bad cat!
    Reputation: montana_ben's Avatar
    Oct 2010
    29x3 Knard is pretty light, isn't it? This one might be one of the lighter fatties...perhaps it'll beat the light HuDu?
    Quote Originally Posted by montana_ben View Post
    I think the 29x3" Knard will be around 850gms, and I think the 26x4" Husker Du is closer to 1200gms.
    Quote Originally Posted by Wish I Were Riding View Post
    Right. 1200 1250. Still pretty light for the size. I'm really liking the HDs.
    I've been riding a motorcycle again recently and I've started unclipping form the pedal and sticking my root out and to the front on a bike too in some turns. Really helps with weight distribution and cornering traction. Plus you have a foot there if you slip. I'm much better on the left than the right. Same way on a motorcycle : /
    Reputation: Jstews's Avatar
    Oct 2011
    Anybody know when these are supposed to be available?
    Nemophilist
    Reputation: TrailMaker's Avatar
    Hey;
    This may have been found by others here searching the Frame Building forum, but I thought I would toss it in here anyway, for the sake of this forum. There is a thread in that forum that I started that has a small list of some Fatbike tire profiles, useful for frame building purposes.
    This is the spec I measured for a HuDu on the GRF/RD 80mm rim. This was while they were stretching at 40psi.
    Attached Thumbnails Attached Thumbnails 26x3.8 Surly Knard-huskerduprofile.jpg
    Most people ply the Well Trodden Path. A few seek a different way, and leave a Trail behind.
    - John Hajny, a.k.a. TrailMaker
    nvphatty
    Guest
    Quote Originally Posted by TrailMaker View Post
    Hey;
    thats too sexy for my rims..
    nvphatty
    Guest
    hmmm, if the 26x3.8 is 120tpi it too may under 1000gms.
    Reputation: Velobike's Avatar
    Quote Originally Posted by nvphatty View Post
    Never thought I'd see the day when a 1kg tyre would be "light"
    Latitude: 5736' Highlands, Scotland
    Reputation: tracerprix's Avatar
    Dec 2009
    Quote Originally Posted by Velobike View Post
    Ha ha, so true
    This place needs an enema
    Reputation: mikesee's Avatar
    Aug 2003
    It is?
    Not that I've seen--not even a little bit.
    Reputation: Steve Balogh's Avatar
    I did
    Quote Originally Posted by mikesee View Post
    It is?
    See: New Husker Du , I posted some measurements. Found .010" to .030" bigger.
    I found my Husker Du's to be wider than the Larry's I got from you. Hard to say how much variation is in their process. You might not see any difference in some tires from a different run.
    Quote Originally Posted by Steve Balogh View Post
    Well if you count 1/100th of an inch as significant than I guess you could be right.
    Bring on those digital calipers.
    Aug 2003
    I guess we have a different definition of 'significant'!
    But you're right in that there are variances in each batch, not to mention that which tube (or lack thereof) and exact pressure can affect the overall measurement 'significantly'.
    Cheers,
    MC
    Witty McWitterson
    Reputation: ~martini~'s Avatar
    Availability looks to be mid month. I'm watching them, and will bring a couple in fo'sho'.
    Just a regular guy.
    nvphatty
    Guest
    depending on price i may try a pr.
    Witty McWitterson
    Unless there gougers out there, price will be right in line with the rest of Sulry's tire line up.
    Just a regular guy.
    The Croatian Bear is thoroughly enjoying the Knard 3.8's. They corner better than the HD's and they're quicker to roll up. get ready to rip the legs off the inferior.
    Attached Thumbnails Attached Thumbnails 26x3.8 Surly Knard-251033_137986603014483_1054456065_n.jpg
    Dec 2010
    nvphatty
    Guest
    Quote Originally Posted by croatian_bear View Post
    oh sure makes us drool now.........
    Just keep the drool off my Knards... Do: Like The Croatian Bear on Facebook though for a chance to win 1 of 5 'Resistance Care Packages'...400 Likes by 11/3 will make it happen!
    Reputation: f00g's Avatar
    Done! not sure what a "Resistance Care Package" is, but if it is from Surly it's got to be cool! A pair of those Knards would be great for my Fatback build i'm almost done with.
    nvphatty
    Guest
    thats a great shot to show the blocks and profile of Mr Nardy.
    any real life weights on the 3.8 knard? wondering if they will be lighter than the new husker du? thanks
    nvphatty
    Guest
    I enquired with surly today and the reply was avail 1st week in Nov with no idea of weight or cost....
    nvphatty
    Guest
    ahhhhhhhh same as the HD which is quite spendy.
    Still no weight?
    Smash Mode: ON
    Reputation: Dustin Mustangs's Avatar
    Also posted on the Surly website now.
    I wonder how this one will do in the snow? Man santa has got to be pissed with how much I have been changing my list this year...
    Whatever floats your bike, dude
    Quote Originally Posted by Dustin Mustangs View Post
    Remember, it is not enough to have a good snow tire; the main thing is to use it well.
    Dinner for wolves
    Reputation: buddhak's Avatar
    This looks like it may be the fat tire version of the Maxxis Beaver I have been having fever dreams about...
    Fixed gear trail Pug looking like it may see the light of day in 2013. I can hear the CFO now - "You spent $300+ on a pair of tires?!?!? You are so fired."
    Responds to gravity
    will rant for food
    Quote Originally Posted by buddhak View Post
    CFO
    I've heard a lot of euphemisms for spouse before, but that's a new one, and gave me a laugh
    croation_bear, is that an OD crank as well? hows that going?
    Quote Originally Posted by bjfalken View Post
    The new crank is great! Solid, black, no der rub, black...did I mention that it's black?
    awesome, thanks! i have my name on one as soon as they come into the country!
    If it's around 1200g - then I'm in - Now a Big Fat Knard would be even better!
    Sep 2012
    Not to keep beating a dead horse, but I want a 4.7" version of this tire so, so hard.
    Dec 2010
    I want a 29x3" Nate for the Krampus
    aka bOb
    Reputation: bdundee's Avatar
    Quote Originally Posted by Willum View Post
    They will probably gives us that after we buy all the 3.8 first.
    Really negative rep for that.^^^^ Give me a break!!
    nvphatty
    Guest
    Quote Originally Posted by bdundee View Post
    yea 1 rockstar tire at a time turkeys.
    nvphatty
    Guest
    according to postings here they are avail @ QBP.
    Bud & Lou are here
    Reputation: spovegas's Avatar
    Breakdown
    You b@stards. Demons, the whole lot of you. Torturing me with your temptuous images and adjectives. Perpetually sweaty palms. Sleepless nights spent tossing and turning. Total inability to concentrate at work. Every man has his breaking point and you've finally pushed me to mine . . . two knards were just ordered. I hope you're happy with yourselves. At least I will sleep tonight. The only question left to dwell on is whether they will be delivered in a sack.
    nvphatty
    Guest
    If your happy i'm happy.
    I've been getting them, too. LOL, that poster must work for Surly or something.
    Reputation: OFFcourse's Avatar
    Does anywhere have the 26x3.8 Knards (120tpi) in stock?
    Any weights on these yet?
    Nov 2008
    So far QBP has only had the 27tpi instock and they sold out in three days. The 120 tpi's are over due.
    Cheers,
    Steven
    Quote Originally Posted by OFFcourse View Post
    Lucky neighbor of Maryland's Patapsco Valley State Park, 39.23,-76.76 Flickr
    100+ wheel-build club
    Reputation: johnny settle's Avatar
    Mar 2011
    I bought one from Jenson. ETA Nov. 12th.
    "Go that way REAL FAST, if something gets in your way... turn".
    Quote Originally Posted by johnny settle View Post
    Thanks, Jenson have pretty sweet shipping price to me if only surly would give us some weights!
    27 tpi Stats
    I got my Knards today and of course the first thing I did was weigh them:
    One came in at 1680 and the other at 1740. Pretty chunky, especially compared to my Larry at 1470, Endo at 1260 and BF's at around 1100. But hey, you wanna play, you gotta pay, right? I'm really excited about these tires and am optimistic that the speed and traction will be so worth the price of a little extra weight.
    On first impression, they appear to be wider than the Endo, but mostly that's an optical thing, I think, because the treadblocks wrap so much further around the tire.
    The outer treadblocks are the widest part of the tire, though, by just a bit. With 30 psi in the tires, I measured around 102 mm and at 10psi, about 98. Brand new of course, and so they haven't had time to stretch, but ballpark numbers. No surprise in those numbers, since they use the same casing as the others, I presume.
    I'll be super jealous of you guys that are waiting for the 1200g 120 tpi's when you get 'em, but for now, feel free to eat your hearts out, suckas! Unless of course I literally eat my own heart out tomorrow out of sheer frustration, since I won't get a chance to ride these until Saturday.
    nvphatty
    Guest
    Thems studly
    are the 120 tpiz 1200g ? source?
    Smash Mode: ON
    How does your chain clearance compare with how it was with the endo?
  67. #67
    Just a guess, based on the fact that the HD is in the 1200 - 1250 range.
  68. #68
    Reputation: duggus's Avatar
    WE CAN'T STOP HERE THIS IS BAT COUNTRY
    For the bead win : )
  69. #69
    Mounted mine just a few minutes ago. I've been running nates and wanted lower rolling resistance for riding single track. Short trip around the block and I can say they will be faster for sure. Night ride scheduled tonight to see traction
    Ride what you like, how you like, just remember that's what everybody else is doing too.
  70. #70
    I wonder how these tires will do with packing up snow/sand.
  71. #71
    Cormac
    Reputation: cormy's Avatar
    Any body had luck setting these up tubeless? What pressures are yall running tubeless for the fatty? seems like youd burp a tonn running 6-11 psi.
    '11 Dawes Deadeye
    '12 Niner E.M.D. 9
    '09 Giant ocr c1
    Xtracycle
  72. #72
    I have 2+ mm clearance. Probably better than with the Endo.
    I went more than a little crazy over chain rub about this time last year, as documented here. Since then, I did a ~400 mile tour on BF's pumped up to 25 psi, which majorly rubbed. Certainly I'd rather not rub if I have my choice, but I guess I've kind of mellowed on the issue - it's just not that bigga deal to me. The time spent in the big cog/small ring is pretty miniscule and the chance of the chain doing any damage to the tire is even infinitely more miniscule, IMHO.
    And chicks dig rub marks, so there's also that.
  73. #73
    Smash Mode: ON
    Thanks for the info. With the type of riding I do I have a lot of issues with mud/sand/grit contaminating my drive train. I have some full coverage carbon fenders almost done but even with those there is still a big issue with the chain picking up debris straight from the tire. The more clearance there the better as far as that goes.
  74. #74
    Yeah, I see your point about wanting clearance for the mud. Looking forward to seeing your fenders when they're finished.
  75. #75
    I was playing with my Knards this weekend . . . wait! That sounds all wrong. Not what I meant. At all!!!
    What I meant was, I was out riding on Surly's newest fat tire. And it was RAD. Fast and sticky, just like I had hoped. I REALLY dig these tires.
  76. #76
    nvphatty
    Guest
    ^ did you fall down go boom or was this a pee break??
  77. #77
    Neither. Just stopped to gather a little oxygen after climbing that thar hill.
  78. #78
    Geordie biker
    I'm liking the look of these
  79. #79
    Reputation: buckfiddious's Avatar
    Quote Originally Posted by spovegas View Post
    Gotta ask- figure the weight on the Knards isn't too far off the weight of a Devist8r- any comparison between the two?
  80. #80
    nvphatty
    Guest
    Quote Originally Posted by buckfiddious View Post
    the NEW UL devist8ers are 1800gms +/- so perhaps 100gms diff between the two.
    do I know this well.
  81. #81
    Cormac
    got a knard 27 tpi for my half fat today....and it is sweet. I havent ridden it much yet, but it has noticably less rolling resistance and I cant wait to take it out on the trails
    '11 Dawes Deadeye
    '12 Niner E.M.D. 9
    '09 Giant ocr c1
    Xtracycle
  82. #82
    Picked up a set yesterday....
    ....put them on my old Wildfire. Got the 27 tpi version, works really well on trail. There's a few places locally that have paved paths connecting trails, so I wanted something a bit more road and hardpack friendly without tearing up my Husker Du's on my other bike. A lot less noisy that the Larry's they replaced when hitting the pavement.
  83. #83
    viva la v-brakes!
    Reputation: FishMan473's Avatar
    Jan 2003
    So, rolls faster... any feeling for traction? I'm mostly concerned about use in the snow.
    I have a car. I made a choice. I ride my bike.
  84. #84
    Reputation: octavius's Avatar
    any feedback on what knards are like in mud yet?
  85. #85
    Steve - can you give us a quick comparison on the knard vs husker du? Please
  86. #86
    Reputation: woody_8_5's Avatar
    Awesome looking tire! Waiting for the 120tpi to become available. Had a chance to get up close and personal with this bad boy over the weekend.
    Same width as Larry and Husker
    Attached Thumbnails Attached Thumbnails 26x3.8 Surly Knard-imageuploadedbytapatalk1352734006.046668.jpg
  87. #87
    Knard vs Hu Du
    Quote Originally Posted by MrClean View Post
    I'm thinking the Knard rolls faster - has more knobs in the center closely spaced. I did take one corner fast enough to make the rear break loose into a controlled skid, but it's handling is predictable. Keep in mind though, I have Large Marges on the Wildfire and lighter weight UMA's on my Fatback that has the Husker Du's. The 27 tpi Knard's feel like a more expensive tire, those choosing to go cheaper than the $150 version will not be disappointed.
    As a front tire worked fantastic, was not like an Endomorph. The Knard should work well in sand, I might give that a go this weekend. My first ride was on hardpack and paved trail.
    The Knard is doing what I need it to do, hardpack, grass, new bumpy trails, and pavement.
    Last weekend at Iceman, the Husker Du surprised me at how well it handled the mud up there (has a bit of sand though, not the greasy clay - based soil like my end of the state has).
    I'm thinking mud may be the true test of the Knard. I seriously think that's where the Husker Du may have an advantage.
  88. #88
    Tread
    For tread depth, I'm getting 3mm on the Husker Du's and 2mm on the Knards.
  89. #89
    viva la v-brakes!
    Jan 2003
    Has anyone weighed the kevlar beaded version?
  90. #90
    I just ordered a 120 TPI, so I'll post a weight when it arrives.
    If it's under 1200gm I'll be happy, otherwise I'm kinda thinking an Ultralight Nate would be better.
    Replaces my orginal Larry and a Devista8er, so I can't really go wrong
    GG Smash 29 (pending)
    Trek Full Stache 29+
    Kona Wozo 29+
    Devinci Hendrix 27+ (loaner)
    Specialize Levo FSR 27+ (wifee)
  91. #91
    Sep 2012
    got my 27tpi version last night, weighed in at 1705g
  92. #92
    I just talked to the shop who has my order and apparently the 26 x 3.8 120tpi folding knard is on the same delivery schedule as the 29 x 3" Knard. So now I'm thinking I might hold off on getting the fat Knard since the wire bead weights are coming in really high; which makes me think the folding bead is going to be heavier than the comparable Larry or HD.
    The ultralight HD is looking better all the time.
    Kona Wozo 29+
  93. #93
    Weights for the folding version are on this thread.
Members who have read this thread: 4
