Page 4 of 5 FirstFirst 12345 LastLast
Results 151 to 200 of 245
  1. #151
    Reputation: Way2ManyBikes's Avatar
    Is it wrong for me to consider doing a 27.5+
    Marty
    12 JamisDakar650B
    14 FarleyBlue,Bluto,i9-Hed,4.JumboJims
    14 FarleyBlack,Jackalope
    17 Farley 9.6 Under Construction
  2. #152
    Reputation: mikeetheviking's Avatar
    Jan 2015
    Not wrong. The 27.5 x 3.8 tires that come stock on this thing can be run on 40mm-80mm wide rims, these tires are actually measuring 3.2-3.5 inches wide on the narrower rims.
    Totally doable!!!
    Mikee Likes It!
    @gordosbicycleclub
  3. #153
    Quote Originally Posted by Way2ManyBikes View Post
    It pretty much is already.
    Those tires run narrow. Put them on narrower rims like 65mm and you'd have a sub 3.5" tire.
    If you were to run standard B+ tires....you may have a really low bb
    I run the 26" version Hodags on 65mm rims and they are about 3.5 after a year of riding.
  4. #154
    Jan 2015
    Subtle, very subtle, sometimes you have to smooth with your approach
    Mikee Likes It!
    @gordosbicycleclub
  5. #155
    I think your getting a new Farley
    Quote Originally Posted by mikeetheviking View Post
    Marty
    12 JamisDakar650B
  6. #156
    I'd be interested in doing this possibly with the new Pike 29+ fork, possibly even Olaf Lefty
    The Pike 29+ fork is only available on bikes for now, not available aftermarket yet.
  7. #157
    Nov 2014
    Farley EX 9.8
    I just got the new Farley EX 9.8. I was riding the 2015 Farley 8. Initial impressions: The EX has a wide bottom bracket, but I am getting used to that. I noticed the pedal strikes way more. I hit my calves on occasion on the seat stays, they are wide and when seated and pedaling I hit if the bike if it is not perfectly straight up and down. Thats all the negitive stuff for me. The 27.5 wheels are faster and do keep your momentum going better than the 26. I dont notice any negative impact from the 27.5 wheels. It is a very stout frame, so stiff. It feels great. I love how I can get more pump out of the full suspension, and more pre-load before jumps. The Bluto is a standard bluto so not super stiff, but it work well for my terrain. I am still working on getting the rear suspension dialed in, it feels a bit harsh. I upgraded the bars to sixc 35mm 35mm rise and love them. This bike is a ton of fun to ride and thats why I bought it. Racing it at Ice Man next month. I am expecting my time to improve vs the hardtail, this bike is faster!
    Attached Thumbnails Attached Thumbnails 2017 Trek Farley EX Full Suspension Fat Bike-farley-ex-9.8.jpg
  8. #158
    Oct 2016
    Hi all I am new here but have been following a few threads for a while now. My thoughts on this sweet machine is just that. My first few rides on it were unreal and had me thinking that they have perfected the mountain bike. I have since taken it on some bigger rides and while still awesome and quite possibly my favorite bike it wasnt nearly as lively as my regular mtb. Still would highly recommend to anyone.
    Cheers
  9. #159
    Reputation: tadraper's Avatar
    I picked up a Farley ex 8 last week so far super fun bike.
    Haven't had a ton of time on it but can tell it is fun and rolls great.
    Enjoyed it setup stock tried my 29+ wheels while setting up the stock wheels tubeless.
    29+
    Stock
  10. #160
    Nov 2014
    So, do you like the 29+ better or the stock 3.8s?
  11. #161
    I wouldn't say I like them better I had the Farley 9.8 before this one so full rigid and used both wheels sets. I like the options of changing based on how I am feeling or where I am riding. I also have a 26x4.8 wheel set for deep snow that I put on to validate they fit.
    I just like having options as this is my only mountain bike so it will be well used.
    T
  12. #162
    Nov 2014
    Cool, thanks
  13. #163
    Jan 2014
    How does the Farley EX compare to a Top Fuel? The 29+ option intrigues me for XC racing.
  14. #164
    I rode a top fuel for a few weeks really liked it which is one reason I went this direction. For me it is very comparable other than weight of the Farley being a little heavier. I think this bike will work for XC racing with the 29+ or 27.5x3.8. I need to change the front chainring 34-36 oval and want to get the new e thirteen 9-44 cassette and then XC will be good.
    T
  15. #165
    so is the bottom bracket drastically wider than your old Farley 8 ?
    i was under the impression that the Farley EX 9.8 uses the NEXT SL cranks and flipped chainring to achieve the same Q factor as a 170 or 177 frame.
    QUOTE=Telebikes;12867994]I just got the new Farley EX 9.8. I was riding the 2015 Farley 8. Initial impressions: The EX has a wide bottom bracket, but I am getting used to that. I noticed the pedal strikes way more. I hit my calves on occasion on the seat stays, they are wide and when seated and pedaling I hit if the bike if it is not perfectly straight up and down. Thats all the negitive stuff for me. The 27.5 wheels are faster and do keep your momentum going better than the 26. I dont notice any negative impact from the 27.5 wheels. It is a very stout frame, so stiff. It feels great. I love how I can get more pump out of the full suspension, and more pre-load before jumps. The Bluto is a standard bluto so not super stiff, but it work well for my terrain. I am still working on getting the rear suspension dialed in, it feels a bit harsh. I upgraded the bars to sixc 35mm 35mm rise and love them. This bike is a ton of fun to ride and thats why I bought it. Racing it at Ice Man next month. I am expecting my time to improve vs the hardtail, this bike is faster![/QUOTE]
  16. #166
    Nov 2014
    It is wider. The chain ring is flipped for better chain line but it's wider overall. I think it will be nice to have the chain away from the wheel however as that was an issue for me on 2015 hardtail.
  17. #167
    Nov 2014
    I have a question for anyone who has switched over to the 27.5 from 26. Do you use less pressure than you would with the same 3.8 hodags on the 27.5?
  18. #168
    I had the first Farley with 26 wheels and hodags the pressure is a personal preference. I am heavier than most people I ride with and generally use more pressure. If I recall I use the same general pressure.
    T
  19. #169
    that could be a deal breaker for me. really want a farley EX 9.8 but I am concerned that the Q factor will be too wide for me.
    QUOTE=Telebikes;12868406]It is wider. The chain ring is flipped for better chain line but it's wider overall. I think it will be nice to have the chain away from the wheel however as that was an issue for me on 2015 hardtail.[/QUOTE]
  20. #170
    Nov 2014
    Quote Originally Posted by donkeykongchamp View Post
    [/QUOTE]
    Yeah, it caught me be surprise. The only issue I have found is with pedal strikes and that is very manageable. Pedaling with the width has not been an issue yet, but only
    2 rides so far
  21. #171
    pedal strikes are manageable for sure. the wide q factor is a little more of a slow change for the body to adapt to. i tried to get my body to adapt to a specialized fatboy carbon last year but just couldn't do it. so i sold it.
    2 rides so far[/QUOTE]
  22. #172
    bigger than you.
    Reputation: Gigantic's Avatar
    Quote Originally Posted by Telebikes View Post
    I switched over from a hardtail 26 to a Salsa Bucksaw, running 27.5, with Hodags. I generally ride with higher pressure than on 26 in all instances, but I'm not a big fan of having the sidewalls fold over on me. In the snow, I''ll go as low as I can without denting the rims.
    Maverick Moto Media Motorcycles, Mountain Biking & Social Media Mgt
    Facebook Twitter Instagram
  23. #173
    The Wider bottom bracket shouldn't be a concern as it is actually better for your knee's and you should in Theory be able to put more power to the ground.
    Ex. If you were to go to the gym and try to squat with your feet close together you would be limited by your poor foot location. The wider bottom brackets actually put your feet in a much better position to exert power. So honestly the wider bottom bracket is a good thing for pretty much everyone.
    Just think if your a big guy, wide hips and big legs your legs are on an inward angle which then puts stress on the outer part of your new joint.
    Marty
    12 JamisDakar650B
  24. #174
    Nov 2014
    It may be better for my knee's, but after pedaling normal Q factor bikes for 10+ years it definitely puts strain on my ankles, knees, and hips. I should note that I am a big guy at 6'4" with a 36" waist. That being said, I want my legs to adjust so badly because this bike feels like a dirt bike without a motor. It is so much fun to ride. 27.5 wheels are so much faster, it's amazing!
  25. #175
    Curious if your riding clipped in ??
    If you switch to flat pedals and a pair of 510 shoe's I am betting a silver dollar your discomfort will go away.
    Marty
    12 JamisDakar650B
  26. #176
    Nov 2014
    I ride clipped always. I have a size 16 foot so there are no good flat shoe options for me. I have a hard time keeping my big feet on flat pedals unforunately.
  27. #177
    Wow, I didn't know they made a clippless shoe that big.
    Marty
    12 JamisDakar650B
  28. #178
    Reputation: lphillips's Avatar
    My new Farley EX 8 in 29+ mode
    Here's my new Farley EX 8. I also swapped the Bluto for the Fox 34 I had on my Stache+ and am running 29+ wheels. I also have 9Point8 dropper and Shimano m8000XT drivetrain and discs. Really, REALLY, love the ride on this bike! It's an XL sized frame and weighs ~31 pounds as shown.
    Attached Thumbnails Attached Thumbnails 2017 Trek Farley EX Full Suspension Fat Bike-farleyex1.jpg
  29. #179
    zeb
    zeb is offline
    Tested for 2 days.2017 Trek Farley EX Full Suspension Fat Bike-p4pb14046332.jpg
  30. #180
    Oct 2016
    Hey all! Brand new here. Been reading for the last few weeks about Fat Bikes and got me a Farley EX 8 last Fri. Let go of my YETI last march after Moab and been without since. Look forward to a good couple weeks. Headed to Bella Vista AR this morning from Central Ks. Doing Slaughter Pen and Blowing Spring for a couple days then down to the Womble at Lake Ouachita. Got 2 KTMs, ( 640Adv and 450EXC) the Kayak and the Trek all loaded up in the trailer. Should be fun!!
    Hayden.
  31. #181
    Oct 2012
    So 26 x 4.8 actually fits?
    Quote Originally Posted by tadraper View Post
    T
    Tad, just wanted to make sure- you've actually ridden the bike with 26 x 4.8 and it works? What width were the rims? Cuz others have been saying the 4.8 won't fit due to the suspension arch. Thinking of getting one if I can run 26 x 4.7 in the winter.
  32. #182
    i have minions 26x4.8 on 80's no issues with fit or ride. i will get some photos this weekend if i have time to show how they compare to the stock 27.5x3.8 Hodag's
  33. #183
    passed out in your garden
    Reputation: cmg71's Avatar
    Mar 2012
    Quote Originally Posted by allezdude View Post
    Can you please do a width measurement as well?
    always mad and usually drunk......
  34. #184
    Wheels tested no issues with any rubbing.
  35. #185
    This really could be one bike for all seasons. Fits D5's on Mulefut 80's
    2017 Trek Farley EX Full Suspension Fat Bike-15397669_10154559072225751_1825737270_o.jpg
  36. #186
    Rear Shock doesn't like the cold, -25c
    Attached Thumbnails Attached Thumbnails 2017 Trek Farley EX Full Suspension Fat Bike-20161207_193125.jpg
  37. #187
    holy cow. Thats brutal
  38. #188
    A-Y
    A-Y is offline
    Reputation: A-Y's Avatar
    Aug 2005
    Anyone else having issues with the Bontrager Drop Line seat post in the cold (sub zero celsius temps.)? Dropper won't hold its position and drops all the way within a few minutes of pedalling, seems worse the colder it is. Its been in the LBS once already and I'm going to have to bring it back again. Otherwise this is a great bike. The suspension really smooths outs the ruts and bumps caused by frozen foot prints.
  39. #189
    Reputation: ccornacc's Avatar
    Does anyone know how much the EX 9.8 frame weighs? I have not been able to track a frame weight down yet.
  40. #190
    All fat, all the time.
    Reputation: Shark's Avatar
    Feb 2006
    Quote Originally Posted by 2LO4U2C View Post
    Warranty?
  41. #191
    Flipping the chainring changes the chainline, NOT the Q. The Q factor is the width from outside of crank arm at pedal to outside of crank arm at pedal.
    A 120mm crank spindle will have 20mm wider Q factor on average than a 100mm bb.
    Some cranks have a narrower Q, like the Next SL.
    If you want a 100mm bb it may be possible, you just need to look at crank clearance.
  42. #192
    That shouldn't be a suprising, the Bluto would have the same problem. -25 is very cold for air shocks with rubber seals.
    I just had this vision of you riding back to the car, fork and shock fully compressed
  43. #193
    Reputation: solarplex's Avatar
    Apr 2014
    Quote Originally Posted by Nurse Ben View Post
    Why? Fox float snowmobile shox work fine.
    Fatbike, XC bike, Gravel Bike....
  44. #194
    Apr 2014
    Quote Originally Posted by A-Y View Post
    Only cold certified dropper is the 9point8 fall line.
  45. #195
    I would guess it's around 6.5-7.5 lbs including the rear shock.
  46. #196
    Quote Originally Posted by solarplex View Post
    I have ridden my Drop Line around zero with no issues. It is slow but works.
  47. #197
    His dropper was the 9point8 as well, it has also gone in for warranty.
  48. #198
    A-Y
    A-Y is offline
    Aug 2005
    Quote Originally Posted by josh8 View Post
    Bontrager sent a replacement Drop Line and so far it appears to work well. Tested on two rides: -5 and -10C respectively with no slowness when triggered. I also noticed the replacement had the trigger under the bar vs. over the bar that came stock with the bike.
  49. #199
    We had a couple of the Bontreger droppers in the group, both were fine at -30c. Thats where I'm going next.
  50. #200
    Apr 2014
    Well i think im going to pull a trigger on a 8 next season.
    Never found a drawback for my 3.8" hodags on my farley 6 for my conditions. But im going to keep it as ive put some $$ into it and it can be my really cold weather bike, also had a gnarwhal on it, might put another and it can be an icy condition bike then too.
    Ill probably ditch the dropper for weight savings. How much is saved going tubeless? Heard 3lbs but i doubt that. If its 33 lbs thats fine, just make the legs stronger for summer xc season.
    I seen the dish on the ring was wrong on the ex my lbs has. Its chainlines not centered, is that for tire rub or is it set up wrong?
  1. Replies: 9
    Last Post: 09-17-2015, 07:26 PM
  2. Replies: 4
    Last Post: 10-04-2014, 11:31 PM
  3. Replies: 5
    Last Post: 05-19-2014, 01:17 PM
  4. Replies: 4
    Last Post: 08-27-2013, 05:15 PM
  5. SPAM: Trek Liquid 30 full suspension bike
    By appleSSeed in forum All Mountain
    Last Post: 07-03-2013, 04:31 PM
