Page 4 of 21 FirstFirst 1234567814 ... LastLast
Results 301 to 400 of 2056
  1. #301
    Feb 2015
    Quote Originally Posted by Apansson View Post
    What do you reckon would be the easiest way(s) then to drop roughly 2lbs? I'm thinking of DMR vault super light mg/ti pedals, 290 grams. But yeah? Losing 1kg or so seems difficult...
    I sense much weenie in you young one.
    23lbs is pretty F'ing light.
  2. #302
    Sep 2015
    Does anyone know when the Bontrager Haru Pro carbon fork will be sold separately? Any idea on the price?
  3. #303
    Feb 2015
    Quote Originally Posted by TheFarleys View Post
    It may never be sold separately.
  4. #304
    Sep 2015
    Quote Originally Posted by Gambit21 View Post
    Course it is! But being in the business does that to you
  5. #305
    Sep 2015
    Say it ain't so!
  6. #306
    Aug 2015
    Quote Originally Posted by moshock View Post
    Nice pic, thanks for sharing! I have the Farley 5 as well. Impresses me every time I look at it. The paint job is just sexy, ain't it?!
    Very! I'm very impressed with the look. The ride is amazing too. Got a chance to hit some trail this weekend. Was after 20 miles on the road so need to get on it with some fresh legs to get a proper run through. But man is it fun.
  7. #307
    Dec 2014
    Say it ain't so!
    This UK site is showing some info
    Bontrager Haru 26" Carbon Fat Bike Fork | Triton Cycles
  8. #308
    Feb 2015
    Quote Originally Posted by FatSpooky View Post
    That's good news
  9. #309
    Sep 2015
    That's good news
    The price seems decent too. Hope that information is correct.
  10. #310
    Feb 2015
    Aye - been there.
    Although back then while at the shop, same as now I usually shook it off before pulling the trigger and tried to stay sensible. Making $8.00 an hour as a bike mechanic helped keep my spending in line too.
  11. #311
    Sep 2015
    Sure, here you go:
    CS width at widest point (ie. near your heels) is 164 mm
    CS outer width at rear hub (excluding axle QR) is 233 mm
    Q factor (centre of frame to outermost crank face at pedals) is 114mm (ie 228mm total bilaterally).
    The chainstays themselves are remarkably thin (surely solid?), but "high" when viewed side-on, for most of their length and run parallel for most of their length from the widest point at the rear tyre to about where the rear sprocket cluster starts, if that makes sense.
    The frame is very well manufactured, with a lot of subtle shaping due to hydroformed construction, which isn't evident in even the enlarged images on Trek's website. I'd recommend you check it out closely in person if you can. It's very impressive next to my old school TIG welded steel HT (which is still pretty cool).
    Quote Originally Posted by shoo View Post
    Thanks for the ride report. I have a favor to ask. Could you get a measurement inside and outside the chain stays at the widest point. My wife has a 2014 Farley but it is too small and I would like to replace it. Trek states that they kept the same Q factor so I am curious what the 2016 Alloy frames measure.
  12. #312
    Nov 2008
    Hey thanks a bunch Fat Dan. I apreciate you taking the time to get those measurements.
    Cheers.
    Quote Originally Posted by Fat Dan View Post
    Sure, here you go:
    CS outer witdh at rear hub (excluding axle QR) is 233 mm
    Lucky neighbor of Maryland's Patapsco Valley State Park, 39.23,-76.76 Flickr
  13. #313
    Feb 2012
    Here's a couple from todays ride. I have to say the bike is starting to grow on me. Still looking for the optimal tire pressure, but really enjoy this bike. Coming from road and cyclocross bikes this is just plain fun and takes you anywhere.
    Attachment 1016547Attachment 1016548
    Would you know what your 9 weighs?
  14. #314
    Sep 2015
    Quote Originally Posted by NDTransplant View Post
    Sorry but I don't have a scale. Would be interesting to know though. Is there anyone else out there who would have both a 9 and a scale?
  15. #315
    Reputation: solarplex's Avatar
    Apr 2014
    Quote Originally Posted by bcriverjunky View Post
    4" is 4" no matter how you measure it. If anything the 26 could equal more with the added squish. I ride mine all year so I'm happy with the 4" tire but I do wish I could run a 5" in the winter
    The larger diameter will make the tire contact patch longer. Yea the same width but larger area for sure.
    Fatbike, XC bike, Gravel Bike....
  16. #316
    Sep 2015
    Quote Originally Posted by Paochow View Post
    The DT Swiss BR 2250 is another option- it is as light as many carbon sets, strong, and cheaper, especially from the euro sites.
    Thanks for pointing me to those rims.
    When I look at them, it says tubeless setup is 'in development' Does anyone know what that means? It seems like it would be silly to get light rims like this and then add tubes. If not, please explain.
    Can someone explain what rim width and setup I would need to run 5" fat tires on a Farley 9.6" I see things talking about everywhere from 100mm to 65mm. It seems like the same time would not fit well on that great of a range. Any help and explanation is appreciated.
  17. #317
    Jul 2014
    Quote Originally Posted by jrogersAK View Post
    From what I've read, DT Swiss isn't going to release the tubeless kit. As silly as it sounds, shrink wrap tubeless is a cheap, reliable, lightweight solution. My neighbor and I have been running it all summer without issue on the very similar Fatboy rims.
    As for wheel size, I'd go with a 80-100mm rim to get a wide contact patch with the larger tires. Wider is usually better, however be mindful of weight increases. Going from a DT Swiss BR rim (81mm) to a Clownshoe (100mm) is an increase of 250gr per wheel.
    '17 Cutthroat
    '16 Bucksaw Carbon
    '15 Fatboy Expert
  18. #318
    Quote Originally Posted by solarplex View Post
    Well I rode a 9.8 this weekend. Really liked the bike. I took it on a sand beach and it motored right around on the sand including going up inclines. It had rained over the night before, the sand was dry with a very slight crust on it and loose underneath. It sure wasn't compacted at all (this is a public beach with a lot of traffic).
    So I'm pretty convinced that the 27.5x4 will work just fine for me in most cases. Tire inflation was on the high side (~10psi) but no issues. Had I reduced tire pressure a bit, I'm sure that would have made it even better. This will be my first fat bike but I'm still impressed with the flotation of the 27.5x4 on this sand. I'll be riding mine mostly on snowing trails and I'll probably put GripStuds in the tires since there isn't a pre-studded option for the 27.5's yet.
    J.
  19. #319
    Well it looks like there is plenty of clearance, decided to put my Bud and Lou on Clowns on.
  20. #320
    Jul 2014
    Quote Originally Posted by Natedeezy View Post
    See that is how it should have come from the factory! A kick ass snow bike!
    '17 Cutthroat
    '16 Bucksaw Carbon
    '15 Fatboy Expert
  21. #321
    Reputation: cardnation's Avatar
    Jul 2014
    So has anyone been able to measure and weigh the Bontrager Barbegazi 26x4.7" tires yet?
    I bike with tires.
  22. #322
    Sep 2015
    Whats the weight and price of these rims? Are they significantly heavier than the wampas?
  23. #323
    I would wager that the clownshoe wheelset has about 500g-800g on top of the Wampas if not more
    Some quick estimates
    1000g per rim
    650g for hubs
    380g for spokes
    150g rim strips
  24. #324
    Sep 2015
    Quote Originally Posted by crohnsy View Post
    1000g per rim
    650g for hubs
    380g for spokes
    150g rim strips
    Ah cool. Nothing for me then! I'm just going for as light as possible. Did you tubeless the wampas+hodags? Do you need anything else apart from sealant?
  25. #325
    He clowns are much heavier than the stock wheels even built with I9s and light spokes. Defiantly will be winter only wheels. I think this was the back wheel after it was built.
  26. #326
    Lord Thunderbottom
    Reputation: TitanofChaos's Avatar
    Farley 9's are pushed back to late november now, but some shop in california over ordered on the first wave sending one in my size back into stock
    It's on it's way to WI should be riding it by next weekend, I'm pumped
    Today I will do what others won't, so tomorrow I can do what others can't
  27. #327
    Jul 2014
    DT Swiss Big Ride would be a good lightweight somewhat affordable option. They are ~300gr lighter than the Wampas
    '17 Cutthroat
    '16 Bucksaw Carbon
    '15 Fatboy Expert
  28. #328
    Feb 2015
    That means the Wampas are in the same neighborhood as the Mulefuts...confirming my suspicions that an 80mm 27.5 rim is less than ideal.
    I keep bouncing back and forth between those DT Swiss rims and switching to 4" tires in summer, or 29+ (which I will use plenty Hank)
    29+ makes the most sense since I can still run 4" tires on the Mulefuts. Those damn DT Swiss rims just won't leave me alone though.
    I think a set of Next SL cranks are a better bang for the buck weight loss option though. Still...
  29. #329
    Lord Thunderbottom
    I don't have the numbers here but considering overall diameter the wampa wheelset is realistically lighter than the other equivalent options that keep the same wheel O.D. as the 27.5x4 tire will be lighter than the other tires available which are all 5" to achieve the same O.D.
    If maintaining the geometry doesn't matter to you or you're just being a weight weenie the thing then carry on, the farley BB height is only like 5mm lower than say a 907 carbon so if you're enjoying the current diameter, it likely does not matter anyways
  30. #330
    Jul 2014
    Quote Originally Posted by TitanofChaos View Post
    It will really depend on the weight of the 27.5" tires. If you save 150gr a wheel over the Wampas, and run JJ 4.8 LS, the Wampas would need to be less than 1050 gr to net any weight savings.
    '17 Cutthroat
    '16 Bucksaw Carbon
    '15 Fatboy Expert
  31. #331
    Without riding and or touching the Wampas, I can imagine they are going to be way more durable than the DT fat rims. For snow riding the dt may be better? But, for dirt, the wampas should be a better choice.
    Sent from my 831C using Tapatalk
    http://Theclydeblog.org Big guy cycling product tester
  32. #332
    Jul 2014
    Quote Originally Posted by DukeNeverwinter View Post
    Objection your honor, the defense is speculating...
    Granted this is all speculation until the Wampas get some dirt miles, but I'd have a hard time believing your statement about durability. The DT rim is a similar design to the Fatboy SL rim, which despite the wheels having hub issues, the rims themselves have proven strong and reliable. Carbon is very strong and stiff, but doesn't tend to do as well with sharp impacts. Do a google image search for "carbon rim failure" and take a look at the carnage. Combine that with the shorter sidewalls of the 27.5" tires and you are inviting rim strikes when you run low psi.
    If you don't believe me, when you get your 9.8 we can both set our tires to 6 psi and ride through rocks gardens and see who's wheels break first
    '17 Cutthroat
    '16 Bucksaw Carbon
    '15 Fatboy Expert
  33. #333
    Lol, 6psi won't hold up under my 240lbs fat ass, regardless of rims.
  34. #334
    Jul 2014
    Quote Originally Posted by dukeneverwinter View Post
    lol, 6psi won't hold up under my 240lbs fat ass, regardless of rims.
    Sent from my 831c using tapatalk
    lol
    '17 Cutthroat
    '16 Bucksaw Carbon
    '15 Fatboy Expert
  35. #335
    Feb 2015
    ...not so much.
  36. #336
    Aug 2015
    got the call a little while ago, my Farley 5 has arrived and is built, gonna pick it up tomorrow, so stoked!
  37. #337
    Aug 2015
    Quote Originally Posted by egrims View Post
    Picked it up today. Can't wait to take it out for a proper rip. Just hit it around the parking lot. First impressions are this thing is amazing. I only wish I had gotten a fat sooner...
    Attachment 1016147
    14 hours until I pick mine up, not sure I'm gonna sleep tonight!
  38. #338
    Jun 2015
    What would the recommended PSI be for my Farley 5 tires?
    I'm running tubeless and weigh 220lbs.
    Not finding much in the line of calculators or graphs online, and I'm sure it's pretty tire-specific based on height, width, weight of rider, and maybe tubes or tubeless...
  39. #339
    Feb 2015
    There's no bike specific pressures first of all. Secondly you'll have to experiment to see what works for you in various conditions. Start at 9 or 10 psi and go from there.
  40. #340
    Any other follow TrekU Ninjas on here?
    I'm still desperately waiting for my 7 to come in!! All my fellow employees are getting their 5's and 9.8's in stock. I just want my 7! Anyone else get theirs yet?
    My plans for my build are: tubless, 70mm Pro stem, carbon bar, carbon post, carbon saddle.
    I'd be stoked if I can get it to end up at 27lbs.
  41. #341
    Dec 2014
    Quote Originally Posted by ZenkiS14 View Post
    Best wishes on that. The 9.6's are coming in at 27.5-28 with pedals and tubeless. I've put jackelope wheels w/hodags tubeless, Easton EA 70 carbon bars, 1 X 10, Kent EriksonTitanium seat post, lighter Fabric seat and a Salsa Makwa carbon fork on my Farley 6 and it's just at 27.9.
  42. #342
    Jul 2015
    I just want my 7! Will add bluto and probably a reverb. Will go tubeless as well. Really looking fwd to it
  43. #343
    Quote Originally Posted by Ivar Elverum View Post
    Curios as to why you just didn't go for the 9?
  44. #344
    Jul 2015
    Considered the 9, however, I want 26*4.7 tires, and even if i add bluto and reverb, still haven't reached the 9-price..
    Had to stop somewhere..
    I do hope that the barbegazi tires are good for snow..
  45. #345
    Dec 2013
    Sizing ( Farleys run small ?)
    Guys whats the story with the sizing for these farleys.......A few chaps have mentioned they run small ?
    Im 5' 7" ? Obviously its going to be either a 15.5 or a 17.5.
    Has anyone made that choice already ?
  46. #346
    Feb 2015
    Wasting money until you get rid off the low hanging fruit/weight in the cranks. A set of Next SL cranks will save you .9lbs
  47. #347
    They were decent in sand when I road a 9.8 (that I am in the process of buying) with them the other day on a beach. I followed that up with a Pivot Les Fat with 26x4's on it and the 27.5x4's were much better than the 26x4's. More float for sure. I'm going to mount GripStuds in them for the winter. I think they will be better than the 26x4's, more than half way to the float of the 26x4.7's and will roll better in general on everything other than loose deep new snow. Groomers - no doubt.
    J.
  48. #348
    That's a good point, I'd probably go X01 over Next though. I'm a SRAM guy at heart. Or I may not play with it at all past the cockpit, get it feeling like I want in the cockpit, and just leave it. It wont be my main bike at all. I'll be doing bars/stem for preference, and carbon post for comfort.
  49. #349
    Apr 2005
    Quote Originally Posted by David Cooney View Post
    I am 5'6" and went to a demo this weekend. The 15.5 was too small for me. I was over max on seatpost and it was cramped. It may work for you if you have short legs and arms or short legs and want to be very upright. The 17.5 felt very comfortable to me.
  50. #350
    Reputation: cr3anmachin3's Avatar
    Feb 2015
    Any new Farley 5 owners here in UK? If so did you get from Evans and how were the delivery times? Looking at it for my first Fatty. I would normally never have looked at Trek bikes but thought these 2016 models were pretty forward thinking and decent price for spec. Interested in owners views. thanks
  51. #351
    Feb 2015
    I couldn't live with the ugly green on blue - it's just wrong.
  52. #352
    Jul 2015
    Quote Originally Posted by JohnJ80 View Post
    J.
    It's the groomer look and effect I want.
    In the end it was a question about how much, and the stomach feeling. I did land on the 7 and we can go back and forth a million times if I should've decided on the other one...
    In the future my fs may have 27,5+ (probably) and my fatbike will have 26*6?
  53. #353
    Feb 2006
    I think it's one of their better color combo's!!
  54. #354
    Either way, with the trek 2016 fat bikes, the downside risk is another set of rims and tires. With other bikes that are not set up the same way, it's worse because the downside risk is to have to get a different bike. Also, I'm going to have to stud the tires myself since there are not any 27.5x4 studded tires yet. Not a big deal, but one more thing to do.
    In my case, and for where I'm going to ride, I was pretty sure that the 27.5x4 would work after talking to the factory and looking into it with my LBS but I wasn't sure. When I got to ride it, and then compare it to a 26x4, then it was clear. But, I think, it's an individual decision and I think preferences are all over the map on it. What i can say was that I was really impressed with the bike and it's handling.
    J.
  55. #355
    Jul 2015
    About size, I'm 181cm and i ordered 19,5"
    edit: yeah, keep my 7 next year just upgrade with a new wheel set
  56. #356
    Feb 2015
    Quote Originally Posted by litespeedaddict View Post
    Blech!!
  57. #357
    235 lbs here. Last winter I ran my tubeless Dillinger 5s at 4-5 PSI on soft , deep snow increasing to 8-10 PSI on hard pack.
  58. #358
    Reputation: Way2ManyBikes's Avatar
    Quote Originally Posted by Thrawn View Post
    That' one hell of a demo!!!
    Curious now... Anyne try and fit a 27.5 x 3.8 setup on a Farley 6 or 8?
    I have a set of 27.5 Scrappers with Panaracers 3.5 and there is plenty of room and are they are a blast to ride.
    Btw both my bikes are 14 Farley
    Marty-mj
    www.garagescene.net www.syborgtwinturbo.com www.2ndcamaro.com
    Marty
    12 JamisDakar650B
    14 FarleyBlue,Bluto,i9-Hed,4.JumboJims
    14 FarleyBlack,Jackalope
    17 Farley 9.6 Under Construction
  59. #359
    2016 Trek Farley 5, 7, 9, 9.6, and 9.8 Fat Bikes
    I guess we'll see as more people get them. I for one will be disappointed if my 9.8 isn't under the 25lb mark. Especially when 907 is showing a sub 19lb build.
    It's possible to get the bike sub 23 with a carbon fork if you buy all the right parts but it's expensive. I'm considering a carbon frame however I'm pretty hard on my bikes.
    Marty-mj
    Marty
    12 JamisDakar650B
  60. #360
    Mine came in at 24lb 2oz sans pedals. Shire would have been nice to see 23 but I honk I'll survive lol....
  61. #361
    Feb 2015
    Honking in the Shire - sounds like good times!
  62. #362
    Aug 2015
    Picked up a Farley 9.8 last week. Absolutely love it. It's my first Fat Bike althought I've demoed a few.
    I did manage to generate a slow leak in the front tire after the first ride. Due to there being ZERO replacement tubes in stock anywhere, it is now set up tubeless front and back.
    Still waiting on my xpedo spry pedals (tomorrow). Currently it weighs in at 24lb10oz for a 17.5 frame.
    https://scontent.xx.fbcdn.net/hphoto...23263021_o.jpg
  63. #363
    24lb10oz is tubeless?
  64. #364
    Aug 2015
    That was the weight after the tubeless conversion.
    The more I ride this bike the more I love it. It's just so much fun.
  65. #365
    Feb 2015
    Anyone got a weight for the 2016 Farley 5 out of the box stock with pedals pls?
  66. #366
    Just picked my my Farley 9.6, size XL. Weighs 28.6 lbs with tubes, without pedals.
    Planning to convert to tubeless and will weigh the wheels while I have them off the bicycle.
  67. #367
    Quote Originally Posted by cr3anmachin3 View Post
    Not with pedals but complete otherwise reflectors and all. 19.5 frame.
  68. #368
    Feb 2015
    ah great thanks for the info. 15kg then...was hoping for something a bit lighter but I suppose it is the entry level model. Do you run a bike shop or dealership? I was looking to get one in the UK but only a few places stocking them and one of those is Click & Collect and too far away from me.
  69. #369
    Sep 2015
    Can someone help me out with more details here? I am considering this option, but want to make sure I get it right. I have a 9.6, and here is what I am looking at going to:
    Amazon.com : Race Face Next SL 10-11 Speed 175 Crank Arms with 170 Rears : Bike Cranksets And Accessories : Sports & Outdoors
    Is this all that I need? Should I get the 170mm or the 175mm? I think my current one is a 175mm but I am not sure. Is this all that I need, and is it just a 'plug and play' to change the crank arm out, with the same bearings, sprocket, etc? Sorry for the dumb questions, but I don't want to order a $400 part and have it be wrong.
    Thanks,
  70. #370
    Feb 2015
    You'll need the appropriate bottom bracket to accommodate the 30mm spindle as the Aefect crank uses a 20mm spindle.
    Having said that, it's a lot of money even for that amount of weight - think on it. I'm still toying with it but I think I've decided I'd rather keep my money or spend it on some 29+ wheels, XT brakes, and maybe a suspension fork down the road.
  71. #371
    Lord Thunderbottom
    New bike day, farley 9
    No time for pictures, i built it and went riding
    Sent from my SCH-R530U using Tapatalk
  72. #372
    Lord Thunderbottom
    Just kidding, here's the important stuff
    21.5" frame
    Stock out of box weight
    Thomson post, haven carbon bars, ESI grips, issi triple pedals, tubeless
    His and hers, yep non drive side, in a hurry to go ride
    Ride was awesome, going backwards from lous on shoes on my blackborow to this for a summer purpose bike, this wheel size makes sense to me
    So long to my 29ers
  73. #373
    Feb 2015
    How much lighter to the carbon bars feel in your hand compared to the stock ones? Just curious. I ask because I pulled the stock seat and seatpost out of one and it weighed next to nothing.
  74. #374
    Lord Thunderbottom
    The bars with the grips and garmin mount felt close to the weight of the stock bar alone, the haven bar is slightly narrower, its more for comfort than weight
  75. #375
    Feb 2015
    Got it, thanks.
    Waiting on my 7...
  76. #376
    Weighed a bone stock with pedals and reflectors 19.5" Farley 7 tonight. 30.38lbs, still waiting on my bike though...
  77. #377
    Thanks,
    If you order that set you will need a chainring as well...
    Msg me if you would like to buy a complete setup, including chainring 170mm arm length bottom bracket as well
  78. #378
    Feb 2015
    So...was about to buy a Farley 5 (against all my girlfriends protestation!) and looked at Evans and LeisureLakes Bikes and they are all Click & Collect and too far away for me to get the bike. Seems I am doomed to defeat but then found a local Trek dealer really close to me who thinks he can order in for me at cost price. WIN ! I am sure though once built those guys will not be able to resist having a go on it. Will update here if/when I get it. EXCITING !
  79. #379
    Reputation: tadraper's Avatar
    So my wife took me bike shopping yesterday, and this it what i left with!!!
    WHAT A FUN BIKE OUT ON THE TRAILS first ride was the POTO in SE Michigan last night can't wait for a day ride!!!! just amazed at this thing.
  80. #380
    Sep 2015
    I don't think they run small. The short seat tube height is to compensate for the increased standover height of the 4.9" tyres, so the frames appear short. Once set up though, my 17.5 feels like, well...a 17.5, despite my perceptions about the frame looking like a trials bike.
  81. #381
    Quote Originally Posted by tadraper View Post
    I don't know if I am more jealous of your bike or wife
  82. #382
    The Trek archives show parts but not geometry for 2015 Farley 8. Do any of you know if 2015 Farley 8 geometry is same as 2016 models?
    I've been wading through a lot of pages here and am trying to find out of a 19.5 2015 model will be quite like my 2016 Remedy in 19 size. Our Trek commuter is 20 and I think Treks must run small. I'm 5'10", and considering a used bike I might not be able to try before buy.
    Thank you.
  83. #383
    Reputation: tyriverag's Avatar
    Jan 2014
    Quote Originally Posted by bitflogger View Post
    Thank you.
    I believe the geometries are roughly the same, with maybe minor differences to handle the fatter tires.
    it's a challenge some of us are ultimately worthy of.
  84. #384
    Thank you.
    I'm 5'10", and I ride a 18.5" Remedy 29, a 20" 7.4FX, and I chose a 17.5" Farley 7, the 19 just felt too long and big in general. I could probably get away with a 19.5" if I were to run a 50mm stem, but thats not ideal for this geometry.
  85. #385
    Jun 2015
    Quote Originally Posted by dEOS View Post
    my thoughts exactly!
  86. #386
    More Farley 9.6 size XL weight info:
    Bicycle, tubeless with Xpedo Spry pedals: 27.4 lbs
    27.5 Hodag tire: 1230 gr (only weighed one)
    27.5 tube: 440 gr (both weighed the same)
    27.5 wheels:
    Front: 1300 gr
    Rear: 1640 gr (seems too heavy but I've mounted the tire and can't recheck)
  87. #387
    Aug 2015
    I got a 17.5 for my Farley 5, when I saw it I thought it looked small but when I rode it I found it to be perfect size, on the other hand the 19.5 Farley 6 seemed to be the right fit for me. I haven't compared geometry but they must be different...
  88. #388
    27.5 Jackalope rims should be about 930ish+ grams each.
    26 ones are supposed to be about 870 grams.
    Counting 32 dt competition spokes at about 6 grams each is 192 grams.
    brass nipples at 1 gram per nipples so 32grams.
    that leaves about 486 grams for the hub. hope pro 2 fat is 370ish.
    So, not horrible. but certianly not great. If they were cut out rims it would be less for sure. And the hub is heavy, but for a price point wheel, it is in line with most.
    sure you could make lighter ones. but they would cost you near 1k.
  89. #389
    Can anyone help me find geometry for the pre-2016 bikes? The Trek archives don't have that. Some articles mention 70 degree head angle and 17.3 chain stays. I wasn't to know effective top tube, reach, and stack. To help decide if the used 19.5 in my area is too big for me.
    Thank you.
    ƃuoɹʍ llɐ ʇno əɯɐɔ ʇɐɥʇ
  90. #390
    Nice!
    Back in 2011, for my birthday, my wife opened a profile here to see what I was in to and ask around some questions as to the types of bikes I'd be interested in. She called around to various shops to see who had what in my size. In my birthday card she outlined what was going down and where we could go to test ride. I made the decision and she called around to negotiate final pricing and pick up date. (Giant Anthem X 29er)
    In late 2012 she was off of work doing some online shopping and called me to update. Jokingly, on a whim I told her, "while you're at it I'd like a 2013 Salsa Mukluk 2 frameset black/grape ape size small". An hour later she forwarded me the confirmation email for the purchase. When I got home she mentioned the guy on the phone at Bikeman proposed to her.
  91. #391
    Oct 2012
    So I decided to stop by my LBS yesterday hoping that my 7 came in and they've been trying to get ahold of me and had my cell number messed up. And low and behold, one lonely 7, size medium, was setting on the showroom floor! I'm like "hey, that's my bike!" and they were like, "what?". I told them that I put a deposit on a 7 about 2 months ago and have been waiting for a phone call. They said that this was one of the bikes that they preordered proir to me putting a deposit down, so that's why my name did not pop up in the system when it came in. Ugh! Luckly, it's only been sitting there since Tuesday and no one came in a swept it up in front of me!
    Heading out for a quick ride in about 30 minutes!
  92. #392
    Feb 2006
    I normally just get kinky sex for my birthday, which I was perfectly happy with, until I caught up with this thread this AM. Now I feel a little short changed. Seriously, a fatbike for a birthday? Dude.
  93. #393
    setup my 9.8 tubeless today since it is raining,, what an easy task. remove air pop one side of the tire off to get tube out add sealant use floor pump to reseat tire!!
    my tubes weighed 1.45 lbs on the kitchen scale hope to weigh the bike soon.
    did a mixer last night rail trail, gravel and trail what an all around great bike..
  94. #394
    Feb 2015
    Quote Originally Posted by tschram72 View Post
    Lies
    Pics or it didn't happen!
  95. #395
    Reputation: ForNow's Avatar
    Nov 2014
    Fan of the bike and your truck.
    I rode a Farley 9.8 today. Really liked it. Holding it for couple days to decide.
    If I get the bike, I'll post a similar photo with my 2015 GMC HD.
    ______________________________
    Farley 9.8.5
  96. #396
    Oct 2015
    Hi everyone!
    I just bought myself farley 5 2016. I was planning to put bluto on the front.
    Im having trouble finding proper conversion caps for the hub. If anyone know what fits, ill be glad.
    I found drawings at the forum, so its possibility to mill them, but the drawing is from farley 6 and not sure that the hubs are same?
    Thanks.
  97. #397
    A question for any 9.8 owners... do you know what the Q-factor is on these Farleys? Is the Next SL the 170mm or 190mm wide version?
    Thanks in advance!
  98. #398
    Not sure what the q-factor is but the next sl's on my 9.8 are for the 199mm The rear hub is 197 so the 170 version would be to narrow.
  99. #399
    I hope it's a 169mm spindle and not 189mm. Trek has made a point of saying 5" clearance with 4" qfactor.
  100. #400
    I will go out and take a look and let you know.
  1. 2015 Trek Farley 6 and 8 fat Bikes
    By Robg68 in forum Fat bikes
    Last Post: 06-19-2017, 09:16 AM
  2. When should the 2016 models roll out?
    By Tizom in forum Santa Cruz
    Last Post: 12-05-2015, 12:58 PM
  3. Remedy 29 availability in EU, 2016 models ?
    By 20.100 FR in forum Trek
    Last Post: 04-17-2015, 06:29 AM
  4. Replies: 4
    Last Post: 10-04-2014, 11:31 PM
  5. Trek Farley 6/8
    By BigVaz in forum Trek
    Last Post: 06-23-2014, 08:29 AM
Members who have read this thread: 175
