Results 1 to 13 of 13
    2014 Pugsley Offset
    I email Surly concerning 2014 Pugsley offset and this was the reply I received.
    "For 2014 all the painted frames will come with a painted to match Moonlander non-offset fork. The black Pugsley frame will come as a frame only option so you can get an offset fork. At this point we have decided to redesign our offset fork so there won’t be any available until that redesign process is done, but we will have offset, painted to match forks for our 2014 bikes available late this year."
    Kinda sucks if you already own a set of offset wheels (like I do). I'm back to checking eBay daily in hopes of finding a good used 18" frameset.
    Steve Heywood
    Buckeye, AZ
    Reputation: Mark_BC's Avatar
    Sep 2012
    So does that mean you can't swap front and rear wheels? I just ordered the green frameset including fork. That's a bummer.
    Quote Originally Posted by Mark_BC View Post
    That is indeed what that means. Interested to see what the updated offset fork will be.
    Oh noes. I'm going to drink the Kool-Aid.
    Sep 2012
    I guess it could be worse, at least I get a Moonlander fork and can put a gynormous tire on if I want. Buying another fork later on isn't that big of a deal I guess. I like that it has water bottle mounts.
    My guess is the offset will be the same 17.5mm as it always has been, but they will make some 'hidden' structural changes after the recent recall of these and the 100mm forks.
    Reputation: vikb's Avatar
    Although I am a fan of the swappable Pugs offset fork - the cost of rebuilding the wheel offset and buying a new fork isn't worth it unless you are doing some front end upgrades anyways. I'd just ride the Moonie fork until there was a reason to mess with the front wheel.
    Safe riding,
    Vik
    www.vikapproved.com
    Sep 2012
    Can you ride an offset front wheel on a Moonlander fork? Does it feel weird?
    I'd imagine there'd be some rubbing. And if there wasn't any rubbing, it would definitely steer funny as the wheel would be offset from the centerline of the bike.
    I'm not too thrilled about this :/ I don't mind losing the offset, but I don't want all the damn holes in the fork.
    Jason
    Disclaimer: www.paramountsports.net
    never summer
    Reputation: singlefin's Avatar
    2014 Pugsley Offset
    Quote Originally Posted by JAGI410 View Post
    Chalk it up as weight savings?
    May 2012
    Well you also need another wheel to use with the offset fork.. so not just as simple as purchasing an extra fork.
    Reputation: Schott's Avatar
    Nov 2012
    2014 Pugsley Offset
    Quote Originally Posted by singlefin View Post
    Scratch that, reverse it, and you've got it. Threaded inserts and bolts add weight
    never summer
    2014 Pugsley Offset
    Quote Originally Posted by Schott View Post
    Yea your right. The can remove the bolts...there are 22 of 'em on the Necromancer. No scale but a safe bet is 1-1.5 grams.
    Can't please 'em all. One thing I like about Salsa and Surly is all the extra mounts. Wish the Pugs and Moonlander had mounts under the downtube.
  1. 2014 Surly Pugsley & Moonlander colors
    By nitrousjunky in forum Fat Bikes
    Last Post: 09-30-2013, 08:17 AM
  2. Pugsley Going Away From Offset Frame Design?
    By onepivot in forum Fat Bikes
    Last Post: 03-23-2013, 02:49 PM
  3. Salsa Anything Cage on Pugsley offset fork?
    By empire_builder in forum Fat Bikes
    Last Post: 06-15-2012, 11:47 PM
  4. Pugsley Offset?
    By thekrow4jc in forum Fat Bikes
    Last Post: 01-24-2012, 07:55 PM
  5. Paid Spam: 29er offset rear wheel for Pugsley
    By 96gfjoshua in forum Fat Bikes
    Last Post: 04-18-2011, 06:03 PM
