Results 1 to 10 of 10
    Jun 2010
    2013 mukluk 3 crank arm
    I own a 2013 salsa mukluk 3 and I love the bike I'm stationed in korea and since I got here i have had to spend more money than i expected with unexpected breaks. I was wondering what to do about my loose crank arm on non drive side. Do I buy a new crankset and bb or do I just see if someone has a crank arm that someone upgraded out of or do I just get a whole new set up. Im currently on a budget and don't have tons of money to throw at the bike. What should I do. Im 235 lbs and kinda need a stout bb and crankset what kinda recommendations do you guys have for decent priced ones. Thanks for reading my rambling post and for your time. I removed the bottom bracket for lubing the other day. and I was wondering if im supposed to have a washer on the inside of the crankarm or something.
    Reputation: calzonical's Avatar
    Aug 2005
    I am assuming you are running the stock crank set with an ISIS bottom bracket. If this is the case, then you may have a crank bolt that is bottoming out within the bottom bracket spindle but is not fully seating the crank arm to the spindle. you may want to place a washer inside the crank arm (or back side of crank bolt) and then insert the crank bolt and tighten.
    Jun 2010
    I tried to they a washer at the three cheap bike shops in my area and no-one could under stand what I wanted to do. I think that's what's wrong will washers really fix that
    Aug 2005
    Washers are cheaper than a whole new crankset. you could fabricate a washer from thin plastic, aluminum can (may need to fab more than one), etc. Good luck!
    Jun 2010
    Thanks man.
    Reputation: tundratrader's Avatar
    I assume you have tightened everything up already?
    Jun 2010
    Of course I did
    Just making sure man didn't mean anything by that. Maybe you have a bottom bracket issue. I would pull it if you have tools lube it and reinstall.
    Jun 2010
    The washer made it tight but now the bolt keeps getting loose
    Aug 2005
    apply blue loctite (non-permanent) to bolt threads
  1. Replies: 22
    Last Post: 03-26-2015, 08:41 AM
  2. XX1 Crank on my Mukluk
    By larres in forum Fat bikes
    Last Post: 06-12-2014, 04:59 AM
  3. 4.8's on 2013 Mukluk?
    By dvn in forum Fat bikes
    Last Post: 12-14-2013, 04:35 PM
  4. Mukluk Crank Options
    By Sasquatch1413 in forum Fat bikes
    Last Post: 06-27-2013, 07:49 AM
  5. 2013 mukluk 2 vs 3
    By Dan GSR in forum Fat bikes
    Last Post: 12-24-2012, 10:19 AM
