Results 1 to 12 of 12
    Jan 2015
    170x10mm hubs with a thru-axle/bolt?
    I just ordered a new Salsa Beargrease X5, but turns out its QR, even though before I ordered and looked at the website, one of the frame features is '177x12 symmetrical rear spacing.' I guess its spaced at 177, but the dropouts only take 10mm QR? Kind of misleading.
    I do really want the bike and like everything else, was going to put bluto up front and then an x9 1x10.
    Question is does anyone make a skewer/bolt or thru-axle that is an actual 10mm vs using the 5mm QR. Is it even worth worrying about on a rear tire that will be sitting at 6-8psi? I know, you get what you pay for... as far as a $1500 fatbike but I really like the alloy beargrease.
    I can get a deal on a carbon x7, but then my upgrade budget is shot and carbon is not important to me with this bike.
    Bike will be here and built this week.
    Reputation: watts888's Avatar
    Oct 2012
    Looks like they exist, but you'll have to swap out the rear hub, which starts pushing the "why bother" button.
    Fat Bike Bolted Axles | Hubs - Axles | Hubs/Cassettes | Products | Halowheels.com
    since it's a hardtail, as long as the QR skewer is a good quality one and the wheels is installed in the frame properly, it should be fine. I use a QR on my 29er hardtail and my fatbike rear wheels, and they haven't failed me yet.
    Front axle, I'd definitely make sure it's a thru-bolt/thru-axle design though. I have a 135mm QR on my fatbike, and with a steel salsa enable fork, you can really tell there is flex.
    "a hundred travel books isn't worth one real trip"
    since 4/10/2009
    Reputation: Harold's Avatar
    That's just a regular QR. The axle itself is 10mm (and hollow), and the QR skewer is 5mm. Like watts posted, if you want a bigger bolt, you'll likely have to do a wheelset change. Theoretically, any hub you can get in a fat width with 10mm DT RWS endcaps could take a 170x10mm bolt/skewer, but hubs that offer that option are limited and tend to be expensive ones. Hope, I9, DT Swiss (of course), and just a few others will offer that. It's not clear to me if the bolt-on axles watts posted will work in ANY hub available with 10mm endcaps. Maybe, maybe not, but a wheelset change would be pretty pricey when you're talking about these sorts of hubs.
    You may have missed a couple of things on the BG frame specs that differ in some cases between carbon frames and alu frames. Seatpost diameter is another.
    Te mortuo heres tibi sim?
    Here's a thought:
    does anyone make an allen bolted fat rear 170mm skewer? Something like the Control Tech or Halo skewers?
    I've found those can make a little difference over a standard QR. Plus, they look slick and sano. Will buy it if I find it!
    Jan 2015
    Beargrease x5 order canceled. Walked out of store with Carbon X7 for 2299 and rode snow covered trails for lunch.... QR concern no longer a concern. Buying Bluto anyway... why. Because 'merica! that's why.
    Reputation: dvo1's Avatar
    I have a salsa hub with a 170x10mm thru bolt.
    Only one I have seen
    Reputation: Swerny's Avatar
    Mike
    Toronto, Canada
    2017 Trek Farley 9.6 with Lauf
    2017 Diamondback Haanjo Trail Carbon
    2016 Scott Solace 10 Disc
    Reputation: dbhammercycle's Avatar
    Quote Originally Posted by dvo1 View Post
    It's a formula hub. I've seen it also.
    Novatec makes one also.
    Hope makes endcaps for a 10mm thru axle, but no skewer.
    I don't know why,... it's just MUSS easier to pedal than the other ones.
    Jan 2015
    Quote Originally Posted by dbhammercycle View Post
    Deja Vu from the threads that I originally searched/read before starting this one... In 6 months, someone will search this topic and find my thread as well as others, read it and wonder if anything has changed... and start a new thread only to find themselves caught in a never ending cycling of non-10mm-thru-axle-ness.
    ^yes, I've reread those a few times myself. I may just have to order a fatback import hubset or novatec rear wheel just to get the rear hub with a 10mm thru axle followed by a sale of the front hub or rim to recoup some small amount of fundage for spokes. Leaning towards the fatback import set to get some color and I figure the front hub will help more to fund spokes. I could keep the front hub, but then I'd need a new fork. I could have 2 wheelsets then I suppose...
    Won't somebody just sell a 170mm rear hub with a 10mm thru axle please? I'm not the only one interested...
    Jan 2015
    Thankfully, because its an awesome bike, I went with the beargrease c x7, but that was my original plan had I gone with the beargrease x5. But it would have been a pain depending on the hub if it would have taken the 10 mil thru-skewer or did it have pure qr endcaps and not convertable for a 10mm skewer. Then Im rebuilding wheels with new hubs or trying to perform surgery on the hubs came with. And ultimately, I would have just left it QR... until I had a real reason to build a new wheelset (carbon or something like a plus wheel for summer or for a 15mm hub for a bluto).
    Now that I YOLO'd on the carbon beargrease, Im happier with the build spec anyway and have th 12/15mm f/r TAs as a consolation.
    This is what I meant for the QR thing.
    Hex Key Skewers | Hubs - Skewers | Hubs/Cassettes | Products | Halowheels.com
    Though I'd happily convert my Hope Fatsno 170mm to a bolt to.
  1. Replies: 0
    Last Post: 02-15-2014, 09:53 PM
  2. New 6 bolt hubs for a 29er
    By lukeom12 in forum 29er Components
    Last Post: 06-05-2013, 05:59 AM
  3. How to swap my QR axle for a Bolt on axle
    By cummings in forum Downhill - Freeride
    Last Post: 02-13-2013, 05:58 AM
  4. SRAM X9 6 bolt hubs?
    By vwgt07 in forum Wheels and Tires
    Last Post: 10-03-2012, 09:18 AM
  5. 6 bolt rear hubs like an XT 775?
    By LookerBob in forum Wheels and Tires
    Last Post: 05-17-2011, 02:13 PM
Members who have read this thread: 7
