Results 1 to 15 of 15
    WNC Native
    Reputation: nitrousjunky's Avatar
    170mm Rear Wheel Build, Muk 2 or Hope FatSno hub?
    I'm getting ready to have a Marge Lite rear wheel built up for my fat bike build. Is the Hope FatSno hub worth the price difference over the Muk 2 hub?
    After having to buy a 170mm skewer separate for the Hope, it's looking like about $100 difference.
    Unless I am wrong, I think they both have the same engagement. Anyone spent time on both?
    "I ride to clear my head, my head is clearer when I'm riding SS. Therefore, I choose to ride SS."~ Fullrange Drew
    Nov 2007
    I have both. Both work fine. The Hope is much lighter. And louder, if you care about that.
    I don't notice a big difference in engagement. You can get the Hope for $225 online. Hope also makes 170mm skewers now, but I haven't tried 'em.
    I gots a hope fatsno laced to a clown shoe in the classifieds.
    Thingamejigger
    Reputation: Flying_Scotsman's Avatar
    Serviceability on the hope hubs is great!!
    I have the Hope 170mm rear hub (not actually the Fatsno according to the Hope Website).
    I had some issues with the Alum. fh body, and Hope gladley sent me a SS one.
    I like Hope some much I am going to try their M4 and X2 brakes....on a bike I won't be throwing over rocks, floating down rivers, and taking out in sub-zero temps.
    They are too nice for such behavior.
    WNC Native
    Quote Originally Posted by tri-tele View Post
    Seen that, Clown Shoe is way to big for what I'm after though.
    Going 1 by X makes it easier to run fatty rims. They worked just fine with my 907 frame.
    dvn
    dvn is offline
    Reputation: dvn's Avatar
    No experience with the Hope but I have the Mukluk 2's and the engagement is terrible. I can't imagine the Hope being as bad.
    "Either way it doesn't really matter, I just got back from a bike ride."
    > dbhammercycle
    WNC Native
    Quote Originally Posted by dvn View Post
    Hope is 24pts, almost positive Salsa is 24 pts also. Hadley and the Paul/I9 hubs are the only decent engagement hubs out there.
    I plan to be either SS or 1x. However this will be used for trail riding rocky/rooty terrain, so that wide of a rim would be getting lot of rim hits.
    aka bOb
    Reputation: bdundee's Avatar
    I've had two Muk 2 hubs and one had bad engagement and one was great. I took them apart to put some lighter freehub grease in and the one with bad engagement had one pf yje pawls installed wrong, you might want to investigate a little.
    Wizard of the Trail
    Reputation: Geist262's Avatar
    I have a muk2 hub on my 907. I will replace it with a hope. I already replaced a free hub body and my friend changed two plus a hub. We are both Clydes though.
    There is no charge for awesomeness......or attractiveness.
    Good rep does not wash out the bad, nor the bad the good.
    I have both hubs, and there is no comparison. The Hope engages much faster than the Salsa- $100 is not a lot for the return on quality. If it were $200 or more, then it would be a more difficult decision.
    WNC Native
    Geist262- Thanks for that info, I'm at my lightest weight in years at 190. So this does help with the decision.
    deuxdiesel- Also helpful info, think you guys have talked me into the Hope now.
    aka bOb
    I know you decision is made but I agree Hope is a way better investment.
    Wizard of the Trail
    Quote Originally Posted by nitrousjunky View Post
    Your welcome. Also, someone mentioned that Salsa's hub doesn't engage all that well. Very true. I suspect I will be on a new hub by winter. The other day I was out and I heard a crack sound come from the rear. The pawls were probably between engagement points.
  1. Replies: 1
    Last Post: 08-16-2013, 09:47 AM
  2. Hope 170mm rear hub - bolt on??....
    By Shark in forum Fat bikes
    Last Post: 05-23-2013, 01:42 PM
  3. Rear Cassette Is Hungry For Hope Fatsno
    By jonshonda in forum Fat bikes
    Last Post: 01-27-2013, 09:12 AM
  4. Rear Cassette Is Eating Hope PRO 2 Fatsno
    By jonshonda in forum Wheels and Tires
    Last Post: 01-25-2013, 07:45 AM
  5. hope fatsno hub dimensions
    By dRjOn in forum 29er Bikes
    Last Post: 11-18-2012, 07:09 AM
