Results 1 to 26 of 26
    Reputation: motorman's Avatar
    100mm rims on the rear of a 907??
    Has anyone got any photos of 100mm rims mounted on the rear of their 907?
    I was wondering about a 2nd wheelset for beachriding on my 2011 frame, but I do wonder about the frame clearance when using these rims & regular Larry, even though it is stated they do fit.
    Just want to see how snug they are
    Drink coffee....ride bikes....eat cake
    http://morayfatbike.blogspot.com
    Fat!Drunk!Slow!
    Reputation: JordyB's Avatar
    Oct 2007
    With a 100mm/larry combo, i'd be more worried about drivetrain clearance.
    That can be dealt with, but I need to be convinced that they can be squeezed in before building begins
    aka bOb
    Reputation: bdundee's Avatar
    I know there are people running a BFL on a 80 on the older 907's. Not sure what the width difference is between that and a skinny Larry on a hundie.
    I have tried that, but when I put the power down, there is enough flex in the wheel to cause rub, as there is only a few mm clearance
    May have to buy something fatter for beach work & keep the 907 for trails/camping adventures as I love it
    aka bOb
    Quote Originally Posted by motorman View Post
    Oh yeah maybe that was you who I was referring too and MauricioB. Oops.
    Reputation: coastkid71's Avatar
    Give me a M, give me a O, give me another O, give me an N, give me L, give me a etc...
    You know you lust the bike whose name we shall not speak...
    plan it...build it....ride it...love it....
    http://coastkid.blogspot.com/
    It aint gonna ride itself
    Reputation: MauricioB's Avatar
    Oct 2007
    Quote Originally Posted by bdundee View Post
    That was me. I had a BFL on a 70mm UMA 2 in my 2010 for a while, but when I'd stand to pedal it would rub the chainstays. Went back to an Endo on the rear. I suspect you'd be fine with a 100mm rim/3.7 or 3.8 tire, but I haven't tried it myself.
    Geordie biker
    Reputation: saltyman's Avatar
    Quote Originally Posted by coastkid71 View Post
    Shhhhhhhh......
    2014 milage so far - 2,485
    www.ukfatbikes.co.uk
    Grrrh....I'm building a Surly LHT as we speak, please don't make me buy another bike
    Fat Bike Specialist
    i have 2 sets of wheels for my current 9:Zero:7
    - flat top 100's/larry rear, BFL up front
    - marge lite/huskies
    running MWOD crank, moonlander spindle, and front deraileur adapter
    all gears...
    direct,easy swap...great to have both...
    JayP
    Disclaimer: Posted by Fitzgerald's Bicycles in Victor, ID.
    aka bOb
    Quote Originally Posted by Fitzgerald'sBicycles View Post
    all gears...
    JayP
    Do you have a 2011 or 2012 frame?
    Aug 2010
    907 2012 without offset + FlatTop 100 + BFL + 5-8 PSI (On 15 PSI rear wheel not fit to frame)
    Photo after several trips.
    fatbikes.com recommended to me this setup. no apologies, no decision from them I have not received so far.
    very bad service.
    now I buy moonlander and happy with rear wheel clearance!
    Attached Thumbnails Attached Thumbnails 100mm rims on the rear of a 907??-non-drive-side.jpg
    I have rolling Darryl with nates and it will not fit Older 907
    Reputation: alaskairhog's Avatar
    I have a 2011 9zero7 with 100mm flattop rims, endo in the back, some minor chain rub in granny gear but no issues.
    Have you got any pics?
    Reputation: Velobike's Avatar
    I've got some 100mm rims. I'll lend one to you so you can fit a BFL, Larry, Nate, or Endo to it and measure how far into your stays it will go. Then there's no need to get 100mm rims to build a wheel unless it works.
    I could also do this with my 907, but I suspect my mudguards would get in the way, so I'd have to remove them.
    Latitude: 5736' Highlands, Scotland
    LBS Manager
    Reputation: Johnny Hair Boy's Avatar
    I have Flat Top 100's and BFL's on my 907 and I have no frame rub. I needed to do some creative drive train spacing but I did not loose any gears. I run the tires around 5 psi
    Velo, I have to go to Norway for a couple of weeks, but I might take you up on your offer when I get back & maybe catch up for a ride somewhere
    My bike is an "old" 135mm frame, so there is no way a BFL is going to fit in the rear. It doesn't even work with 80mm rims
    Muskoka
    Reputation: BlackCanoeDog's Avatar
    Jul 2003
    Quote Originally Posted by Johnny Hair Boy View Post
    Johnny, is your 907 170mm or 135mm frame? Fatbikes.com site clearly states that the 170mm frame is designed to run 100mm rims, so why is this even a question
    Your bike looks awesome btw!
    https://get.google.com/albumarchive/...127?source=pwa
    RSD Bikes "The Mayor"
    Rocky Mountain Sherpa Overland
    LBS Manager
    Quote Originally Posted by BlackCanoeDog View Post
    My bike is the 170 rear spacing. with a BFL it is close but it works. Since the last time you saw it I have removed the smallest cog and spaced the cassette out just to be safe
    If you are referring to my post, the 2011 frame is 135mm only. A nate on 80mm rims barely fits, so I wanted to find out how folks get on with 100's.
    Anyhow, I'm not wasting any money or time on this, I am buying a moonlander now & keeping the 907 the way it is.
    Muskoka
    Jul 2003
    OK, I didn't know that, thanks.
    Muskoka
    Jul 2003
    So Johnny are you implying that the 170mm frame was not really designed to take the BFL?
