Results 1 to 3 of 3
    Apr 2015
    100mm Eccentric Bottom Bracket?
    Trying to make a pre-alternator Mukluk into SS.
    Anyone have ideas?
    I've read that Problem Solvers PF30 can be extended with the right bolts but wouldn't have any idea what size or where to get them.
    I live in Indy and work with the coolest people in the world at
    Gotta have Bonnervision
    Reputation: Velobike's Avatar
    The larger effective diameter can interfere with the granny ring mounts on some cranks (it did with mine) but this can be solved by spacing the crank out a bit if needed (assuming it allows this), or as I did, simply grind them off.
    You also need their tool.
    Latitude: 5736' Highlands, Scotland
    Reputation: bikeny's Avatar
    What kind of BB shell does your Mukluk have? If it's threaded, I think you only have 2 choices, the above Exzentriker, or the Phil Wood Philcentric.
    If it has a PF30, than there are more options. None marketed directly for 100mm BB though. The Problem solvers, Niner Biocentric II PF30, etc. will work, you just need to source 30mm longer bolts.
    I'm using a Niner Biocentric II PF30 on an 83mm BB fat/29+ bike with great results.
  1. Eccentric Bottom Bracket help!
    By Dantesays in forum Singlespeed
    Last Post: 07-16-2015, 09:25 AM
  2. Eccentric Bottom Bracket
    By jburm in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 10-03-2014, 06:14 AM
  3. Tensioner v. Eccentric Bottom Bracket
    By Lars_D in forum Internal Gear Hubs
    Last Post: 09-29-2014, 06:36 AM
  4. Eccentric Bottom Bracket Conversion
    By azmtbkr81 in forum Bike and Frame discussion
    Last Post: 02-17-2013, 05:42 AM
  5. Eccentric Bottom Bracket EBB help
    By spistols in forum 29er Bikes
    Last Post: 08-24-2012, 03:33 AM
