Results 1 to 51 of 51
    Oct 2012
    V Brake Install on Specialized Hotwalk Balance Bike
    Installed v-brakes on my sonís Specialized Hotwalk 12Ē balance bike. Got a bunch of tips from a fellow blogger. Below are the parts I've used for anyone interested:
    Parts:
    - V Brake mount adapter (Evolution Bike Co in Georgia $60)
    - V Brake boss from LBS $5 (10mm coarse thread)
    - Tektro Mini BMX Brake/Lever/Cable set from JensonUSA $17
    I shaved down a section of the brake pads since the rear of the pads were closer to the rim than the front and throwing off the modulation of the brake lever squeeze. This is because I moved all the concave pad washers to the outside of the v brake to allow the brake arms to be within recommended specs. If I installed with the pad washers in the proper positions, the top of the brake arms would have extended out too much, and I didnít want the arms getting caught up on my sonís legs.
    Otherwise, the install was straight forward. My 2.5 year old son can grab and pull the lever without issue.
    Attached Thumbnails Attached Thumbnails V Brake Install on Specialized Hotwalk Balance Bike-dsc_0113.jpg
    Great idea! Wish I did it when my daughter had hers.
    GMF
    GMF is offline
    Mmm... Tasty
    Reputation: GMF's Avatar
    I like it! Getting him used to hand brakes now will aid the transition to a "real" bike that much easier. Good job :-)
    Oct 2012
    Thanks for posting this! My son's Hotwalk doesn't have brakes either so I was looking for ways to add brakes to it. Looks pretty straight forward and relatively inexpensive. Thank you!
    Havok
    Reputation: Jordan300's Avatar
    Such a good idea. Great work.
    Oct 2012
    I'm having difficulty finding the clamp on v-brake adapter online. Is this a LBS only item?
    I did something similar, but install a disc brake.
    Quote Originally Posted by roesbra View Post
    Sticking finger into a spinning disk rotor can easily amputate a finger, don't leave the bike within easy reach where kids can play with it unsupervised.
    Yeah I'm not a big safety freak but I could never feel comfortable letting my 2-3 year old use that unattended. plus it is way overkill.
    Cheapo
    Reputation: Dave88LX's Avatar
    Glad this came up. I was looking at that and thinking "Damn, that's expensive", but then realized you can just unbolt it and move it on to the next bike when the time comes.
    I have a Hotrock 16 that I want to put a brake on. I was just going to throw a caliper brake on there because something is better than nothing right now (using it as balance, no pedals), but this here may be an even better option.
    EDIT: Looking at the pics of the clamps, do they not already have the V-brake bosses installed? Or am I missing something? Trying to figure out how it all goes together.
    Cheapo
    I called Evolution Bike Co. to order a set of those clamps. They had 3 left when I ordered, and have another shipment of 100 coming in in about two months. He said this new batch will be anodized in various colors. They also charge sales tax for out-of-state sales, just FYI, something about covering their ass with the gov't changing their rules.
    Now to source some v-brake bosses and buy the mini v-brake kit.
    Is the cable that comes in the Tektro mini v-brake kit decent, or should I find something else?
    Quote Originally Posted by GrayJay View Post
    Always be careful with children, never my son is only biking. the purpose disc brake is minimize stress and fatigue when walking child.
    nee
    nee is offline
    Apr 2014
    It's very beautiful.
    Where do you have found the adaptor for the caliper?
    And what this the hub?
    If I can create this one, I create the disc with carbone.
    RaphaŽl
    Cheapo
    Well all my stuff came in, just have to throw it on there now. The v-brake bosses were $10 for a pair of used ones at my LBS. I should have just bought Aluminum ones for a bit more, think of all the weight savings!
    Cheapo
    OK...chain guard bracket is right in the way of the clamp location. I guess I have to grind it off our read around to see what others have done.
    Cheapo
    Unless I can put them on the chainstays instead, haven't checked that yet.
    EDIT: Nevermind, I think it'll hit the chain that way.
    Hmmm.
    CJH
    CJH is offline
    Quote Originally Posted by Dave88LX View Post
    Hmmm.
    Dave88LX,
    What did you ever work out with these? I went to order the V brake adapter plate from Dan's Comp today and it's no longer listed on their site. Guess I'm willing to pay a bit more for these clamp on ones if that's all I can find.
    Jun 2014
    V Brake Install on Specialized Hotwalk Balance Bike-img_3052.jpgV Brake Install on Specialized Hotwalk Balance Bike-img_5020.jpgV Brake Install on Specialized Hotwalk Balance Bike-img_6642.jpg
    Quote Originally Posted by CJH View Post
    Dave follow the instructions the poster put up. I was the one who originally did this but the OP fine tuned it. As you can see I am also running this set up on a 12 in cult pedal bike. The clamps are the best way to go to get the best braking power for your little guy. I chose to go with an avid 5 brake lever as it not only adjust the lever position but also how the easy or hard the lever pulls. My 2 year could easily lock the rear wheel up. Hope this helps
    Dave88LX,
    Reputation: CaRaBeeN's Avatar
    Mar 2012
    Hi,
    I also would like to install v-brake to 12" Scott Voltage Walker
    Do you think will it work?
    Thanks.
    (I've started own topic before I found this thread, anyway that would be useful for future searchers too)
    V Brake Install on Specialized Hotwalk Balance Bike-221811_14767_png_zoom_3.jpg
    2012 Trek Slash 9
    2012 Trek Session 9.9
    Reputation: Goldigger's Avatar
    gambit023
    Hope you don't think I'm taking the pee..
    I'm over the pond in the UK and wanting to fit a rear brake to my crazy sons Hoy balance bike.
    Getting the mounts shipped over might be costly once customs get hold of them.
    Is there any chance you could give me some dimensions on the mounts please? I can then knock some up on my mill.
    Reputation: Nyquist's Avatar
    May 2005
    Hey Goldigger, happy to send you the 3-d CAD model (or pdf of the drawing) of my version of hte mounts if you're interested.
    Sep 2014
    Hi Nyquist, is there any chance you could send me CAD model of your mounts? Thanks
    Here's my mounts I machined...
    Installed the tektro mini V Brakes..
    Aug 2013
    Very impressive, wish I had your skills.
    Dec 2014
    I recently picked up this Tektro kit and custom mounts while working in the states and its a real neat solution. I bought two complete sets so if anyone in the UK needs a set at cost, let me know?
    Sep 2012
    I'm about to add this to my sons hotrock 16 bike. I have the evolution clamps with bosses that came with it and The mini v brake kit. The bolts that came with the kit seem to screw in fine. Am I missing something since you guys went and got new bosses. Please let me know as I'm adding this for Xmas and want to make sure I have what I need.
    Dec 2014
    Quote Originally Posted by Shiftredline View Post
    No you won't need anything else. I used the bosses that came with the V brake kit.
    Cheapo
    Lucky guys. Neither my clamps nor v-brake kit came with the posts, so I had to buy a set on my own.
    Dec 2014
    Please excuse my limited mechanical abilities. Im going to try add these V-Brakes to my Kids Hot Walk. Today he was flying down hills like a wrecking ball.
    Questions:
    1) Is this the item I need:
    Tektro BMX BRK/LVR/CBL Set > Components > Brakes > Linear Pull and V-Brakes | Jenson USA
    I know it says cable set, does that mean its all inclusive with the cable? Yes dumb question.
    2) What is the V-Brake Boss? Is that the peg that comes out of the mount? Because in the photos at Evolution Bike Company Looks like they are already there.
    Thank you for your patience.
    J
    Reputation: griffter18's Avatar
    Item listed looks like what you need but you will need to check with provider to see if it ships with cables.
    The Brake Boss is the peg on which the brake sits again check with the provider that these are included.
    MTB: Stumpy, Enduro, Hotrock, Commencal Supreme
    ROAD: Jamis Zenith, Pinarello Dogma
    Cheapo
    That kit includes brake caliper/lever/cable. Make sure it's the mini kit.
    My Tektro kit did not include bosses, nor did the clamps from Evolution, although I think they may ship with them now, you need to check with them. I got mine from the local bike shop/
    Dec 2014
    THANK YOU... I just spoke to Jenson and they confirmed it does have the cable. Also Spoke with Evolution and they now include the bosses. I should have everything by Friday. Thanks again.
    Dec 2014
    For those of you who did this did you use the 1st 2nd or 3rd hole in the Evolution Brake Mount? If it was the 1st or the 3rd do you mean the one closest to the front or back of the bike.
    Thanks,
    j
    Cheapo
    J, Got your PM. I used the middle hole. Have you tried screwing in the little screws on either side near the pads to get some more spring tension to get the caliper arms to reset back out? It takes a little messing around to set them up.
    Dec 2014
    Thank you for your quick response. My son rides this thing everyday now. So it can't be out of commission to long. I have not played with those screw much, but its good to know it needs to be in the middle hole. Ill put that back on like that. The other question I had was do the spacers on the brake pads need to be adjusted at all or the way they come out of the box is correct?
    Thanks again,
    J
    Cheapo
    OK so those two little screws, you'll see them when you look at the caliper, are what control spring tension (how hard it is to squeeze the lever), and also how the caliper arms center on the rim. Maybe go in a turn per side at a time and see how things work out, then either back off one side or add a little more pressure to the other side if they are off-center.
    There is a fat and a skinny spacer. I believe I have the fat spacer on the side of the pad and the skinny spacer on the outside (nut side) of the pad shaft. They give you a little extra adjustment in/out.
    Dec 2014
    Thanks. Thats how they came out of the box. Ill go mess with it some more.
    J
    Dec 2014
    Thanks again Dave. I did swap the spacers and put the smaller one between the pad (inside) and the lever and the bigger one between the bolt and the pad (outside).
    Overall its not pretty but its working really well.
    J
    Cheapo
    Cool, glad you got it set up! As long as you have a concave/convex spacer on both sides.
    Apr 2015
    Thinking about replacing the brake on my 3-year-old's second hand Hot Rock 12 - it's complete rubbish and she can't use it at all.
    I'm in Ireland, can't seem to source the Tektro mini brake lever - does anyone have another recommendation that I could get in Europe?
    Considering Avid FR5, Tektro TS325A Junior, or a Raleigh Junior.
    I have no idea what I'm doing - I'm a "transport cyclist" at best and I've never worked on a bike before. Can anyone help a mama out?
    May 2012
    Jun 2015
    What is the inside diameter of there brake mounts?
    Dec 2010
    Reviving an old thread just to say thanks to everyone that posted on this topic. Installed a v-brake my grandson's Hotwalk last night, just to get him used to hand brakes.
    Quote Originally Posted by robert w View Post
    Hi,
    I have jus ordered the clamps from evolution. Do they come with the bosses?
    How is it working?
    thanks
    Dec 2010
    Quote Originally Posted by cicot View Post
    Hi,
    How is it working?
    thanks
    Yes they come with the bosses. They work fine but the tolerances are really tight. Kids' hands are really small so the lever has to be adjusted in quite a bit. So the lever distance to activate the brake is very short which means the pads need to be really close to the wheel.
    In the end, they're a bit soft because I can't get them adjusted perfectly (the wheels would have to be perfectly true). But he uses both the brake and his feet and stops fine. And when he got a pedal bike, using the hand brake was natural, so we achieved the actual goal.
    +1 a touch soft but most of the stopping happens with the break. And when my kid got the pedal bike the handbrake made perfect sense.
    Sep 2012
    Another revival on this thread. Hoping to put a brake on my sons hotwalk as per original poster but can't find the evolution brake mounts here in the UK. Does anyone know where I might be able to get them or something similar? There was someone back in 2014 I think that said they had two pairs... bit of a long shot!
    Oct 2012
    Quote Originally Posted by mlusmore View Post
    My second son is just about to move up to a pedal bike. If you want I can sell and ship you the entire brake package. The lever is a bit scuffed up but fully functional.
    send me a PM with your email address for more details.
    Reputation: cmc4130's Avatar
    Nice! I need to get some clamp on v-brake mounts for a 24" BMX that I have.
    Dec 2010
    Quote Originally Posted by cmc4130 View Post
    Call me or text me - I have the ones I took off Landon's Hotwalk. For all the trail work you do that Landon and I enjoy so much, I'll happily give them to you.
    Robert Wood
    Feb 2018
    Hello, is here somebody who can send me drawing of the mounts so i can machine them?
    thanks
  1. XT disc brake rub, pad in-balance
    By duanerowe in forum Brake Time
    Last Post: 05-13-2013, 08:20 AM
  2. Replies: 16
    Last Post: 04-19-2013, 07:19 AM
  3. Shimano Brake Install - Anyone Doing This?
    By phlegm in forum Brake Time
    Last Post: 01-20-2013, 10:30 AM
  4. Specialized hotwalk vs strider
    By OS cuda' in forum Families and Riding with Kids
    Last Post: 11-05-2012, 03:08 PM
  5. XT Shimano Brake install
    By dcc1234 in forum Brake Time
    Last Post: 05-07-2012, 09:46 AM
Members who have read this thread: 28
