Results 1 to 7 of 7
    try driving your car less
    Reputation: jh_on_the_cape's Avatar
    Specialized Hot Rock 24 - done for now
    I found this bike on CL way before my son was old enough to ride it, but bought it anyway and stashed it away. I think this is a 2003 and these came in 2 sizes, 11" and 13.5" and this is the larger one. My son was not really big enough to ride it until he was about 9. He primarily cruises up and down the dirt road we live on and we made a short trail through the woods next to our house. A couple of Saturdays a month we go out with some other dads and boys onto some mellow singletrack, advancing a bit every weekend.
    I wanted to keep this fun and cheap. I see some bikes on here that are too nice to dump on a neighbors lawn while playing whatever. I wanted my son to have that freedom I loved so much at that age. But we all know that a nicer bike will be more fun. Just not too nice to stress about it. I also see some folks posting bikes that cost them very little but took lots of time and expertise. I have little time to tinker with this bike (like make a custom brake arch) but I have the tools and experience, except for wheelbuilding.
    So I took this bike, which cost a little over $100 and found a good compromise with the following:
    carbon bar and post. easy to swap, about $20 each on the bay and dropped some weight and my son thinks it looks cool.
    removed the kickstand
    shorter stem, $10 on the bay shipped from china. how do they do that?
    I felt that the wheels were not worth the $$ to upgrade. he does not need discs. The cassette rear hub was tempting, but I did not do it.
    I left the triple up front because he uses mostly the middle, and sometimes the granny. Removing the big ring does not really save you much of anything.
    the big upgrade that I was on the fence and did it was the fork. the spinner air fork actually works, as opposed to the stock RST. It saved 0 grams. This is the most recent and final upgrade. Only a few rides but I can see it was the right move, as opposed to finding a SID and building a front disc wheel.
    The drivetrain works well, my son can handle it, and the $ for upgrades seems not worth it on this bike. I did put on an old LX front brake because the stock front would not work with the spinner fork (without getting shorter mounting bolts).
    He is the oldest of 3 so it will get some use! I have about $325 into it total. Weighs 25 pounds with the lights and flashing valve caps.
    OK having trouble with pics... coming soon.
    Attached Thumbnails Attached Thumbnails Specialized Hot Rock 24 - done for now-20140122_135742.jpg
    Only boring people get bored.
    Nice start. Check that the tires are not horrendously heavy, I have seen some OEM 24" tires that weighed in excess of 700gr ea, switching to some nice light Schwalbe 24" Rocket Rons or MowJoes can save nice chunk of rotational weight and provide better traction. You might also consider re-building the original wheels with 16 spokes, still plenty strong for kid duty, that is also a good time to upgrade the hubs if the stock hubs are junky. .
    In my post I stated that do not want to rebuild the wheels. I have done a few wheelbuilds and it takes me a really long time with so-so results. If I found someone to do it for me for free I would go with a cassette hub in the back, and done the SID-disc thing up front.
    I think the stock Spec. tires are pretty good just weighing them by hand when he had a flat once. I will let him skid them bald and then look for replacements.
    Next time he flats I will get some light 24" tubes if I can find them.
    Quote Originally Posted by GrayJay View Post
    Jun 2010
    I'd agree with replacing tires, though maybe your Spec. are better... I recently picked up a Trek MT220 on CL and the only thing I've done so far is replaced tires with folding Small Block 8s. Went from 27lbs 6oz to 25lbs 12oz.
    Good luck with your project!
    Thanks! Tires will need replacing soon. I wanted to do this when the bike passes on to younger sibling so it's 'fresh'. What's a good 24" tire these days? Rocket Ron?
    Quote Originally Posted by DSweinhagen View Post
    Jan 2015
    The Rocket Rons are good yes. I got two sets for my boys in 24", and they came in quite a bit under their advertised weight.
    Stand back
    Reputation: dbabuser's Avatar
    Nice work! That's what I'd have ended up with if I could've controlled my upgradeitis. There isn't much to be gained (weight loss wise) by building new wheels unless you spend a lot of $$. I helped justify it by finding disc hubs with a lot points of engagement. The wheels weren't too expensive (building them myself), but after adding in the rotors, not much weight savings to be had.
    Golden Bike Park
    Golden Connector Trails need your support!
  1. Specialized Rock Hopper
    By notthatjeffy in forum Vintage, Retro, Classic
    Last Post: 02-05-2018, 12:26 PM
  2. specialized rock hopper
    By sunyun in forum General Discussion
    Last Post: 01-05-2014, 08:56 PM
  3. Girls specialized hot rock
    By Megacabsledder in forum Families and Riding with Kids
    Last Post: 07-25-2013, 01:48 PM
  4. Replies: 8
    Last Post: 05-02-2012, 06:50 AM
  5. Stolen - yellow Specialized Hard Rock
    By Strangler in forum Colorado - Front Range
    Last Post: 07-27-2011, 10:00 PM
