Results 1 to 3 of 3
    Sep 2012
    Slick Tyre Recommendation, need ideas!!!
    I have a 20" bike which I'm building and will be using a 406 rim which is 29mm wide. It'll be used for trail and also road. I thought I'd get a couple of sets of tyres, probably Small Block 8s, but some slicks as well. Anybody any experience? Seen these Schwalbe Kojak 20" Tyre | Buy Online | ChainReactionCycles.com
    just wondered if they would go on the 29mm rim OK?
    Any ideas/suggestions for a lightweight slick type tyre?
    Reputation: Welnic's Avatar
    Feb 2013
    The people that know about 20" slick tires ride recumbents.
    1.35" kojak should be about 34mm wide, should work fine with a 29mm width rim. If you want faster, smaller tires you should also probably consider getting narrower rims so that the width of the tire does not drop below width of the rim.
  1. Trigger carbon 1, need tyre recommendation
    By motoadve in forum Weight Weenies
    Last Post: 01-18-2013, 05:07 PM
  2. Semi-slick tyre recommendations?
    By Tidybeard in forum Turner
    Last Post: 06-29-2012, 07:34 AM
  3. 26' Semi Slick Tire recommendation
    By likeaboss in forum Wheels and Tires
    Last Post: 03-24-2012, 10:00 PM
  4. Will a 1.25 inch slick tyre fit a Alex Ace-17 rim?
    By bikeman1 in forum Wheels and Tires
    Last Post: 10-23-2011, 03:49 PM
  5. slick tire recommendation
    By packfill in forum 29er Bikes
    Last Post: 01-09-2011, 06:34 PM
