Results 1 to 5 of 5
    Saved 671g with tires
    So I was thinking that my son weighing in at a whopping 75lbs would be fine on a lightweight race tire. I picked up some Bontrager XR0 Teams from ebay and threw them on his bike tonight. Pulled off a couple of Saquaros running tubes because I could never get them to seat using a floor pump on his DT XRC330 rims. Figured I would give these a shot at tubeless and they ended up being the easiest tires I have ever set up tubeless. Between the tires and tubes we are down a pound and a half. I figure the slightly better than semi-slick should be fine with the speeds he is running.
    Impressive weight savings, these are 26", (not 24" 507mm) tires I assume? Anyone have current suggestion for a lightweight 24" tire?
    I come from a cyclocross background and you can definitly still get impressive amounts of traction without heavy tread blocks, helps with both reducing weight and rolling resistence.
    Quote Originally Posted by GrayJay View Post
    Small Block 8
    Quote Originally Posted by bme107 View Post
    Small Block 8
    If you want actual knobs for some traction I say Rocket Ron or Mow Joe. I'm running a RR on the front and MJ on the rear of my son's.
    Rocket Ron HS 438 | Schwalbe North America
    Mow Joe HS 371 | Schwalbe North America
    OG Ripley v2
    Carver 420 TI
    Reputation: Zerort's Avatar
    Jan 2013
    I put the RoRo's on my son's bike 2.1 front and rear. He's alot more confident now that he doesn't have to worry about the tires washing out from underneath him as the stock tires did. Expensive - but great tires.
    by Silentfoe
    I'm satisfied knowing that what I wear during my "day" job makes me more of a man than you'll ever be.
  1. New wheels and 1.2 pounds saved!!
    By cstem in forum 29er Components
    Last Post: 02-16-2013, 07:47 AM
  2. How I saved Tinker's life
    By chiito in forum Arizona
    Last Post: 01-09-2013, 04:02 PM
  3. RTP saved again ... for now
    By crossboy in forum North & South Carolina
    Last Post: 04-19-2012, 06:00 AM
  4. my camelback saved my a$$ today
    By Adam_B. in forum Beginner's Corner
    Last Post: 06-22-2011, 08:45 PM
  5. I May Have Saved My OWN Life Tonight
    By highdelll in forum Commuting
    Last Post: 02-07-2011, 10:09 PM
