Results 1 to 2 of 2
    Mountain Biking Newbie
    Feb 2012
    Rust on a used bike
    Was looking to pick up a used Specialized Hotrock 20" for my son. Found a couple in my area....one is a so-so deal, could be cheaper, but it has rust on two nuts at the tire axles....all on the same side...only thing is I can't tell if there is rust on the actual axle/screw. On the bike that is a really low price, there is rust on the nut as well as on the axle screw from what I can tell.
    Do you think a little bit of rust is a problem if it's on the axle screw/bolt? If it's on the nut, that can be changed out...but not sure how to get ride of the rust if it's on the actual screw.
    Any thoughts? Should I stay away from anything used that has rust?
    2014 Felt Q24 Disc
    2013 Specialized Hotrock 24 XC Disc
    2011 Specialized Epic Comp 26
    Jan 2013
    I wouldn't worry too much if it's just surface rust. This is a bike that will be supporting what, 75lbs max? And topping out at what 15mph? Not speeds or weights that will come anywhere close to causing a failure. As long as is doesn't look like it's rusted through I say get the cheap one and clean it up.
  1. Replies: 49
    Last Post: 08-05-2013, 11:55 AM
  2. How to get rust off rotors
    By mtnbiker64 in forum Brake Time
    Last Post: 07-20-2012, 08:48 AM
  3. Anybody Have Rust on their HD?
    By nightops in forum Ibis
    Last Post: 06-16-2012, 10:42 PM
  4. SIR 9 Rust on TT Gusset
    By Niner Rider in forum 29er Bikes
    Last Post: 04-04-2012, 11:02 AM
  5. Rust on my HD
    By biketrader in forum Ibis
    Last Post: 03-30-2012, 06:14 PM
