Results 1 to 3 of 3
    Birdman aka JMJ
    Reputation: Birdman's Avatar
    Mini BMX seatpost - Custom vs. Odyssey Jr.
    I recently got my 4 year old daughter a 2008 16" Specialized Hotrock (in hiding for Christmas). After a quick cleaning and tune, I decided that the spec was pretty decent except for the steel seatpost.
    I searched for a lighter 22.2mm seatpost, but they are very expensive or very heavy (or too short). I decided on an Odyssey Jr. post and scored a good deal on one. Only problem is that the post is only 180mm long. I sized it up to the bike, which I had already adjusted the seat height to my daughter's leg length, and I was already near the recommended max height for the Odyssey post.
    So, I ordered some thickwall 6061 aluminum 7/8" OD tubing and dug up an old Syncros hardcore seat clamp that I'd had in my parts bin for a decade.
    Since the seat clamp was sized for a 27.2mm post and could not be turned down sufficiently to fit the 22.2mm post, I fabricated a 6061 aluminum adapter sleeve and married the 2 parts together. Everything is bonded together with high strength metal epoxy. A little clunky, but lighter than the steel post.
    Here's a comparison. The Odyssey post is 180mm and 152g, the hybrid Syncros post is 235mm and 212g.
    I'll post an update once I have it mounted and tested.
    JMJ
    Birdman aka JMJ
    I mounted the post on the bike last night. I had a brief WTF!!! moment when I saw that the seat rails were 3/8" narrower than the spacing on the seat clamp, but it turned out to be the way the steel seatpost clamp squeezes everything together. A good hard pull on the seatrails re-spaced them to the correct dimension.
    Doesn't look too bad - sheds 120g over the steel post (332g vs. 212g).
    JMJ
    Attached Thumbnails Attached Thumbnails Mini BMX seatpost - Custom vs. Odyssey Jr.-syncros-post-3.jpg
    GMF
    GMF is offline
    Mmm... Tasty
    Reputation: GMF's Avatar
    Very nice. It gives the already industrial looking syncros seatpost clamp a little more edge. You are letting the world know your daughter is ready to rip up some trails...
  1. mini lathe or mini mill
    By doogs in forum Lights DIY - Do It Yourself
    Last Post: 05-22-2009, 05:32 PM
  2. Memorial Day Micro-Mini, Mini Gathering ( Pic Heavy )
    By outdoornut in forum Virginia, WV, Maryland, DC, Delaware
    Last Post: 06-05-2007, 04:45 PM
  3. Replies: 5
    Last Post: 03-30-2006, 12:27 AM
  4. Hope Mini Upgrades/Changes (Not Mini Mono)
    By myitch in forum Brake Time
    Last Post: 08-26-2005, 12:55 AM
  5. hope mini vs mono mini
    By pfunk in forum Brake Time
    Last Post: 06-13-2004, 12:32 PM
