Results 1 to 10 of 10
    Good job! Lewis's carrera blast
    Lewis's bike started off as a normal hefty 27.5lb ish bike from halfords. I didn't want to spend too much on him if he wasn't going to take an interest in the sport. other than the really crap brakes which where swapped straight away he got on ok with the bike. Once he started to show an interest I changed things over so that the bike was more suited to his size and so we could loose a wad of weight. I did the transformation over a year or so.
    at the start 27.5lb ish
    and now 22.78lb
    current spec
    forks - RST F1RST air 24
    Brakes - avid elixir 3 160mm rotors
    Crank - Thorn 150mm + RF NW 30t
    Pedals - DH sport direct from china
    Chain - KMC X10 93
    cassette - XT 10sp
    Rmech - SLX shadow + medium
    shifter - zee 10sp
    Wheels - superstar switch evo (rebadged Novatec D881SB front and D882SB) laced to Alex ACE 20 rims with sapim race DB spokes. titanium QRs
    tyres - schwalbe rocker ron set up tubeless
    saddle/seatpost - SDG bel air & Kore T-Rail post
    bar - eXotic Scandium Riser Handlebar 620mm
    stem - standard
    grips - uberbike lockons
    sadly I work weekends so we don't get as much time to get away as I would like but his skills are improving as is his confidence. If he comes off he gets back on and trys again.
    Mar 2012
    Very nice! Out of curiousity, how much does your son weigh and how tall is he? How much air do you end up putting in the fork?
    136cm
    30kg kitted up
    60psi with no compression added and rebound to taste - still playing about with pressures though. manual says 30-40psi for riders 20-40kg.
    Jan 2009
    It turned out very nice Poah. And at 22lbs ish, its pretty darn light too. Nice job.
    Reputation: Mark194's Avatar
    Mar 2012
    Where did you find the crankset? Does it have a square taper BB?
    Quote Originally Posted by Mark194 View Post
    Kids Cranks | MTB mumblings
    wee update. fitted a 40t expander, new pedals (resin), 50mm stem and carbon haven bar.
    Nice build! I want to get one of those 40t or 42t cassette expanders as well.
    For reference, my kid is 72lbs (32.6Kg) and uses about 65-70psi. So we are in the same ball park for fork air pressures.
    Also, does he have good leg extension with that seat height? It looks low. And is it comfortable for him to ride it with "nose" down orientation?
    seat down comfy yes, saddle was down as he was using his ramps. its higher for climbing etc. really need to get him a dropper post
    Quote Originally Posted by POAH View Post
    That's what I was going to recommend if he likes to raise and lower his seat a lot. You should see if he can get comfortable with a raised seat and doing belly to seat type maneuvers over steep or jump type things.
  1. Carrera Vulcan - Is it worth 400$?
    By rushhenn in forum Bike and Frame discussion
    Last Post: 12-02-2013, 07:15 AM
  2. carrera centos?
    By ripper. in forum All Mountain
    Last Post: 06-12-2013, 08:10 AM
  3. Carrera Mountain bikes
    By Gunner265 in forum Passion
    Last Post: 03-08-2013, 04:49 PM
  4. carrera bikes
    By lgoldie10 in forum General Discussion
    Last Post: 04-04-2012, 09:07 AM
  5. Carrera Bikes
    By sega_rt in forum Beginner's Corner
    Last Post: 03-22-2011, 10:33 AM
