Results 1 to 7 of 7
    Jan 2013
    Kid friendly floor pump
    Anyone recommend a floor pump that is easy enough for a 75# kid to pump to 60 psi? I want to teach and encourage my son to do his own basic maintainence. He can pump his tires (26 x 1.5 if it matters) to about 40 psi with a lot of effort with my Blackburn AirTower 4 but not 60 psi (they're city tires not knobbies) at all.
    Are there any pumps that are any easier? Maybe a big volume cylinder for less pressure resistance with each stroke?
    Thanks.
    Oct 2012
    If he's 75lb, would you trust him with an air compressor? You can get a cheap pancake compressor for cheap these days...
    Apr 2014
    I was also thinking air compressor.
    Re: Kid friendly floor pump
    You want a LOW volume, small diameter cylinder to make it easier, not high volume. Yours looks like it is a road bike pump, so not sure if you can find anything with a smaller-diameter cylinder or not.
    Lezyne pumps are really good. It isn't too difficult to pump 60 psi with my high-volume model. If a friend or lbs has different road bike pumps he could try.
    He will be growing fast and will soon be able to use yours. Meanwhile, help him.
    Does he really need 60 psi?
    40psi in a 1.5" tire is likely excessive pressure for a 75 pound kid, you want a bit of deformation of the tire to smooth out the bumps, even for mostly asphalt riding.
    +1. And better traction & handling.
    Jan 2013
    Thanks. Good points
  1. Best floor pump?
    By nrsnow in forum Wheels and Tires
    Last Post: 03-05-2014, 10:50 AM
  2. Floor pump
    By client_9 in forum Where are the Best Deals?
    Last Post: 02-02-2014, 09:35 PM
  3. Floor Pump
    By Blueliner in forum Tooltime
    Last Post: 04-02-2013, 08:10 AM
  4. Fat floor pump
    By Saw in forum Fat bikes
    Last Post: 01-02-2013, 07:47 PM
  5. Floor pump as a shock pump?
    By AZGroundPound3r in forum Shocks and Suspension
    Last Post: 05-12-2012, 05:00 PM
