Results 1 to 3 of 3
    Sep 2013
    Hotrock 20" coaster bike upgrades
    Just picked up a used Hotrock 20 for my growing 6 yr old son. It appears to be the 2013 model (current design) and I decided to go with the lighter solid fork version. While the bike cosmetically seems to be in great shape, there is some noise coming out of the coaster brake while spinning forward under weight. Will try to repack the bearings this weekend. Also I'm considering possibly rebuilding or replacing the bottom bracket. Could someone tell me what size bb should I be looking at? The 6sp version has it spec'ed 68mmx128mm, but the coaster version does not list the size. Could the crank size also be different between the two models? (Ours is 115mm). Final question - when my son is ready for gears, would it make more sense to buy another Hotrock with gears or try upgrading this one?
    Happy cycling!
    --Rob
    CJH
    CJH is offline
    Quote Originally Posted by ne0en View Post
    Pretty sure the two Hotrock 20's have different crank and bb setups from each other. The coaster model is more like the coaster 16 and will require an adapter to fit a lighter, three piece.
    The 20 coaster should only have 110mm rear hub spacing so adding gears is not as easy as a new hub/wheel setup.
    I think a few builds here have squeezed in a few gears or added a three ring crank up front. I think it's better to get a geared bike and maybe keep the coaster model for dirt jump park or jumps out on the driveway or whatever.
    All of my advice is coming from faint memories. If we get the expected cold, rainy weather here I may see if I have some old threads bookmarked on another computer.
    Sep 2014
    Does the newer 20" bike with coaster brake still have the one piece crank? It looks like it, on the Specialized site it says "Steel, OPC Ball retainer type" There's a kit you can buy that converts that type of bottom bracket shell to use more mainstream bottom brackets (like the one on the 6 speed hot rock). You can search for Truvativ american to euro converter. I haven't tried one of these, because we need gears so I just move to a 6 or 7 speed with 135mm spacing in the rear.
  1. Hotrock 12" coaster brake drag: problem & solution (well, sort of)
    By oren_hershco in forum Families and Riding with Kids
    Last Post: 11-25-2014, 02:49 PM
  2. Upgrading Specialized Hotrock 20 coaster
    By mrshinsa in forum Families and Riding with Kids
    Last Post: 04-28-2014, 01:42 PM
  3. 20" Hotrock Project Bike
    By mtb1983 in forum Families and Riding with Kids
    Last Post: 02-05-2014, 11:25 AM
  4. Need advice on hotrock coaster 20
    By Shiftredline in forum Families and Riding with Kids
    Last Post: 08-20-2013, 05:42 PM
  5. Hand Brakes for a 16" Coaster Brake Bike
    By Viva Borracho in forum Families and Riding with Kids
    Last Post: 02-28-2011, 12:19 PM
