Results 1 to 2 of 2
    Reputation: usmceric1's Avatar
    Mar 2014
    Help me with Cannondale Trail 24 build
    Here are the stock specs: Frame: Trail 24, Optimized 6061 alloy, smooth welding
    Fork: SunTour XCT-JR 24, 40mm travel, 1-1/8" steerer, coil, w/ canti mounts
    Crank: Alloy 152mm crank, 36T steel chianring
    Bottom Bracket: Cartridge square taper
    Shifters: Shimano, RS-36, Revo Twist
    Cog Set: Shimano, 7-speed freewheel, 14-28
    Chain: KMC Z50, 1/2x3/32"
    Rear Derailleur: Shimano, TX-35, 7 Speed, MegaRange
    Rims: Alex Z1000, single wall, 32 hole
    Hubs: Formula Alloy hubs, nutted axles, rear 7 speed
    Tires: Cannondale 24x2.0", wire bead
    Pedals: VP Composite platform w/ reflectors
    Brakes: V-Brake, Alloy linear pull
    Handlebar: Alloy, 580mm wide, 25.4mm
    Stem: Alloy Ahead, 60mm
    Headset: Tange Seiki Alloy, 1-1/8" Ahead, integrated
    Brake Levers: Alloy, linear pull
    Spokes: Steel, 14g Black
    Grips: Cannondale Kid's Performance
    Saddle: Cannondale Boy's Ergo
    Seat Post: Cannondale Alloy, 27.2
    Mar 2014
    So the first thing I want to change up is the whole drivetrain. I would like to go either 1x9 or 1x10. Which ever is the best option price wise. Changing out the drivetrain will force me to get a new wheelset. I am thinking of going to a Stans 24" 24 spoke setup. I need hub choices. Also will be going to trigger shifters. After the wheels and drivetrain, the only other component would be to go with a decent hydraulic disc brake setup. I am currently searching everywhere for a used Rock Shox SID 26" fork (older model).
    Stem, seatpost, and handlebars will be an easy swap.
    With the drivetrain swap, I am going to need shorter crankarms, so that is an issue. Also it has a square taper BB, can that be changed out to something more compatible with whats out there for sale?
    I am guessing I should stay away from a long cage RD?
  1. Replies: 0
    Last Post: 08-08-2014, 06:56 PM
  2. 2013 Cannondale Trail SL 2 (26er) or 2014 Cannondale Trail 5 (29er)
    By quickmammoth in forum Beginner's Corner
    Last Post: 07-06-2014, 08:02 AM
  3. Replies: 0
    Last Post: 08-25-2013, 09:37 AM
  4. please delete
    By discohospital in forum Cannondale
    Last Post: 07-20-2013, 01:54 AM
  5. 2011 cannondale trail sl3 vs 2012 cannondale trail 5
    By idon'tlikepink in forum Beginner's Corner
    Last Post: 08-22-2012, 07:56 AM
