Results 1 to 12 of 12
    Jun 2013
    Help Installing used Tag A Long
    I bought a used Kent CO Pilot trailer bike on Craigslist and didn't get any shims for the hitch. Since I don't have the owner's manual, I'm not sure how tight to make the hitch. I had to make my own shims and have the ability to make it as tight as I need to. Should it be able to rotate around the seat post at all? I have searched high and low for advice on installation and can't find anything definitive. Any suggestions would be much appreciated!!
    Does the hitch system incorperate a U-jount that allows it to articulate side-to-side as you turn? If so, the clamp to the seatpost can be tight (no movement when turning). I had an "allycat" tag along with shim hitch that relyed on the shims slipping around the seatpost in order to provide turning. In that case, the shim does need to be loose enough to allow the trailer to turn but not so loose that it wobbles.
    Suggestion for dealing with any trail-a-bike that has a hitch that is PITA to install/remove from your nice bike, get a second seatpost and seat, leave the hitch permanantly affixed to the spare and then quickly swap it with your nice post. much faster changeover and will save your nice post from getting scratched.
    Jun 2013
    No the hitch system does not have u joint that allows articulation. I have never used one of these, so I wasn't sure how it should work. So, the tag a long should move side to side and not stay directly in line with my bike, correct? If that is the case, I will use a smaller shim that allows it to swivel on the seat post.
    Reputation: logbiter's Avatar
    If it's like my Adam's trail-a-bike, the hitch shouldn't move at all once installed on the seatpost. The shims it comes with appear to be some form of acetal-like plastic.
    Jun 2013
    @logbiter - If I install the hitch tight with no movement, then the bike will have no ability to move while turning, as there is no articulation in the remainder of the hitch.
    mamilli -
    For your tag-along, if there is not a seperate U-jount, the hitch does need to be able to swing side-to-side, the kids rid should not be rigidly bolted to your bike with no ability to swing. If you do solidly bolt it, the lever arm back to the kids wheel is so long that it will still slip sideways when you turn (or break something) but will be unable to re-center and follow strait.
    For my alleycat trailer, I despised the stupi, clunky sliding shim hitch system enough that I cut it off and added a seperate U-joint and newly fabricated solid clamp to the seatpost, much faster to install/remove and I dont have to mess up my seatpost position every time daughter want to go for a quick ride around the block with me.
    Feb 2012
    I have one, the seatpost part is a square tube with a "V" welded into the end, another "V" clamps with 4 bolts to the front of the seatpost - making this- ==<0>
    The copilot then has two joints, one up/down one left/right and a smaller square tube that goes inside the part bolted to the seatpost.
    A quick release clamp functions as a pin through both halves to keep them from coming apart.
    The part bolted to the seatpost must be solidly tightened touching the seat collar on your bike so it doesn't push your seatpost down, I tried a rubber shim in between the post and connector halves to save the seatpost from scratches and the results were disastrous. Just use an old seatpost if yours is really nice.
    Reputation: joe_bloe's Avatar
    Can you post a picture of the hitch and joint?
    Feb 2012
    Tomorrow I should be able to post a picture, hopefully I have the same model.
    Quote Originally Posted by GrayJay View Post
    Pic please.
    Not to thread jack, but our Trek uses the plastic shim and I'm not a fan. I don't have a spare post, anyone tried anything that works to prevent the shim from scratching the post?
    Quote Originally Posted by haager View Post
    Pic please.
    Here you go;
    Help Installing used Tag A Long-easter-003.jpgHelp Installing used Tag A Long-easter-004.jpg
    This alleycat started with a plastic sleeve hitch that was slow and aggravating to attach/detach. I cut it off and brazed on a U-joint and a split collar clamp that is much easier to install/remove, does not require removing the seatpost.
    Feb 2012
    sorry, totally forgot about this until I found a pic on my phone of it.
    Here's the original when it's apart
  1. help installing dhx air.
    By SantaCruzGoblin in forum Shocks and Suspension
    Last Post: 11-21-2012, 10:31 AM
  2. Replies: 8
    Last Post: 10-15-2012, 04:35 AM
  3. Need help/advice on long long long rides
    By OSOK in forum Passion
    Last Post: 08-14-2011, 10:41 AM
  4. Need Long Sleeved Shirts For Riding, But In Long Size
    By CharleyGnarlyP290 in forum Apparel and Protection
    Last Post: 07-21-2011, 06:20 PM
  5. Replies: 9
    Last Post: 01-26-2011, 06:14 AM
