Results 1 to 5 of 5
    Reputation: LewisQC's Avatar
    Jul 2013
    Grip for small hands...
    Hi
    I want to get rid of grip-shift shifter on my son's and daughter's bikes. Probably with this
    http://www.amazon.com/Shimano-Acera-...rigger+shifter
    I will need some grip as well but I can't find small ones for children.
    Is it possible to buy regular lock-on grip and just cut them the size I want?
    Jan 2015
    Quote Originally Posted by LewisQC View Post
    Hi
    odi lock on grips come in mini widths. would probably have to trim the flange for the shifters.
    http://www.amazon.com/Odi-Ruffian-Lo.../dp/B000AOA32Q
    sinz also has mini non lock-on grips
    https://www.jrbicycles.com/storefron...productId=4808
    bicyclist
    Jan 2011
    My daughter picked out some ODI mushroom grips at the LBS, I cut about 1.5" out of the middle and glued them on, those look and work great.
    If the lock-ons you want have locks on both ends this approach might work with the low-torque of a kid's hand grip and you could even look into bonding the base plastic cut faces together with JB weld. Or make the center cuts at a 45 degree angle so they are kind of keyed together.
    Reputation: BXCc's Avatar
    May 2012
    Hi
    Amazon.com : Shimano Acera SL-M310 Rapid Fire Shifter, Right (Black, 7-Speed) : Bike Shifters And Parts : Sports & Outdoors
    I did the same on both of my daughters bikes. The M310 shifter has been a huge help with shifting. One of my criteria was a 7 speed drivetrain just for this reason. It's near impossible to find a 6 speed trigger shifter. As far as grips go, ESI is a great choice. They come in many colors, are under $20, don't slip at all, and don't have a grip pattern. I got them their color of choice, then cut about a third off of the grip.
    Extreme Steering Inc.: "Racer's Edge" 9 Colors $16.99
    Jul 2013
    Thanks guys!
  1. Recommendations for grips for really small hands
    By Bumpyride in forum Fat bikes
    Last Post: 03-14-2014, 08:09 AM
  2. Brakes for small hands
    By Rob-Bob in forum Downhill - Freeride
    Last Post: 01-01-2013, 09:25 AM
  3. Free Stroke Adjustment Necessary for Small Hands?
    By sneakyt in forum Women's Lounge
    Last Post: 10-08-2012, 03:03 AM
  4. Disc brakes for small hands!
    By MIOM in forum Brake Time
    Last Post: 09-25-2012, 01:52 AM
  5. Lock on grip reco for small-med size hands??
    By evil monkey in forum General Discussion
    Last Post: 10-18-2011, 06:52 PM
