Results 1 to 5 of 5
    GMF
    GMF is offline
    Mmm... Tasty
    Reputation: GMF's Avatar
    DIY crank shortening
    Like many parents on this forum, I'm a fairly avid cyclist and have accrued parts over time that are no longer in use. I've also accrued children over time who could maybe put said parts to use. Problem is grown-ups = big, and kids = small.
    So we've been steadily making little tweaks and changes to my son's specialized hotrock, and I wanted to get him a better crank setup. I had an old Cannondale Coda crank i got off e-bay for like $30, complete with chainrings and BB that had been taken off another project and I just didn't see them being used, so I decided to try and adapt them for my son. Being a fan of accruing tools, i found a reasonable set of pedal taps off ebay for like $35, and purchased a 9/16 drill bit (although a more common 1/2" will also work, just be harder to tap).
    All i used was a cheap power drill, hacksaw, dremel, file, a wood block, and my son helping hold things steady.
    Step 1) Eyeball desired crank length (i believe we went with a 135? About 10mm longer than what he had). Shown here is the original 175 vs. the new holes. The wood block was used to back up the crank as i drilled into it. Get as plumb to the crank as you can :-).
    Step 2) Trim off the extra arm. I think I actually used my chopsaw here, but a hacksaw would have been just as good.
    Step 3) shape to clean it up. I cut the square corners off with a combination of the hacksaw, dremel, and a file. The dremel didn't actually help too much. Just gave the sawing muscles a bit of a break.
    Step 4) Install and enjoy. They are reasonably light, plenty strong, roll on a decent BB, and look pretty cool (although he wants to paint them electric blue).
    The keen eye will notice that this particular crank is thinned out on the backside, but there was still enough meat for 3 or 4 threads, which is enough as long as you don't super crank down on the pedals tightening them.
    His next set may be an old pair of race face cranks that have been sitting in the parts bin forever...
    This was surprisingly easy to do, and any "not straightness" in the drilling hasn't been an issue.
    Just thought I would throw this out there and share with the universe. I now have no concerns about making more "custom" cranks as he (or his sister) gets older, and now I have the tools!
    RAKC
    Reputation: tigris99's Avatar
    Re: DIY crank shortening
    Very nice. Was trying to figure out if this would be possible on my son trek mt60 but decided not to try till I read this, much easier than i thought. Makes it possible to put any crankset u want to kids size. I know my son could use a granny ring sometimes cause that bike though light really isn't that light when u scale down to bike weight vs child size, be like me riding a 45+ lb bike.
    Sent from my HTC Sensation Z710e using Tapatalk 2
    GMF
    GMF is offline
    Mmm... Tasty
    Yup, you got it. This is an old 94bcd crank, so I was able to run a single 29t chainring, which is working well enough for now, but I can easily build a crank that can do gears. I'm trying to keep it light, though, and my boy can climb most stuff around, assuming he wants to...
    RAKC
    I know part of my sons issue is because he doesn't wanna shift but couple trails here have short steep climbs that are too much for him in low I think. Being only 6 and riding singletrack with me is surprising in itself.
    Other thing. Rediculous looking "dialed" crankset with holes for moving pedals out further. Makes sense but look horrible and he hits them on things all the time. Oh and their steel. But being lack of cranksets that short I didn't want not to have the longer option when he gets bigger. Well that was my concern till now LOL.
    Good job, I am suprized that they came out acceptably plumb done just by hand-drill. It is pretty easy to make a jig using an old BB spindle to align and then do the drilling in a drill-press to ensure the new hole is dead strait. good tutorial for this at;
    Home Built Bikes - Tips, Tools & Help
  1. Shortening Spokes
    By pcxmbfj in forum Wheels and Tires
    Last Post: 11-20-2012, 07:40 PM
  2. Shortening hoses
    By jrafter in forum Brake Time
    Last Post: 10-30-2012, 06:18 PM
  3. Shortening STEMS
    By timng85 in forum General Discussion
    Last Post: 09-23-2012, 11:31 AM
  4. shortening cranks?
    By tripwr1964 in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 02-13-2012, 06:59 PM
  5. Shortening Gripshifters
    By hisbabyf in forum SRAM
    Last Post: 04-14-2011, 05:12 AM
Members who have read this thread: 7
