Results 1 to 12 of 12
    Jun 2010
    Custom build 24" Kids bike.
    My daughter turns 8y/o next month and I have been searching for a good quality 24" kids bike. I like most liked the look of the Scott Scale RC, but didn't like the $1,000 price tag. So I set out to build up my own. Only stock parts remaining are the frame, brake levers and seat. In all it dropped the weight from close to 30lbs, down to 22lbs and is a pretty sweet little ride! Hope this helps some bike crazy dads (and moms) out who don't want their kids on a 30lb POS...
    Here are the specs, and some before and after pics:
    Used Scott Racing 24" bike used: $150
    Custom powder Coat: $100
    Custom built wheelset with Shimano XT hubs Sun Rino rims: $100
    Custom carbon fork with disc (ebay) $100
    XT 10speed rear 11x36 with 34T front chainring: $20
    XTR rear brake (garage)
    Avid disk front with stock levers that adjust well for small hands
    synz 140mm BMX crank, 110BCD: $20
    FSA Ti bottom bracket: $25
    Lightweight 26.8 seatpost and stem: $75
    Schwalbe Rocket Ron tires set up tubeless $75
    wellgo alloy pedals: $20
    Odds and end pink goodies to girlify it
    Yes I spent about $200 more than my goal, but the result was a bike that blows the scott scale away for about $700
    Attached Thumbnails Attached Thumbnails Custom build 24" Kids bike.-2013-04-24-13.30.12.jpg
    Mantis, Paramount, Campy
    Reputation: Shayne's Avatar
    Nice
    You could probably drop 2+ pounds on the wheels though. XT hubs are HEAVY as are Rhinolites.
    Jun 2010
    Quote Originally Posted by Shayne View Post
    Nice
    I agree, sugestions on a rim. I did these because I got the rims for $20 and had the hubs in my garage
    Yeah, price wise I guess you can't go wrong there.
    Velocity Aeroheats are nice but pricey. I have 2 sets of them. I believe there is an Alex rim that is cheaper and even lighter though.
    I have the same, the Aeroheats were the only 24inch light rims I could find then someone posted the Alex rims after my wheels were done.
    I'm happy with the Aeroheats, but if I had known about the Alex rims I would have chosen those.
    OG Ripley v2
    Carver 420 TI
    Another strategy for reducing wheel weight- In my experince, 36 or 32 spoke wheels are plenty strong for 250 lbs riders, and complete overkill for a 60 lbs kid. I am working on re-lacing a set of 36 spoke wheels to 18 spoke in rear (6 sets of crossed spokes on drive side - use two hub flange holes, skip one) tension ballanced with 6 radial spokes on the non-drive side (use one flange hole, skip 2). At the rim, lace all the spokes from both sides into the 18 holes originally intended for the drive side spokes. You could likely also reduce rim weight a bit by using a hole-saw to drill out excess material from the rim inbetween the spokes.
    On the front, just re-lace a 36 spoke set as an 18 spoke wheel. (Radial lacing with rim brakes, disk brakes need spoke crosses to transmitt braking force).
    You could certainly use the lightest spokes available for a kid, typical strait 14 gauge spokes are overkill for the load being supported.
    PRETENDURO
    Nice work on the build! Only thing I would suggest since you did away with the suspension fork would be to put a 24"x3" Nokian Gazzaloddi (or a 24"x3" Arrow Racing Wide Bite) tire on the front. You can run them at pretty low pressure (less than 15psi) for an extra bit of squish for the trails. OK, so it would add more weightóthose arenít weight weenie tires by any meansóbut the cornering and traction are superb on those tires. Iím currently running a 24"x3" Gazzaloddi on the front of my sonís custom-built 24" bike, he loves it. Heís always throwing it into corners to see at which point it will break loose. We do a lot of riding on rocky/switchbacky/loose singletrack.
    QUOTE from MTBR.COM: You have given Brewtality too much Reputation in the last 24 hours, try again later.
    Axe
    Axe is offline
    Custom User Title
    Reputation: Axe's Avatar
    For my daughter's Scott Spark 24 I have built Circus Monkey 28h disk hubs and Alex rims. Rims had been kinda narrow, but seem to work fine with Schwalbe's Mow Joe.
    Not sure about disk brakes though, they seem to be very powerful for her, locks rear wheel much too easy.
    Quote Originally Posted by Axe View Post
    Are you using hydro or mech?
    OG Ripley v2
    Carver 420 TI
    Axe
    Axe is offline
    Custom User Title
    Quote Originally Posted by TwoTone View Post
    Mech BB7. With Avid Ti levers, as they have convenient reach and leverage adjustments.
    When would such bike be up for sale?
    My daughter just turned 8 and I need to find something like this. She has out grown her Redline Pitboss. GD
    Can she climb with the 1x10 gear ratio? Is the 34x36 low enough for actual dirt climbs?
  1. Kids 20" Ibex mountain bike build up (with GOOD components)
    By Leopold Porkstacker in forum Families and Riding with Kids
    Last Post: 10-03-2013, 03:01 PM
  2. Replies: 33
    Last Post: 10-01-2013, 02:02 PM
  3. Replies: 0
    Last Post: 07-18-2012, 10:22 PM
  4. WTB: 20" kids bike
    By naiku in forum Virginia, WV, Maryland, DC, Delaware
    Last Post: 05-23-2012, 06:56 AM
  5. Awesome Alpinestars Cro-Mega Kids Bike Build
    By mazdaprotege4 in forum Families and Riding with Kids
    Last Post: 05-20-2012, 06:33 PM
Members who have read this thread: 7
