Results 1 to 19 of 19
    Reputation: SuperJETT's Avatar
    converted son's Precaliber 20 to 9 speed
    I had some old road bike wheels with Shimano 600 (Ultegra) hubs and decided to do some measuring. The 600 rear hub used the same spoke length as the oem Precaliber hub, so I relaced the rim today with it. Add a spare LX derailleur and thumb shifter and the 11-32 cassette and chain off my wife's bike and it's ready to roll tomorrow.
    KHS
    Motobecane
    Fisher
    Kona
    The good and bad of the swap:
    good:
    SRAM 3.0 rear derailleur works just fine
    LX trigger shifter is easier for him to shift than the 6-speed twister
    bad:
    in the small cog I have chain rub against the dropout
    the hanger was bent and I didn't even know, mainly because he mostly rides in 1/2/3
    KHS
    Motobecane
    Fisher
    Kona
    turtles make me hot
    Reputation: NYrr496's Avatar
    I did almost exactly the same thing. I made my son's Precaliber 8 speed with an XT hub, shifter and rear derailler. I think I went 11-32 on the cluster and 34 up front. He climbs everything on it.
    I like turtles
    Have you graduated to clipless pedals yet?
    turtles make me hot
    No. He wanted these Tioga spider web pedals that were a lot of money. I put them on his bike and on the first ride, one of them smacked the back of his calf. The plastic pedals are back on the bike.
    I like turtles
    That 'user' is actually just a ******bag 'grown man' from the jetski site I run trying to be funny.
    KHS
    Motobecane
    Fisher
    Kona
    This weekend I changed out the SRAM 3.0 rd to a Shimano LX and put a 11-34 cassette on. It's shifting perfectly now. Before, the cable pull difference between the 2 meant I could only adjust for one end of the cassette or the other but it was fine since he mainly rode in 1-2-3, maybe 4. Now he has all gears and a 9-speed chain fixed the rub also.
    I have an older XT short cage rd on the way to get the chain further away from obstacles since the long cage on it now is only 2" or so from the ground.
    KHS
    Motobecane
    Fisher
    Kona
    Dang! 9 speeds!? I hope to get out and ride with the girls enough this summer to get Kayleigh to the point where she may need more than the 6 gears she has on her Hotrock.
    Sounds pretty slick...
    GMF
    GMF is offline
    Mmm... Tasty
    Reputation: GMF's Avatar
    I did the same thing with my son's specialized hotrock 20. Swapped out the rear hub, threw on a 12-32 8sp cassette, a rapidfire shifter, and a 32t chainring. So far, that seems like a reasonable gear combination and gets him going everywhere. The long cage LX rear derailleur does certainly hang low, though...
    The new (used) XT rd is on and gives much better clearance, plus is just a nicer/lighter derailleur than the LX long cage and is regular rise instead of rapid rise.
    Both pics are with it at the lowest point it could be.
    LX:
    XT:
    KHS
    Motobecane
    Fisher
    Kona
    The cool thing is that a 20inch frame has disc brake mount.
    OG Ripley v2
    Carver 420 TI
    Apr 2005
    Quote Originally Posted by TwoTone View Post
    Anyone need one? I have one just collecting dust.
    Enjoy every ride!
    Dec 2011
    [QUOTE=SuperJETT;8970864]The new (used) XT rd is on and gives much better clearance, plus is just a nicer/lighter derailleur than the LX long cage and is regular rise instead of rapid rise.
    Just wondering, did you do anything to the front fork by way of "upgrade"? I have just bought a used 2009 Pre Cal and need some advise.
    I did actually. I took the preload adjuster out and cut off 1/2 the threads to lessen the preload. It was a free mod and might soften it a little on bumps, so I figured it won't hurt.
    KHS
    Motobecane
    Fisher
    Kona
    Dec 2011
    Cool, thing is my version only has crappy forks (i guess like nearly all stock 20" HTs) and there's no preload adjust. Any advice on swapping to a rigid fork or idea on how I can open her up and swap some springs maybe??
    Are you sure? It's just a plastic knob on one leg from what I remember.
    Take a look at whatever is holding the spring in the fork, take that out and see if you can cut the threads down safely.
    KHS
    Motobecane
    Fisher
    Kona
    Dec 2011
    Unfortunately, yes - no knobs, just covers. Its this one - trekbicyclestores . com/product/09gary-fisher-boys-precaliber-20-49209-1. htm
    Took it to a couple LBS to see if they could advise why my lad (at 65lbs) gets a decent cushion over bumps, but if he lifts the front while riding or drops off the kerb he bottoms out (I swear there's only 20mm max travel after measuring with tape measure!). Only one side has something in there, other is completely empty.
    Mar 2011
    Quote Originally Posted by m-dub View Post
    Hi...do you still have the precaliber frame? I'm interested on buying it from you. I cant send a PM since i dont have 10 posts yet. Thanks
  1. single speed converted to 2x1 w/front d???
    By droolmonkey in forum All Mountain
    Last Post: 03-01-2010, 06:53 AM
  2. Replies: 4
    Last Post: 09-14-2009, 07:51 AM
  3. Can a Rig be converted on multi speed?
    By begeta50 in forum Gary Fisher
    Last Post: 01-01-2009, 03:44 PM
  4. Can a 9 speed hub be converted to a SS hub?
    By whitelizard in forum Wheels and Tires
    Last Post: 02-22-2007, 01:09 PM
  5. Converted my '05 Hardrock to a single speed
    By grtpmkn in forum Specialized
    Last Post: 09-22-2005, 05:09 PM
