• 11-16-2012
    mtbhead
    Cheap-ish 20" disc wheelset on Ebay - anyone tried?
    These seem to be a regularly available 20" disc wheelset sold on Ebay (white no-name rims, Quando disc hubs, 28 spoke): 20" White Wheelset Gold Quando Hubs Disc or V Brake W06 | eBay
    Weight numbers seem a little heavy, but not too bad, and probably lighter than most 20" bikes stock wheelsets with cheap hubs and solid axles/nuts. I was going to build my own disc wheelset using some older disc hubs I had and the stock rims that came on my son's Spark Jr 20, but this is a reasonably priced (and lazy) option. Well, the wheelset is cheap anyway - the shipping is a bit expensive. Just curious if anyone here has tried them out.
  • 11-16-2012
    TwoTone
    Holy cow those as heavy as the stock 24 inch wheels that came on my son's Marin.
    If you can build wheels do it. You're going to be adding weight in the worst place possible.
  • 11-16-2012
    Rondo
    I like the idea that they are setup for discs already but I concur, build your own wheels. I think for just a little additional money you will be happily satisfied and enjoy them more. :thumbsup:
  • 01-03-2013
    jwolfe0815
    Go with an XT disc hub, sapim/wheel smith/DT Swiss spokes and a BMX rim like alienation. Way lighter......
  • 01-04-2013
    TwoTone
    Old post but a warning because of the last post, if you want Mountain Bike sized tires, then DONT use a BMX rim.
  • 01-04-2013
    NS-NV
    No problems with Alienation 20" Deviants... Comes in 32h too.
    Had them on my son's bike for 3 years, now passed on to my daughter.
  • 01-04-2013
    TwoTone
    Yea I forgot I was thinking of my experience with the 24 inch rims for my son's bike and all the different size 24 inch rims. The first set of rims I bought would only fit the mini BMX tires- expensive lesson to learn the hard way.
  • 01-04-2013
    jwolfe0815
    Bingo
  • 01-04-2013
    Leopold Porkstacker
    At the present my favourite local wheelbuilder is lacing up some 20" double-walled Alienation Runaway BMX rims onto some cheap-yet-lightweight disc hubs. Plenty of clearance up front to run a 20"x2.5" Onza Sticky Fingers (non-19" trials version) tire for plenty of grip, and going to run a 20" Kenda Small Block Eight in back. The wheel build will weigh a couple pounds less than the stock set which apparently is made from lead and granite. :rolleyes:
  • 01-04-2013
    NYrr496
    I've done 20" Velocity Aeroheats on old 8 speed XT hubs and now my son is riding a 24" bike with XT hubs and Sunringle Rynolites. Maxxis Snyper tires. Not the lightest thing ever, but they work good.
