Results 1 to 3 of 3
    Mar 2012
    changing solid axles to 9mm quick release
    I just picked up a used 2010 Marin Hidden Canyon for my 7 year old. It came with a bolt on rear axle. I'd like to switch to a 9mm quick release to allow trailside tube replacement.
    Is that a possibility? Do I need to completely disassemble the rear hub? Where can I get the hollow axle?
    Remove the freewheel, use cone wrenches to remove the axle coned then take the axle to a local bike shop to have them match it up for a hollow replacement axle, should be easy and cheap for a decent bike shop to find one. Note that the QR axle will need to be shorter than the nutted axle so it does not extend past the dropouts.
    Park makes these thin wrenches that are inexpensive and light, perhaps you can just get one of those? Just an idea.
    '15 Specialized Fatboy
    '14 Kona Zone Two
    '13 Surly Big Dummy
  1. Broken a Solid or Hollow Axle or Quick Release Skewer?
    By Scott Novak in forum Wheels and Tires
    Last Post: 10-27-2013, 06:41 PM
  2. changing axles and stems
    By Too old to care in forum Bike and Frame discussion
    Last Post: 07-19-2012, 08:52 PM
  3. KM and quick release?
    By JRR in forum Surly
    Last Post: 03-08-2012, 05:09 AM
  4. Quick Release
    By mb32205 in forum Beginner's Corner
    Last Post: 01-18-2012, 09:15 AM
  5. switched to solid axles on my regular QR hubs:
    By Ganze in forum Urban/DJ/Park
    Last Post: 09-18-2011, 06:04 PM
